6 Debugging Tools and Tips
This chapter describes the utilities and tips that may be used for debugging purposes when developing new nodes in Oracle Communications Offline Mediation Controller. The source code for NARMaker.java and NARViewer.java is available under the “Utilities" section of the CDK Development LiveLink site.
Running Nodes from the Command Line
You can run a node from the command line as a Java application, assuming the main() method has been implemented. The basic syntax for running a node from the command line is:
java fullyQualifiedClassName nodeID OMC_home configFile
where:
nodeID: The unique string identifier for this node.
OMC_home: The location of Offline Mediation Controller installation, such as /ocomc.
configFile: The file name and location of this node's configuration file. Configuration files are generated by the Offline Mediation Controller Administration Client GUI and are generally located in OMC_home/config/nodeID/general.cfg.
The basic contents of the general.cfg file are:
monitorinputtimeunit 'Day'
numchannels '0'
osarsperfile '2000'
rulesfile 'file:@TEST_OCOMC_HOME@/npl/?class=com.nt.udc.rules.Processor.NPL.PRCDemo_npl'
debuglevel 'OFF'
maxlogfilesize '100000'
backup 'false'
checkforosarstimer '1'
idleosarwritetime '1'
recordStatistics 'false'
monitorinput 'false'
asCodebase 'file:@TEST_OCOMC_HOME@'
secondaryConfigFile 'secondary.cfg'
narbackup 'false'
narbackupdays '7'
monitorinputtime '1'When running the node from the command line, the fully qualified class name should be specified by the rulesfile parameter. (That is the name of the class that was generated by the NPLCompiler).
NAR Viewer
Use the NARViewer to view the contents of the binary NAR files produced by a node. NAR files are found in the node's output directory (OMC_home/output/node_id/, where OMC_home is the directory in which you installed Offline Mediation Controller). This utility allows developers to verify the contents of the data that the node is producing.
The NARViewer is in the com.nt.udc.general package in the nodes.jar file.
java com.nt.udc.general.NARViewer NAR_file Output_file
where:
NAR_file: The file name of the NAR file to view.
Output_file: The name of file to print contents to (in ASCII).
The above usage statement assumes that the OMC_home/web/htdocs/nodes.jar is included in the CLASSPATH environment variable.NAR Generator
There is a template NAR Generator class available. To provide meaningful data, developers need to modify the template or create a new class, according to their own requirements.
The sample NARMaker class, as described below, will generate the specified number of NARs in a file called nars.dat. The NARMaker will create NARs that include the following fields:
Table 6-1 NARs Created by NARMaker
| ID | Type | Value |
2 |
MillisField |
<timestamp> |
3 |
IntField |
<Counter starting at 0> |
4 |
StringField |
"Test field" |
The sample NARMaker class is in the com.nt.udc.general package in the nodes.jar file.
java com.nt.udc.general.NARMaker #NARs
where #NARs is the number of NARs to generate.
The above usage statement assumes that the OMC_home/web/htdocs/nodes.jar file is included in the CLASSPATH environment variable.
The source code for the NARMaker class is included here for illustration purposes.
Example 6-1 NARMaker.java
·package com.nt.udc.general;
·import java.io.*;
·import java.util.*;
·import com.nt.udc.ndk.node.*;
·import com.nt.udc.nar.*;
· * This is a _very_ basic NAR file generator. It is intended to be
· * used as a template to generate specific NAR's that match the appropriate
· * node's rules. Modify this code as needed.
· * In this example, the generated NAR's will hold the following fields
· * and values:
· * Field 2 - Time interval
· * Field 3- Integer count
· * Field 4- String
·public class NARMaker
· /** Main method which takes 1 argument:
· * args[0] number of NARs to generate */
· public static void main( String [] args )
· int numNars = 0;
· if(args.length != 1)
· String usage = "Usage: \n" +
· " java com.nt.udc.nar.NARMaker <num_nars>";
· System.out.println( usage );
· return;
· try
· numNars = Integer.parseInt( args[0] );
· catch( Exception e )
· System.out.println( "Exception: " + e );
· // Create the NAR, and set up the initial attribute values
· NAR nar = new NAR();
· // Create 3 DCField objects to put into the NAR.
· DCField[] fields = new DCField[3];
· // Create a dummy time field.
· long time = System.currentTimeMillis();
· fields[0] = new MillisField( 2, time );
· // Create a integer count
· fields[1] = new IntField( 3, 0 );
· // Create a sample String field
· fields[2] = new StringField( 4, "Test field" );
· // Put the fields in the NAR
· for( int i = 0; i < fields.length; i++ )
· nar.setField( fields[i] );
· try
· // Use the file called "nars.dat"
· FileOutputStream fos = new FileOutputStream( "nars.dat" );
· // Loop for "numNars", and create a new NAR.
· for( int i = 0; i < numNars; i++ )
· // Update the time field.
· fields[0] = new MillisField( 2, time + ( i * 100 ) );
· // Update the integer count
· fields[1] = new IntField( 3, i );
· nar.setField( fields[0] );
· nar.setField( fields[1] );
· nar.toStream( fos );
· catch( Exception ex )
· System.out.println( "Exception caught : " + ex );
