A NPL Syntax and Reserved Words
This appendix provides the NPL syntax and reserved words.
Table A-1 lists all the NPL methods and the corresponding syntax.
EBNF for NPL
Table A-1 NPL Methods, Operator and Syntax
| Method | Operator | Syntax |
Program |
( MethodHandlerImportDecl )? ( ConfigDeclaration )? ( VariableDeclaration )+ ( ExposeDeclaration )* ( Statement ) +<EOF> |
MethodHandlerImportDecl |
"import" <IDENTIFIER> ( "." <IDENTIFIER> )* ";" |
ConfigDeclaration |
"Config" "{" ( ConfigAttribute )? "}" |
ConfigAttribute |
<IDENTIFIER> <STRING_LITERAL> ";" |
VariableDeclaration |
CompositeVariableDecl | SimpleVariableDecl |
InputRecDecl | OutputRecDecl |
InputRecDecl |
"InputRec" "{" ( AttributeVariableDecl )+ "}" <IDENTIFIER> ";" |
OutputRecDecl |
"OutputRec" "{" ( AttributeVariableDecl )+ "}" <IDENTIFIER> ";" |
AttributeVariableDecl |
AttributeType ( <ATTRIBUTE_NAME> | <IDENTIFIER> | <INTEGER_LITERAL> ) ";" |
AttributeType <IDENTIFIER> ( SimpleVariableInit )? ";" |
SimpleVariableInit |
"=" Expression |
AttributeType |
"String" | "Integer" | "Long" | "TimeInSecs" | "IP" | "TimeInMilliSecs" | "MAC" | "UInt128" | "Byte" | "Short" | "IPv6" | "Float" | "Double" | "Bytes" | "Object" | "List" |
ExposeDeclaration |
"Expose for" <IDENTIFIER> "{" ( ExposeAttribute )+ "}" |
ExposeAttribute |
<IDENTIFIER> "." ( <ATTRIBUTE_NAME> | <IDENTIFIER> | <INTEGER_LITERAL> ) ( <STRING_LITERAL> )? ";" |
Statement |
IfStatement | AssignmentStmt | FunctionStmt | JavaHookStmt |
IfStatement |
"if" "(" ConditionalExpression ")" IfAction ( "else" "if" "(" ConditionalExpression ")" IfAction )* ( "else" IfAction )? |
ConditionalExpression |
RelationalExpression ( ConditionalOperator RelationalExpression )* |
ConditionalOperator |
<OR> | <AND> |
RelationalExpression |
NestedRelationalExpression | SimpleRelationalExpression | BooleanFunctionExpr |
FunctionExpression |
"(" ConditionalExpression ")" |
Expression RelationalOperator Expression |
RelationalOperator |
<EQ> | <NE> | <LT> | <LE> | <GT> | <GE> |
IfAction |
StatementBlock | Statement |
StatementBlock |
"{" ( Statement )* "}" |
AssignmentStmt |
Variable "=" Expression ";" |
Variable |
<IDENTIFIER> ( "." ( <ATTRIBUTE_NAME> | <IDENTIFIER> | <INTEGER_LITERAL> ) )? |
Expression |
AdditiveExpression |
SubtractiveExpression ( "+" SubtractiveExpression )* |
SubtractiveExpression |
MultiplicativeExpression ( "-" MultiplicativeExpression )* |
MultiplicativeExpression |
DivisionalExpression ( "*" DivisionalExpression )* |
DivisionalExpression |
UnaryExpression ( "/" UnaryExpression )* |
UnaryExpression |
( "(" AttributeType ")" )? ( NestedExpression | VariableExpression | IntLiteralExpression | FloatingPointLiteralExpression | StringLiteralExpression | FunctionExpression | JavaHookExpression ) |
NestedExpression |
( UnaryOperator )? "(" Expression ")" |
( UnaryOperator )? Variable |
( UnaryOperator )? <STRING_LITERAL> |
( UnaryOperator )? <FLOATING_POINT_LITERAL> |
<STRING_LITERAL> |
( "byte2bytes" | "byte2str" | "bytes2byte" | "bytes2double" | "bytes2float" | "bytes2hexstr" | "bytes2int" | "bytes2IP" | "bytes2long" | "bytes2short" | "bytes2str" | "bytes2TimeInMilliSecs" | "bytes2TimeInSecs" | "clone" | "convertDateTime" | "copyBits" | "currentTime" | "double2bytes" | "double2str" | "fieldExists" | "float2bytes" | "float2str" | "int2bytes" | "int2str" | "IP2bytes" | "IP2str" | "list2str" | "long2bytes" | "long2str" | "object2str" | "randomInt" | "randomDouble" | "short2bytes" | "short2str" | "strpos" | "str2byte" | "str2bytes" |
| "str2double" | "str2float" | "str2int" | "str2IP" | "str2long" | "str2lower" | "str2short" | "str2TimeInMilliSecs" | "str2TimeInSecs" | "str2upper" | "strlen" | "subbytes" | "substr" | "time2bytes" | "time2str" ) "(" ( Expression ( "," Expression )* )? ")" |
UnaryOperator |
FunctionStmt |
( "logError" | "logWarning" | "logInfo" | "logTrace" | "write" ) "(" ( Expression ( "," Expression )* )? ")" ";" |
JavaHookStmt |
JavaHookExpression ";" |
JavaHookExpression |
"Java" "." <IDENTIFIER> "(" ( Expression ( "," Expression )* )? ")" |
<IDENTIFIER> |
( <LETTER> | <UNDERSCORE> ) ( <LETTER> | <DIGIT> | <UNDERSCORE>)* |
<ATTRIBUTE_NAME> |
( <LETTER> | <UNDERSCORE> | <COLON> ) ( <LETTER> | <DIGIT> | <UNDERSCORE> | <COLON> | <HYPHEN> )* |
<FUNCTION_NAME> |
<LETTER> ( <LETTER> | <DIGIT> )* |
<LETTER> |
["a"-"z", "A"-"Z"] |
<UNDERSCORE> |
"_" |
<COLON> |
<DIGIT> |
["0"-"9"] |
<HYPHEN> |
<MINUS> |
<INTEGER_LITERAL> |
<DECIMAL_LITERAL> | <HEX_LITERAL> | <OCTAL_LITERAL> |
<DECIMAL_LITERAL> |
["1"-"9"] (["0"-"9"])* |
<HEX_LITERAL> |
"0" ["x","X"] (["0"-"9","a"-"f","A"-"F"])+ |
<OCTAL_LITERAL> |
"0" (["0"-"7"])* |
(["0"-"9"])+ "." (["0"-"9"])* (<EXPONENT>)? |
<EXPONENT> |
["e","E"] (["+","-"])? (["0"-"9"])+ |
<STRING_LITERAL> |
"\"" ( (~["\"","\\","\n","\r"]) | ("\\" ( ["n","t","b","r","f","\\","'","\""] | ["0"-"7"] ( ["0"-"7"] )? | ["0"-"3"] ["0"-"7"] ["0"-"7"] ) ) )* "\"" |
<OR> |
<AND> |
<EQ> |
<NE> |
<LT> |
<LE> |
<GT> |
<GE> |
<MINUS> |
NPL reserved words
Byte
byte2bytes
byte2str
Bytes
bytes2byte
bytes2double
bytes2float
bytes2hexstr
bytes2int
bytes2IP
bytes2long
bytes2short
bytes2str
bytes2TimeInSecs
Config
convertDateTime
copyBits
currentTime
Double
double2bytes
double2str
else
Expose
fieldExists
Float
float2bytes
float2str
for
if
import
InputRec
int2bytesint2str
Integer
IP
IP2bytes
IP2str
IPv6
Java
List
list2str
logError
logInfo
logTrace
logWarning
Long
long2bytes
long2str
MAC
null
Object
object2str
OutputRec
randomInt
randomDouble
Short
short2bytes
short2str
str2byte
str2bytes
str2double
str2float
str2int
str2IP
str2long
str2lower
str2short
str2TimeInMilliSecs
str2TimeInSecs
str2upper
String
strlen
strpos
subbytes
substr
time2bytes
time2str
TimeInMilliSecs
TimeInSecs
UInt128
write
