3 Managing Nodes
You can use Oracle Communications Offline Mediation Designer to add or update nodes in your Node Manager.
To add and update nodes, see the following topics:
Adding a Node
After you create a Node Manager, you can add your first node.
To add a node:
From the Node Managers page, click the name of the Node Manager you want to add a node to.
If this is your first node, click Add Node. If this is an additional node, hover over an existing node and click the menu icon at the end of the node
The Add node dialog box appears.
In the Name and Type tab, enter the following details:
Node Type: Select the type of node that you want to add.
Node Name: Enter a unique name for the node.
Edit Rules: Click to open a text editor where you can enter, compile, and save your NPL rules. For details, see "Creating and Editing NPL Rules Files".
Fill out the settings for your node type. See “Node Type Settings Reference” for more information.
Click Add at the bottom right of the dialog box.
Duplicating Nodes
To duplicate an existing node:
From the Node Managers page, click the name of the appropriate Node Manager.
Hover over the node you want to duplicate and click the following icon:
From the menu, click Duplicate.
The Duplicate node dialog box appears.
Enter a name for the new node.
(Optional) Edit the rules for the node.
(Optional) Edit the settings for your node type. See "Configuring Node Type Settings" for more information.
Click Duplicate at the bottom right of the dialog box.
Editing Nodes
To edit an existing node:
Hover over the node you want to edit and click the following icon:
From the menu, click Edit.
The Edit node dialog box appears.
(Optional) Edit the node type, name, or rules.
Click Update at the bottom right of the dialog box.
You use the Node Programming Language (NPL) rules file to configure how a node processes and translates input data into output data.
All nodes require NPL rule files, but the different types of nodes use them in different ways:
Collection Cartridge (CC): The CC node uses the NPL file to map and associate input data with Network Activity Records (NARs).
Enhancement Processor (EP): The EP uses the NPL rules file to filter unnecessary data, perform mathematical operations on specific fields, add new files, and modify existing field values.
Aggregation Processor (AP): The AP node uses the NPL rules file to aggregate data across multiple records, enabling correlation, summarization, and volume-based processing.
Distribution Cartridge (DC): The DC nodes uses the NPL rules file to map data from the NAR format into an output format suitable for other programs or end users.
To create or edit an NPL rules file for a node:
In the Node Manager page, add, edit, or duplicate a node.
The Add node, Edit node, or Duplicate node dialog box appears.
In the Name and Type tab, click Edit Rules.
The Rules editor dialog box appears. See "Rules Editor Page".
To load the contents from an existing NPL rules file, click the Open Rules dialog icon:
The Load Rules dialog box appears.
Select whether to load the contents from a sample NPL rules file or another node's NPL rules file.
Select the name of the NPL rules file to load into the Rules editor.
Click Load.
For more information about the fields in the dialog box, see "Load Rules Dialog Box".
In the Filename field, enter a unique name for this node's NPL rules file.
(Optional) To expand the Rules editor dialog box, click the Toggle icon:
Add or edit programming lines in the NPL rules file.
For more information about programming using NPL, see "Node Programming Language" in Offline Mediation Controller Cartridge Development Kit NPL Reference Guide.
To compile the contents in the NPL rules file, click the Compile icon:
The Rules editor indicates whether the file compiled successfully or encountered errors.
Click Save.
The settings for your node vary based on the node type you select. The following sections provide information about Offline Mediation Designer node types.
Table 3-1 contains information about the node types available in Offline Mediation Designer.
Table 3-1 Node Type Settings
3GPP 32.015 ASN.1 DC for Wireless Settings
Table 3-2 describes the basic settings for a 3GPP 32.015 Parsing Enhancers EP node.
Table 3-2 Basic Settings Tab
| Field | Description |
| Output Directory Path | Enter the directory in which to store output files. |
| File Name | Enter the base name for the output files. The node appends a sequence number and file extension to this name. |
| Current File Extension | Enter the file name extension to use while the output file is still being written. |
| Processed File Extension | Enter the file extension for completed output files. |
| Time Period to Push Output | Enter the time period after which the output file should be closed and finalized, even if the "Max Records per Output File" limit has not been reached. |
| Time Unit | Select the push output unit: Minutes, Hours, or Days. |
| Encoding Option | Select an encoding method for the ASN.1 data. Options are Definite and Indefinite. |
| Send Output Using FTP | Select to send the output to a remote system using FTP. When selected, you can enter the FTP information for your environment. See "Common FTP Settings" for more information on these settings. |
Table 3-3 describes the advanced settings for a 3GPP 32.015 Parsing Enhancers EP node.
Table 3-3 Advanced Settings Tab
| Backup NAR Files | Select to back up all NAR files. |
| File Retention Period |
(Only appears when Backup NAR Files is selected) Enter the length of time, in days, to retain processed NAR files and backup NAR files. Files older than this period are automatically deleted. |
| Enable Output File Archive/Delete | Select this option to enable output file generation for the node and specify whether the output files are archived or deleted after processing. |
| Archive File |
(Appears only when Enable Output File Archive/Delete is selected) Select to archive all NAR output files after the retention period. |
| Archive Directory Path |
(Appears only when Archive File is selected) Enter the directory in which to archive files. |
| Retention Period (in Days) |
(Appears only when Archive File is selected) Enter the number of days to retain output files until they are archived. |
| Delete Files |
(Appears only when Enable Output File Archive/Delete is selected) Select to delete output files after the retention period. |
(Appears only when Delete Files is selected) Enter the number of days to retain output files until they are deleted. |
| Enable Statistics | Select to collect processing statistics for this node. The statistics are useful for monitoring performance and troubleshooting. |
| Logging Level | Select whether to create a log file. The possible values are On or Off. |
| Max Log File Size | Enter the maximum size, in bytes, for the log file. After the maximum is reached, the node creates a new log file. |
| Input Stream Monitoring | Select to monitor the input stream for potential issues such as a stalled data flow. |
| Interval |
(Only appears when Input Stream Monitoring is selected) Enter the interval at which the input stream is checked for activity. |
| Interval Unit |
(Only appears when Input Stream Monitoring is selected) Select the interval unit: Days, Hours, or Minutes. |
| Optimize Reading and Writing of Files | Select to enable batch processing of read and write operations. |
| Read Timer | Enter the duration, in seconds, between checking for incoming data. |
3GPP 32.015 Parsing Enhancer EP for Wireless Settings
Table 3-4 describes the advanced settings for a 3GPP 32.015 Parsing Enhancer EP node.
Table 3-4 Advanced Settings Tab
File-level Transactions - Input Records Succeed or Fail Together |
Select to process the entire input file in a single transaction. If any record within the file fails processing, the entire file is rejected. |
Backup NAR Files |
Select to enable a back up of all NAR files. |
(Only appears when Backup NAR Files is selected) Enter the number of days to retain processed or backup NAR files. Files older than this period are automatically deleted. |
Max NARs per Output File |
Enter the maximum number of records to add to an output file. After the maximum is reached, the node creates a new output file. |
Write Output After Idle Period |
Enter the duration, in seconds, the node waits before writing an idle record. The minimum value is 1 and the maximum value is 3600. |
| BER Encoding | Select to use Basic Encoding Rules (BER) for encoding records. |
| Aligned PER Encoding | Select to use Aligned Packed Encoding Rules (PER) for encoding records. |
Enable Statistics |
Select to collect processing statistics for this node. This is useful for monitoring performance and troubleshooting. |
Logging Level |
Max Log File Size |
Interval |
Interval Unit |
Use Multiple Threads |
Select to process records using multiple threads. |
Number of Threads |
(Only appears when Use Multiple Threads is selected) Enter the number of threads to use for processing. The minimum value is 1 and the maximum value is 2147483647. |
Produce Output Files in the Order they are Read and Processed |
(Only appears when Use Multiple Threads is selected) Select to ensure that the output files are produced in the same order as the input files are read and processed. |
Read Timer |
3GPP 32.298 DC ASN.1 for Wireless Settings
Table 3-5 describes the basic settings for a 3GPP 32.298 ASN.1 DC node.
Table 3-5 Basic Settings Tab
| Current File Extension | Enter the file name extension for output files that are still being written. |
| Time Unit | Select the push output unit: Minutes, Hours, Days. |
Table 3-6 describes the advanced settings for a 3GPP 32.298 ASN.1 DC node.
Table 3-6 Advanced Settings Tab
| Backup NAR Files | Select to back up all NAR output files. |
(Only appears when Backup NAR Files is selected) Enter the maximum number of days to retain backup NAR files. |
| Enable Output File Archive/Delete | Select to archive or delete the output files. |
| Archive File |
| Delete Files |
| Enable Statistics | Select to collect processing statistics for this node. This is useful for monitoring performance and troubleshooting. |
| Input Stream Monitoring | Select to enable monitoring of the input stream to detect potential issues such as stalled data flow. |
| Interval |
| Interval Unit |
(Only appears when Input Stream Monitoring is selected) Select the interval duration: Days, Hours or Minutes. |
3GPP 32.298 Parsing Enhancer (SGSN06) EP for Wireless Settings
Table 3-7 describes the advanced settings for a 3GPP 32.298 Parsing Enhancer (SGSN06) EP node.
Table 3-7 Advanced Settings Tab
Backup NAR Files |
Enable Statistics |
Logging Level |
Max Log File Size |
Interval |
Interval Unit |
(Only appears when Input Stream Monitoring is selected) Select the duration, Days, Hours, or Minutes, for the "Interval" field. |
Number of Threads |
Read Timer |
3GPP IMS ASN.1 DC for Wireless Settings
Table 3-8 describes the basic settings for a 3GPP IMS ASN.1 DC node.
Table 3-8 Basic Settings Tab
Table 3-9 describes the advanced settings for a 3GPP IMS ASN.1 DC node.
Table 3-9 Advanced Settings Tab
| Archive File |
| Delete Files |
| File Name | Enter the name to prepend to the output file. |
| Current File Extension | Enter the file name extension for files that have not been processed yet. |
| Processed File Extension | Enter the file name extension for processed files. |
| Time Period to Push Output | Enter how long to wait before pushing output files. |
| Time Unit | Select the push output time unit: Days, Hours, Minutes, Seconds, or None. |
| Max Records per Output File | Enter the maximum number of records in each output file. The minimum value is 1 and the maximum value is 200000. |
| Enable Statistics | Select to add statistics to the log file. |
| Input Stream Monitoring | Select to monitor the input stream. |
| Interval |
| Interval Unit |
| Read Timer | Enter the number of seconds between checking for incoming data. (Min=1, Max=3600) |
3GPP Session Sequencing EP for Wireless Settings
Table 3-10 describes the basic settings for a 3GPP Session Sequencing EP node.
Table 3-10 Basic Settings Tab
Expiry Interval (minutes) |
Enter the time the node waits before the sequence record output is sent to the next node in the chain. |
Session Storage Limiting |
Select to enable session storage limiting. |
Limit |
(Only appears when Session Storage Limiting is selected) Enter the maximum number of out-of-sequence partial records in a session to store before flushing the session. |
Log Duplicate Entries |
Select to create a log entry for each duplicate record. |
Missing Record Monitoring |
Select to enable the node to generate alarms or logs for any missing records it detects. |
Missing Record Alarm or Log Severity |
(Only appears when Missing Record Monitoring is selected) Select the log level to record: Informational, Warning, Minor, Major, or Critical. |
Retain Recent Records |
Select to retain recent records. |
Buffer Size |
(Only appears when Retain Recent Records is selected) Enter the buffer size required to retain recent records. |
For more information about the advanced settings for this node type, see "Common EP and AP Advanced Settings".
Aggregator AP for IP Settings
Table 3-11 Basic Settings Tab
| Time Based Session Segmentation | Select to enable time-based segmentation. Sessions are segmented or aggregated based on the length of time they last. |
| Segmentation by 1st CDR arrival time |
(Only appears when Time Based Session Segmentation or Both (Time Based on Volume Based Session Segmentation) is selected) Select to segment CDRs by first arrival time. |
| Flush Time |
(Only appears when Time Based Session Segmentation or Both (Time Based on Volume Based Session Segmentation) is selected) Enter the seconds before an aggregated NAR is flushed. |
| Compression Threshold |
Enter the minimum size that an aggregated segment must reach before compression is applied. This value must be between 1 and 300,000,000. |
| Volume Based Segmentation | Select to enable volume-based segmentation. Sessions are segmented or aggregated based on the amount of data transmitted. |
| Volume Field |
(Only appears when Time Based Session Segmentation or Both (Time Based on Volume Based Session Segmentation) is selected) Enter the CDR field name to aggregate based on volume. |
| Max Volume |
(Only appears when Time Based Session Segmentation or Both (Time Based on Volume Based Session Segmentation) is selected) Enter the maximum volume that a segment can reach before it is flushed. |
| Max volume unit |
(Only appears when Time Based Session Segmentation or Both (Time Based on Volume Based Session Segmentation) is selected) Select the units for the maximum volume: KB, MB, GB, or TB. |
(Only appears when Time Based Session Segmentation or Both (Time Based on Volume Based Session Segmentation) is selected) Enter the minimum size that an aggregated segment must reach before compression is applied. This value must be between 1 and 300,000,000. |
| Both (Time Based on Volume Based Session Segmentation) | Select to enable both time-based and volume-based segmentation. Sessions are segmented based on both the length of time they last, and the amount of data transmitted. |
| Schedule Daily CDR Flush | Select to flush CDRs daily. |
| Daily Flush at Time |
(Only appears when Schedule Daily CDR Flush is selected) Enter the time of day when the daily CDR flush should occur in the format HH:MM. |
For more information about the advanced settings for this node type, see "Common Threaded EP and AP Advanced Settings".
ASCII Collection Cartridge Kit Settings
Table 3-12 describes the basic settings for an ASCII CC node.
Table 3-12 Basic Settings Tab
| Directory Path | Enter the path to the directory where the input files are located. This should be the directory that the ASCII CC node monitors for new files. |
| Local Filesystem | Select to specify that the input files are located on the local file system of the machine running the ASCII CC node. |
| File Parse Delay | Enter the delay, in seconds, that the node waits after detecting a new file before beginning to parse it. This ensures that files are fully written and stable before processing stars. |
| Time Unit |
(Only appears when Local Filesystem is selected) Select the frequency unit: Seconds or Minutes. |
| Local File Suffix |
(Only appears when Local Filesystem is selected) Enter the file extension that helps the node recognize which files in the directory are data files that it should process. |
| Remote Filesystem (FTP) | Select this option to indicate that the input files are located on a remote file system and are accessed using FTP. If selected, the following additional configuration options are required. |
| Add Host |
(Only appears when Remote Filesystem (FTP) is selected) Click to add a host to the remote filesystem. The Remote Host Access, Username, Password, Host, and File(s) to Transfer fields appear. Enter the appropriate values and then click Submit to add the FTP host, or click Cancel not to add it. If you add it, it will be displayed in the table. |
| Remote Host Access |
(Only appears when Remote Filesystem (FTP) is selected) Select the FTP connection type: Secure SFTP, Regular, or Passive. |
| Username |
(Only appears when Remote Filesystem (FTP) is selected) Enter the user name for authentication with the remote FTP server. |
| Password |
(Only appears when Remote Filesystem (FTP) is selected) Enter the password for the FTP server. |
| Host |
(Only appears when Remote Filesystem (FTP) is selected) Enter the host name or IP address of the remote FTP server. |
| File(s) to Transfer |
(Only appears when Remote Filesystem (FTP) is selected) Enter the absolute path of the directory from where the files should be retrieved by the node. |
| Delete Remote Files | Select to delete remote files after they have been successfully transferred and processed. |
| FTP Interval | Enter how frequently to check for new files. |
| FTP Interval Unit | Select the FTP interval unit: Minutes or Hours. |
Table 3-13 describes the advanced settings for an ASCII CC node.
Table 3-13 Advanced Settings Tab
| Reject Duplicate File Names | Select to reject duplicate files from the node. |
| Expiry Time to Reject Duplicate File Names |
(Only appears when Reject Duplicate File Names is selected) Enter the duration, in minutes, to reject duplicate file names. |
| File-level Transactions - Input Records Succeed or Fail Together | Select to process the entire input file in a single transaction. If any record within the file fails processing, the entire file is rejected. |
| Max NARs per Output File | Enter the maximum number of records to add to an output file. After the maximum is reached, the node creates a new output file. |
| Write Output After Idle Period | Enter the duration, in seconds, the node waits before writing an idle record. The minimum value is 1 and the maximum value is 3600. |
| Process Files Sequentially by Name | Select to process the files sequentially. |
(Only appears when Process Files Sequentially by Name is not selected) Select to process records using multiple threads. |
| Number of Threads |
ASCII Delimited DC for Wireless Settings
Table 3-14 describes the basic settings for an ASCII Delimited DC node.
Table 3-14 Basic Settings Tab
Table 3-15 describes the advanced settings for an ASCII Delimited DC node.
Table 3-15 Advanced Settings Tab
| File-level Transactions – Input Records Succeed or Fail Together | Select to treat the entire input file as a single transaction. If any record within the file fails processing, the entire file is rejected. |
| Archive File |
(Only appears when Enable Output File Archive/Delete is selected) Select to archive the output files. |
| Archive Directory path |
(Only appears when Archive File is selected) Enter the directory to which the output files should be moved after the retention period. |
(Only appears when Archive File is selected) Enter the number of days to retain output files before moving them to archive directory. |
| Delete Files |
(Only appears when Enable Output File Archive/Delete is selected) Select to delete the output files. |
(Only appears when Delete Files is selected) Enter the number of days to retain output files before deleting them. |
| Field Delimiter | Enter the characters for delimiting field names. |
| Field Container | Enter the characters for wrapping each field. (Empty for none). |
| Include Header in Output | Select to include the header in the output file. |
| Interval |
(Only appears when Input Stream Monitoring is selected) Enter the minimum silent input time interval to wait before raising an alarm. |
| Interval Unit |
(Only appears when Input Stream Monitoring is selected) Select the units for the input stream interval. |
| Use Multiple Threads | Select to process records using multiple threads. |
| Number of Threads |
(Only appears when Use Multiple Threads is selected) Enter the number of threads to spawn for processing records. |
ASCII Delimited DC for IP Settings
Table 3-16 describes the basic settings for an ASCII Delimited DC node.
Table 3-16 Basic Settings Tab
Table 3-17 describes the advanced settings for an ASCII Delimited DC node.
Table 3-17 Advanced Settings Tab
| Treat file as a single transaction | Select to process the entire input file as a single transaction. If enabled, all records in the file succeed or fail together. If disabled, individual records can succeed or fail independently. |
| Archive File |
| Delete Files |
| Interval |
| Interval Unit |
| Number of Threads |
ASCII Distribution Cartridge Kit Settings
Table 3-18 describes the basic settings for an ASCII Distribution Cartridge node.
Table 3-18 Basic Settings Tab
Table 3-19 describes the advanced settings for an ASCII Distribution Cartridge node.
Table 3-19 Advanced Settings Tab
| Archive File |
| Delete Files |
| Output Directory Path | Enter the directory to store output files. |
| Time Period to Push Output | Enter the time period before pushing output files. |
| Time Unit | Select the unit of time in days, hours, minutes, or seconds. |
| Interval |
| Interval Unit |
| Number of Threads |
ASN1 File Collection Cartridge Kit Settings
Table 3-20 describes the basic settings for an ASN1 File CC node.
Table 3-20 Basic Settings Tab
| Directory Path | Enter the path to the directory where the input files are located. This should be the directory that this node monitors for new files. |
| Local Filesystem | Select to specify that the input files are located on the local file system. |
| Frequency to Check for New Files |
(Only appears when Local Filesystem is selected) Enter the frequency at which this node checks the specified directory for new files. |
| Time Unit |
(Only appears when Local Filesystem is selected) Select the unit: Seconds, Minutes, or Hours. |
| Pattern For Matching Input Files |
(Only appears when Local Filesystem is selected) Specifies the method used to match input files in the directory. Options are Use Prefix and Suffix and Use Regular Expression. |
| Prefix |
(Only appears when Use Prefix and Suffix is selected for Pattern for Matching Input Files) Enter the file name prefix of the input files to process. |
| Suffix |
(Only appears when Use Prefix and Suffix is selected for Pattern for Matching Input Files) Enter the file name suffix of the input files to process. |
| Regular Expression |
(Only appears when Use Regular Expression is selected for Pattern for Matching Input Files) Enter the regular expression that will be used to match the names of input files in the specified directory. |
| Remote Filesystem (FTP) | Select to indicate that the input files are located on a remote file system and are accessed using FTP. |
| Add Host |
(Only appears when Remote Filesystem is selected) Select the FTP connection type (Secure SFTP, Regular FTP, or Passive FTP). |
| Username |
(Only appears when Remote Filesystem is selected) Enter the user name to use for authenticating with the remote FTP server. |
| Password |
(Only appears when Remote Filesystem is selected) Enter the password for the FTP server. |
| Host |
(Only appears when Remote Filesystem is selected) Enter the host name or IP address of the remote FTP server. |
Directory Path |
(Only appears when Remote Filesystem is selected) Enter the port number to use for connecting to the remote FTP server. The default FTP port is 21. |
| File Pattern Mode |
(Only appears when Remote Filesystem is selected) Specifies the method used to match input files in the directory. Options are Use Prefix and Suffix and Use Regular Expression. |
| Prefix |
(Only appears when Use Prefix and Suffix is selected for File Pattern Mode) Enter the file name prefix of the input files to process. |
| Suffix |
(Only appears when Use Prefix and Suffix is selected for File Pattern Mode) Enter the file name suffix of the input files to process. |
(Only appears when Use Regular Expression is selected for File Pattern Mode) Enter the regular expression that will be used to match the names of input files in the specified directory. |
| FTP Interval |
(Only appears when Remote Filesystem is selected) Enter the interval of time between attempts to transfer files to the remote FTP server. |
| FTP Interval Unit |
(Only appears when Remote Filesystem is selected) Select the duration (Minutes or Hours) for the FTP Interval field. |
| Interrupt Timer Delay |
(Only appears when Remote Filesystem is selected) Enter the delay time to implement with interrupts and timers. |
| Interrupt Timer Delay Unit |
(Only appears when Remote Filesystem is selected) Select the duration (Minutes or Hours) for the Interrupt Timer Delay field. |
| Delete Remote Files | Select this option to specify whether the remote files should be deleted after they have been successfully transferred and processed. |
| Rename Remote Files | Select this option to specify whether the remote files should be renamed after they have been successfully transferred and processed. |
Table 3-21 describes the advanced settings for an ASN1 File CC node.
Table 3-21 Advanced Settings Tab
| Backup Files | Select to back up all files after they have been processed. |
| Backup Directory Path |
(Only appears when Backup Files is selected) Enter the path to the backup directory. |
| Prefix |
(Only appears when Backup Files is selected) Enter the prefix to add to file names after the file has been processed. |
| Suffix |
(Only appears when Backup Files is selected) Enter the suffix to add to file names after the file has been processed. |
| Delete Files | Select to delete all files after they have been processed. |
| Number of Threads |
AVP Mapper EP for Wireless Settings
For more information about the advanced settings for this node type, see "Common Multithreaded EP Advanced Settings".
Content Based Billing Routing EP for Wireless Settings
Diameter CC for Wireless Settings
Table 3-22 describes the basic settings for a Diameter CC node.
Table 3-22 Basic Settings Tab
Receive Port |
Enter the port number that the node monitors for incoming Diameter connections. |
Request Timer |
Enter the duration, in seconds, the node waits for Diameter records to be transferred during an established connection before disconnecting from the remote device. |
Origin host |
Enter the Attribute-Value Pair (AVP) Code 282 to identify the endpoint where the Diameter message originated. |
Origin Realm |
Enter the AVP Code 296 to identify the realm of the endpoint where the Diameter message originated. |
Host IP Address |
Enter the AVP Code 257 to specify the IP address of the Diameter node generating the message. |
Vendor ID |
Enter the AVP Code 266 to specify the IANA-assigned SMI Network Management Private Enterprise Code Vendor ID of the Diameter node generating the message. |
Product Name |
Enter the vendor-assigned name for the product. |
Acct Interim Interval |
Enter the interval time, in seconds, the client uses when generating accounting records. |
For more information about the advanced settings for this node type, see "Common CC Advanced Settings".
Diameter Parser EP for Wireless Settings
For more information about the Advanced Settings for this node type, see "Common Multithreaded EP Advanced Settings".
Duplicate Check EP for Wireless Settings
Table 3-23 describes the basic settings for a Duplicate Check EP node.
Table 3-23 Basic Settings Tab
Number of Duplicate Records Per File |
Enter the number of record processing threads. The minimum value is 1 and the maximum value is 2147483647. |
Use Scratch Directory |
Select to use the node’s scratch directory as the storage location. |
Partition Size |
Select the time interval, HOURLY or DAILY, for creating a partition based on the CDR time stamp. These partitions store duplicate check keys used to identify duplicate records. |
Retention Limit |
Enter how long partitions and duplicate check files are retained before being deleted. |
Number of Partitions in Memory |
Enter the maximum number of latest partitions to be stored in memory. When the limit is reached, the oldest partition is removed from memory. |
Duplicate Records Storage Directory |
The directory where rejected duplicate records are written. |
Duplicate Records Push Time Unit |
Select the time unit, Day, Hour, Min, Sec, or NONE, for pushing/archiving duplicate records from the storage directory. |
Duplicate Records Push Time Period |
Enter the time period for pushing the duplicate records to the storage directory. For example, if the time unit is Day and the time period is 7, duplicate records are pushed to the storage directory every 7 days. |
Enter the maximum number of records stored per duplicate file (set to 2000 by default). The minimum value is 1 and the maximum value is 10000. |
For more information about the Advanced Settings for this node type, see "Common DC Advanced Settings".
Flexible ASCII Collection Cartridge Kit Settings
Table 3-24 describes the basic settings for a Flexible ASCII Collection Cartridge Kit.
Table 3-24 Basic Settings Tab
| Time Unit |
| Prefix |
| Suffix |
| Add Host |
| Username |
| Password |
| Host |
Directory Path |
| File Pattern Mode |
| Prefix |
| Suffix |
| FTP Interval |
| FTP Interval Unit |
Table 3-25 describes the advanced settings for a Flexible ASCII Collection Cartridge Kit.
Table 3-25 Advanced Settings Tab
| Treat file as a single transaction | Select to process the entire input file in a single transaction. If any record within the file fails processing, the entire file is rejected. |
| Prefix |
| Suffix |
| Number of Threads |
| Optimize Reading and Writing of Files | Select to enable multithreading. |
Flexible Routing EP for Wireless Settings
GTP' Data Collection CC for Wireless Settings
Table 3-26 describes the basic settings for a GPRS Tunneling Protocol (GTP) Prime Data Collection CC node.
Table 3-26 Basic Settings Tab
Receive Port |
Enter the UDP port number on which the GTP Data Collection node listens for incoming GTP messages from the network element, such as Serving GPRS support node (SGSN) or Gateway GPRS support node (GGSN). This port must be configured to match the port used by the sending network element. |
Send Port |
Enter the port number the CC node uses to send GTP request to the GPRS support nodes (GSNs). |
Request Timer |
Enter the duration, in seconds, the node waits for an acknowledgment to a GTP request message before re-transmitting the request or considering the connection failed. |
Response Timer |
Enter the duration, in seconds, the node waits to receive a response to a GTP request. If a response is not received within this time, an error may be logged. |
For more information about the Advanced Settings for this node type, see "Common CC Advanced Settings".
GTP Prime Collection CC for Wireless Settings
Table 3-27 describes the basic settings for a GTP Prime Collection CC node.
Table 3-27 Basic Settings Tab
Port |
Enter the port number used to communicate with a database or device. The number must be a positive integer. |
Max Packet Size |
Enter the maximum size for the UDP packet that the CC node accepts. |
Pending Buffer Size |
Enter the maximum size of the buffer used to store pending or incomplete data packets. |
Enable GSN Monitoring |
Select to enable GSN monitoring for this node. |
Send Port |
(Only appears when Enable GSN Monitoring is selected) Enter the port number the CC node uses to send GTP requests to the GSNs. |
Add |
(Only appears when Enable GSN Monitoring is selected) Click to add a GSN device. The IP Address, Port, Request Interval (sec), Response Timer, and Use Node Alive Request fields appear. Enter the appropriate values and then click Submit to add the GTP monitor, or click not to add it. If you add it, it will be displayed in the table. |
IP Address |
(Only appears when Enable GSN Monitoring is selected) Enter the IP address of the GSN device. |
Port |
(Only appears when Enable GSN Monitoring is selected) Enter the GSN port number that sends data to the CC node. |
Request Interval (sec) |
(Only appears when Enable GSN Monitoring is selected) Enter the duration, in seconds, between GTP requests. |
Response Timer |
(Only appears when Enable GSN Monitoring is selected) Enter the duration, in seconds, that the CC node waits for a response from the GSN, before re-sending the original request. |
Use Node Alive Request |
(Only appears when Enable GSN Monitoring is selected) Select to enable the GTP Prime CC node to send a node alive request to the GSN if it has not received any CDRs in a specific interval. You configure this interval in the Request Interval field. If the CC node receives a response from the GSN before the interval expires, it does not generate a warning alarm. (This means that the GSN is functioning correctly and has no CDRs for this specific interval). If the CC node does not receive a response from the GSN before the interval expires, it generates a warning alarm. The CC node clears this warning alarm when it receives CDRs from the GSN or when the GSN responds to the node alive request. |
CGF IP Address |
Enter the Charging Gateway Function (CGF) IP address for sending a GTP request. |
GTP Prime Collection (SGSN06) CC for Wireless Settings
Table 3-28 describes the basic settings for a GTP Prime Collection (SGSN06) CC node.
Table 3-28 Basic Settings Tab
Port |
Enter the port number used to communicate with a database or device. |
Max Packet Size |
Send Port |
(Only appears when Enable GSN Monitoring is selected) Enter the port number the CC node uses to send GTP request to the GSNs. |
Add |
(Only appears when Enable GSN Monitoring is selected) Click to add a new GSN device. The IP Address, Port, Request Interval (sec), Response Timer, and Use Node Alive Request fields appear. Enter the appropriate values and then click Submit to add the GTP monitor, or click Cancel not to add it. If you add it, it will be displayed in the table. |
IP Address |
Port |
(Only appears when Enable GSN Monitoring is selected) Enter the GSN Port number that sends data to the CC node. |
Response Timer |
(Only appears when Enable GSN Monitoring is selected) Enter the duration, in seconds, that the CC node waits for a response from the GSN before re-sending the original request. |
(Only appears when Enable GSN Monitoring is selected) Select to enable the GTP Prime CC node to send a node alive request to the GSN if it has not received any Call Detail Records (CDRs) in a specific interval. You configure this interval in the Request Interval field. If the CC node receives a response from the GSN before the interval expires, it will not generate a warning alarm. (This means that the GSN is functioning correctly and does not have any CDRs for this specific interval). If the CC node does not receive a response from the GSN before the interval expires, it will generate a warning alarm. The CC node will clear this warning alarm when it receives CDRs from the GSN or when the GSN responds to the node alive request. |
CGF IP Address |
Enter the Charging Gateway Function (CGF) IP Address for sending GTP requests. |
Hot Billing Duplicate CDR Removal EP for Wireless Settings
Table 3-29 describes the basic settings for a Hot Billing Duplicate CDR Removal EP node.
Table 3-29 Basic Settings Tab
Flush Time |
Enter the number of state keys to allow before compressing the duplicate key table. |
Set Flush Time From |
Select when to set or reset the flush time for a given duplicate key table entry. Options include first record and last record. |
For more information about the advanced settings for this node type, see "Common DC Advanced Settings".
IPDR Collection Cartridge Kit Settings
Table 3-30 describes the basic settings for an IPDR CC node.
Table 3-30 Basic Settings Tab
| Directory Path | Enter the path to the directory where the input files are located. This should be the directory that the IPDR CC node monitors for new files. |
| Local Filesystem | Select to specify that the input files are located on the local file system of the machine running the IPDR CC node. |
(Only appears when Local Filesystem is selected) Enter the frequency at which this node checks the specified directory for new files to process. |
| Time Unit |
| Data Suffix |
| Add Host |
| Username |
| Password |
| Host |
| Rename Remote Files | Select to rename remote files after they have been successfully transferred and processed. |
IPDRv2 DC Cartridge Kit Settings
Table 3-31 describes the basic settings for an IPDRv2 DC node.
Table 3-31 Basic Settings Tab
Table 3-32 describes the advanced settings for an IPDRv2 DC node.
Table 3-32 Advanced Settings Tab
| Backup NAR Files | Select to enable backup of NAR files. |
(Appears only when Backup NAR Files is selected) Enter the maximum number of days to retain backup NAR files. |
| Enable Output File Archive/Delete | Select to archive or delete the output file. |
| Archive File | Select to archive files. |
| Archive Directory Path | Enter the directory to which the output files should be moved after the Retention Period. |
| Retention Period | Enter the time period for which the files will be retained in the output folder during the Retention Period. (In Days) |
| Delete Files | Select to delete files. |
| Retention Period | Enter the time for which the files will be retained in the output folder during the Retention Period. (In Days) |
| File Name | Enter the output file name. |
| Current File Extension | Enter the extension for current file. |
| Processed File Extension | Enter the extension for processed file. |
| Time Period to Push Output | Enter the time to push output files. |
| Time Unit | Select the unit of time: Days, Hours, Minutes, or Seconds. |
| Max Records per Output File | Enter the max number of records per output file. The minimum value is 1 and the maximum value is 200000. |
| Interval | Enter the minimum silent input time interval to wait before raising an alarm. |
| Interval Unit | Select the interval unit: Minutes, Hours, or Days. |
| Read Timer | Enter the number of seconds between checking for incoming data. The minimum value is 1 and the maximum value is 200000. |
JDBC DC Cartridge Kit Settings
Table 3-33 describes the basic settings for a JDBC DC node.
Table 3-33 Basic Settings Tab
| Batch Size | Enter the maximum batch size that this node accepts. |
| User | Enter the user name for connecting to the database. |
| Password | Enter the password for the database user. |
| Host | Enter the host name or IP address of the host where the Oracle database server is running. |
| Port | Enter the port number used to communicate with a database or device. The number must be a positive integer. |
| SID | Enter the database instance identifier. |
| Service Name | Enter the database service name. |
| Output bad records as NAR | Select to output bad records as NAR. |
MCS 5200 Collection Cartridge for VoIP Settings
Table 3-34 describes the basic settings for an MCS 5200 CC node.
Table 3-34 Basic Settings Tab
| Directory Path | Enter the path to the directory where the input files are located. This should be the directory that the MCS 5200 CC node monitors for new files. |
| Local Filesystem | Select to specify that the input files are located on the local file system of the machine running the MCS 5200 CC node. |
| Time Unit |
| Data Suffix |
| Add Host |
| Username | Enter the user name for authentication with the remote FTP server. |
| Password | Enter the password for the FTP server. |
| Host | Enter the host name or IP address of the remote FTP server. |
| File(s) to Transfer | Enter the absolute path of the directory from where the files should be retrieved by the node. |
| Submit | Click to add a host to the remote file system. |
Multithreaded Programmable Aggregation Processor Cartridge Kit Settings
Table 3-35 describes the basic settings for a Multithreaded Programmable Aggregation Processor Cartridge nodes.
Table 3-35 Basic Settings Tab
| Flush Time |
| Volume Field |
| Max Volume |
| Max volume unit |
Network Accounting Record Collection Cartridge Kit Settings
Table 3-36 describes the basic settings for a Network Account Record CC node.
Table 3-36 Basic Settings Tab
| Local Filesystem | Select to specify that the input files are located on the local file system of the machine running the Network Accounting Record Collection Cartridge Kit. |
| File Parse Delay |
(Only appears when Local Filesystem is selected) Enter the time to wait for new files to process. |
| Time Unit |
(Only appears when Local Filesystem is selected) Select the frequency unit: Seconds, Minutes, or Hours. |
| Directory Path |
(Only appears when Local Filesystem is selected) Enter the local directory containing the files to process. |
| Local File Suffix |
| Add Host |
| Username |
(Only appears when Remote Filesystem (FTP) Enter the user name for authentication with the remote FTP server. |
| Password |
(Only appears when Remote Filesystem (FTP) Enter the password for the FTP server. |
| Host |
(Only appears when Remote Filesystem (FTP) Enter the host name or IP address of the remote FTP server. |
(Only appears when Remote Filesystem (FTP) Enter the absolute path of the directory from where the files should be retrieved by the node. |
| FTP Interval |
(Only appears when Remote Filesystem (FTP) Enter how frequently to check for new files. |
| FTP Interval Unit |
(Only appears when Remote Filesystem (FTP) Select the FTP interval unit: Minutes or Hours. |
(Only appears when Remote Filesystem (FTP) is selected) Select to remove files from the FTP server after transfer. |
Table 3-37 describes the advanced settings for a Network Account Record CC node.
Table 3-37 Advanced Settings Tab
| Expiry Time to Reject Duplicate File Names | (Only appears when Reject Duplicate File Names is selected)
| Treat File as a Single Transaction | Select to process the entire input file as a single transaction. If enabled, all records in the file succeed or fail together. If disabled, individual records can succeed or fail independently. |
| Prefix |
| Suffix |
| Number of Threads |
Network Accounting Record Distribution Cartridge Kit Settings
Table 3-38 describes the basic settings for a Network Accounting Record DC node.
Table 3-38 Basic Settings Tab
Table 3-39 describes the advanced settings for a Network Accounting Record DC node.
Table 3-39 Advanced Settings Tab
| Archive File |
| Delete Files |
| Interval |
| Interval Unit |
| Number of Threads |
Nortel Prepaid in SCP CC for Wireless Settings
Table 3-40 describes the basic settings for a Nortel Prepaid in SCP CC node.
Table 3-40 Basic Settings Tab
Directory Path |
Enter the directory path where the CDRs are located. |
Local Filesystem |
Select this option to access input files stored directly on the local machine using the specified directory path. |
File Parse Delay |
(Only appears when Local Filesystem is selected) Enter the duration to wait before processing a new file. |
Time Unit |
(Only appears when Local Filesystem is selected) Select the unit of measurement, in seconds, minutes, or hours, for the File Parse Delay. |
Local File Suffix |
(Only appears when Local Filesystem is selected) Enter the file extension that allows the node to identify and process data files in the directory. |
Select to access input files stored on a remote FTP server using the specified directory path. |
Add Host |
(Only appears when Remote Filesystem (FTP) is selected) Select the FTP connection type: Secure (SFTP), Regular, or Passive. |
Username |
(Only appears when Remote Filesystem (FTP) is selected) Enter the user name for the FTP server. |
Password |
Host |
(Only appears when Remote Filesystem (FTP) is selected) Enter the FTP server hostname or IP address. Note: Enter a valid IPv4 address in the 255.255.255.255 notation. |
(Only appears when Remote Filesystem (FTP) is selected) Enter the absolute path of the directory from where files should be retrieved. Use an asterisk (*) for a wildcard character. |
FTP Interval |
(Only appears when Remote Filesystem (FTP) is selected) Enter how frequently to check for new files. |
FTP Interval Unit |
(Only appears when Remote Filesystem (FTP) is selected) Select the unit for the FTP interval: Minutes or Hours. |
Table 3-41 describes the advanced settings for a Nortel Prepaid in SCP CC node.
Table 3-41 Advanced Settings Tab
Enter the maximum number of records to add to an output file. Once the limit is reached, a new file is created. |
Enter the duration, in seconds, the cartridge waits before writing an idle record. The minimum value is 1 and the maximum value is 3600. |
Enable Statistics |
Enable this option to collect processing statistics for the Nortel collection cartridge. This is useful for monitoring performance and troubleshooting. |
Logging Level |
Max Log File Size |
OCECE DC for Wireless Settings
Table 3-42 describes the basic settings for an OCECE DC node.
Table 3-42 Basic Settings Tab
| Duplicate request directory | Enter a valid duplicate request file directory. |
| Success response directory | Enter a valid success response file directory. |
| Suspense directory | Enter a valid suspense file directory. |
| No-response directory | Enter a valid no-response file directory |
| Delayed response directory | Enter a valid delayed response file directory. |
| Duplicate response directory | Enter a valid duplicate response file directory. |
Table 3-43 describes the advanced settings for an OCECE DC node.
Table 3-43 Advanced Settings Tab
Batch Size |
Enter the number of records that will be submitted by Offline Mediation Controller to ECE before waiting for responses. Larger batch sizes may help improve throughput. and may require the Waiting time per batch to be increased to permit all responses to be received from ECE before submitting the next batch. |
Max records per suspense/success file |
Enter the maximum number of records per file that should be written in the OMC_home/ocomc/suspense or the OMC_home/ocomc/success directory. The minimum value is 1 and the maximum value is 50000. |
Waiting time per batch |
Enter the duration, in milliseconds, the node waits for the batch to be processed. The minimum value is 1 and the maximum value is 1800000. |
Timeout for Archiving NAR files |
Enter the frequency at which partially filled no-response, duplicate, and bad NAR records should be closed and moved to their corresponding destination locations. This permits partially filled files of failed NARs to be closed and moved (the max file size is controlled by the OCECESuspenseBatchSize configuration or, by default, will be 10000 records). |
Response Timeout |
Enter the frequency with which the node should check for requests that have not received a response from ECE. The records are stored in memory until there is a response. Any record that has been waiting for a response for more than the "Response Timeout" will be written to the no-response NAR file. Note that as this parameter controls both the timeout and the frequency with which this check is executed, a no-response would be detected at latest two times the value of this timeout. |
Request Throttling |
Select in cases where the ECE server may not be responding as quickly as normal; it can be helpful to pause submission of more work for a short time. When enabled, the number of outstanding requests will be checked after each batch. If the number of outstanding requests is larger than the 'High-Water Mark', processing of the record stream will be halted until the number of outstanding requests drops below the 'Low-Water Mark'. |
| Low-Water Mark |
(Only appears when Request Throttling is selected) Enter the minimum number of outstanding requests allowed before processing resumes. When the number of outstanding requests drops below this value, the node continues processing. |
| High-Water Mark |
(Only appears when Request Throttling is selected) Enter the maximum number of outstanding requests allowed. When the number of outstanding requests exceeds this value, processing is paused until the count falls below the Low-Water Mark. |
Select to generate a NAR for the bad records. |
Log success records |
Select to enable writing the records successfully processed by the ECE to a file in the OMC_home/ocomc/success directory. When enabled, the OCECE DC node logs successfully processed ECE records to the success file. This feature is particularly useful when the advice of charge notification in ECE is configured to include events such as in-session notifications on the usage response message (PIGGYBACK). For more details on configuring advice of charge notifications, consult the ECE documentation. |
Submission-throttling milliseconds |
Enter the amount of time (in milliseconds) that the OCECE DC Node will pause before submitting new requests to ECE. Whilst Request Throttling controls submission at a batch level, the micro-throttling feature permits throttling of submission within a batch of records as a flow-control mechanism. If, at any time, the number of outstanding requests (those sent to the ECE server but for which responses have not been received) exceeds the Max outstanding requests before throttling configuration, the ECE DC Node will add this pause before submitting new requests to ECE. |
Max outstanding requests before throttling |
Enter the maximum number of outstanding requests that will be permitted before the ECE DC Node begins pausing the submission of requests to ECE. See "Submission-throttling milliseconds," which defines how long each pause will be. Once the number of outstanding requests drops below this threshold, records will be submitted normally. |
Max MSCC batch size |
Enter the number of input records in each batch that are for the same user identity. In cases where there are multiple input records in each batch that are for the same user identity, grouping those records into a single request for the ECE server permits them to be processed together. This can optimize throughput when a large proportion of records are for a small number of distinct user identities. Typical values would be in the range of 1 to 10. There is generally little additional benefit from using larger batch sizes (and none when all user identities are distinct). |
Backup NAR Files |
Enable Statistics |
Logging Level |
Max Log File Size |
Interval |
Interval Unit |
| Read Timer |
Oracle CDR Format File Collection Cartridge Kit Settings
Table 3-44 describes the basic settings for an Oracle CDR Format File CC Settings.
Table 3-44 Basic Settings Tab
| Time Unit |
(Only appears when Local Filesystem is selected) Select the unit: Seconds, Minutes, and Hours. |
| Prefix |
| Suffix |
(Only appears when Use Prefix and Suffix is selected) Enter the file name suffix of the input files to process. |
(Only appears when Use Regular Expression is selected) Enter the regular expression that will be used to match the names of input files in the specified directory. |
| Remote Filesystem | Select to indicate that the input files are located on a remote file system and are accessed using FTP. |
| Add Host |
(Only appears when Remote Filesystem is selected) Click to add a host to the remote filesystem. |
(Only appears when Remote Filesystem is selected) Select the FTP connection type: Secure SFTP, Regular FTP, or Passive FTP. |
| Username |
| Password |
| Host |
Directory Path |
| Submit | Click to add a remote file system. |
| FTP Interval | Enter the interval of time between attempts to transfer files to the remote FTP server. |
| FTP Interval Unit | Select the duration (Minutes or Hours) for the FTP Interval field. |
| Interrupt Timer Delay | Enter the delay time to implement with interrupts and timers. |
| Interrupt Timer Delay Unit | Select the duration (Minutes or Hours) for the Interrupt Timer Delay field. |
Table 3-45 describes the advanced settings for an Oracle CDR Format File CC Settings.
Table 3-45 Advanced Settings Tab
| Prefix |
| Suffix |
| Schema File | Select the schema file that is used to parse the Oracle CDR format data files. The Oracle CDR Format CC node uses the schema information in a schema file to parse the CDR files conforming to the Oracle CDR format into NARs. You can configure a custom schema file to accommodate the custom data. |
| Number of Threads |
Partial CDR Completion Cartridge AP for Wireless Settings
Table 3-46 describes the basic settings for a Partial CDR Completion Cartridge node.
Table 3-46 Basic Settings Tab
| Flush Time |
| Volume Field |
| Max Volume |
| Max volume unit |
RADIUS CC for Wireless Settings
Table 3-47 describes the basic settings for a RADIUS CC node.
Table 3-47 Basic Settings Tab
RADIUS Request Port |
Enter the port number on which RADIUS server is listening for requests. |
Idle Record Write Time |
Enter the duration, in seconds, the CC node waits before writing an idle record. |
Add Client |
Click to add a RADIUS client. You must add at least one client. The IP Address and Secret fields appear. Enter the appropriate values and then click Submit to add the client, or click Cancel not to add it. If you add it, it will be displayed in the table. |
IP Address |
Enter the IPv4 address for the client. |
Secret |
Enter the shared secret key used to encrypt communication between the RADIUS client and the node. |
RADIUS DC for Wireless Settings
Table 3-48 describes the basic settings for a RADIUS DC node.
Table 3-48 Basic Settings Tab
| RADIUS Response Port | Enter the UDP port number on which the RADIUS DC node listens for responses from the RADIUS server. The default port is 1814. Note that the default port for RADIUS accounting is 1813. |
| Shared Secret | Enter the secret key that is shared between the RADIUS client and the RADIUS server. This secret is used to encrypt passwords and ensure secure communication between the client and server. This key should be known by both the RADIUS client and server. |
| Retransmit Interval | Enter the time interval (in seconds) after which the RADIUS client retransmits a request if it does not receive a response from the server. The default value is 5 seconds. |
| Expiration Time | Enter the duration (in seconds) after which a RADIUS request is considered to have timed out if no response is received. The default value is 60 seconds. |
| RADIUS Server | Enter the IP address or host name of the RADIUS server. |
| RADIUS Request Port | Enter the UDP port number on which the RADIUS server is listening for authentication requests. The default port is 1813. |
RADIUS CC for IP Settings
Table 3-49 describes the basic settings for a RADIUS CC node.
Table 3-49 Basic Settings Tab
Add Client |
IP Address |
Secret |
RADIUS DC for IP Settings
Table 3-50 describes the basic settings for a RADIUS DC node.
Table 3-50 Basic Settings Tab
RADIUS DC Cartridge Kit Settings
Table 3-51 describes the basic settings for a RADIUS DC Cartridge Kit.
Table 3-51 Basic Settings Tab
| RADIUS Response Port | Enter the port number that listens for incoming RADIUS response packets. |
| Shared Secret | Enter the shared secret between the RADIUS Client and Server. |
| Retransmit Interval | Enter the number of seconds between retransmit attempts. |
| Expiration Time | Enter the number of seconds after which the request expires. |
| RADIUS Server | Enter the IP address of the RADIUS server. |
| RADIUS Request Port | Enter the port number on which the RADIUS server is listening for requests. |
Real Time ASCII File Collection Cartridge Kit Settings
Table 3-52 Basic Settings Tab
| Frequency to Check for New Files | Enter the frequency at which this node checks the specified directory for new files. |
| Time Unit | Select the time unit for the frequency. Options are Seconds, Minutes, or Hours. |
| Directory Path | Enter the path to the directory where the input files are located. This is the directory that the node monitors for new files. |
| Closed File Pattern for Matching | Specifies the method used to match completed files in the directory. Options are Use Prefix and Suffix or Use Regular Expression. |
| Prefix (Closed File) |
(Only appears when Use Prefix and Suffix is selected) Enter the file name prefix of the closed files to process. |
| Suffix (Closed File) |
(Only appears when Use Prefix and Suffix is selected) Enter the file name suffix of the closed files to process. |
| Regular Expression (Closed File) |
(Only appears when Use Regular Expression is selected) Enter the regular expression that will be used to match the names of closed files in the directory. |
| Active File Pattern for Matching | Specifies the method used to match active (in-progress) files in the directory. Options are Use Prefix and Suffix, or Use Regular Expression. |
| Prefix (Active File) |
| Suffix (Active File) |
| Regular Expression (Active File) |
(Only appears when Use Regular Expression is selected) Enter the regular expression that will be used to match the names of active files in the directory. |
| Maximum Time for Awaiting Data | Enter the maximum time to wait for data in an active file before processing begins. |
| Time Unit | Select the time unit for the maximum wait period. |
Record Enhancement (LDAP) EP Cartridge Kit Settings
Table 3-53 describes the basic settings for a Record Enhancement (LDAP) EP node.
Table 3-53 Basic Settings Tab
| Lookup File |
Enter the path to the lookup file used to store the data retrieved from the LDAP server. The default value is UDC_home/datafiles/nodeID/LDAP.lookup. |
| Lookup Table Name |
Specifies the name of the lookup table within the lookup file. The default value is LDAP. |
| Continue on invalid file format |
Select to instruct the system to continue processing even if the lookup file has an invalid format. If this option is not selected, processing will halt if an invalid file format is encountered. |
| Host Name |
Enter the host name or IP address of the LDAP server. |
| Port Number |
Enter the port number for connecting to the LDAP server. The default port is 389. |
| User Name |
Enter the user name for authentication with the LDAP server. |
| Password |
Enter the password for authentication with the LDAP server. |
| Directory Path |
Enter the base distinguished name (DN) for the LDAP search. This is the starting point in the LDAP directory tree for the search. |
| Update Frequency |
Enter the interval (in seconds) at which the node retrieves data from the LDAP server. The default value is 60 minutes. |
| Search Filter |
Enter the LDAP search filter used to retrieve specific entries from the LDAP server. |
| Key Attribute Id |
Enter the attribute in the LDAP entry to use as the key for the lookup. The default is uid. |
| Key Value Separator |
Enter the character used to separate the key (the Key Attribute Id) from its corresponding value in the lookup data. |
| Sub Value Separator |
Enter the character used to separate multiple values associated with the same key in the lookup data. |
Record Enhancement (Local File) EP Cartridge Kit Settings
Table 3-54 describes the basic settings for a Record Enhancement (Local File) EP node type.
Table 3-54 Basic Settings Tab
| Lookup File | Enter the file path to the lookup file. This file contains data used to enrich or transform subscriber state information. |
| Lookup Table Name | Enter the name of the specific table or data structure within the lookup file to be used for the lookup operation. This allows you to select a particular dataset within a larger lookup file. |
| Continue on invalid file format | Select to instruct the system to continue processing even if the lookup file has an invalid format. If this option is not selected, processing will halt if an invalid file format is encountered. |
Record Enhancement (Remote File) EP Cartridge Kit Settings
Table 3-55 describes the basic settings for a Record Enhancement (Remote File) EP node.
Table 3-55 Basic Settings Tab
| IP Address | Enter the IP address of the FTP server. |
| Username | Enter the user name used to access the FTP server. |
| Password | Enter the password used to access the FTP server. |
| Remote File | Enter the file location of the FTP server. |
| FTP Interval | Enter the remote file location of the FTP server. |
| Get Error File | Select this option to enable storing error files. |
| Error Directory | Enter the absolute path to the directory where you want to store error files. |
Record Enhancement Charging EP for Wireless Settings
Record Filter EP for Wireless Settings
Table 3-56 describes the basic settings for a Record Filter EP node.
Table 3-56 Basic Settings Tab
API NI Filter Value |
Enter an Access Point Name (APN) Network Identifier (NI) to filter records, allowing processing of records associated with a specific network. Click the plus-sign icon to save the value. You can enter more than one value. |
APN OI Filter Value |
Enter an Access Point Name (APN) Operator Identifier (OI) to filter records, selecting records related to a specific operator's network. Click the plus-sign icon to save the value. You can enter more than one value. |
Service Center Filter Value |
Enter a Service Center (SC) address to filter records, processing records only if they went through a specific service center. Click the plus-sign icon to save the value. You can enter more than one value. |
Record Type |
Select the checkboxes in this section to filter records based on the following options:
Optional Fields |
Table 3-57 describes the advanced settings for a Record Filter EP node.
Table 3-57 Advanced Settings Tab
Backup NAR Files |
Select to enable back up of all NAR files. |
(Only appears when Backup NAR Files is selected) Enter the length of time, in days, to retain processed NAR files or backup NAR files. Files older than this period are automatically deleted. |
Enter the maximum number of records to add to an output file. After the maximum is reached, Offline Mediation Designer creates a new output file. |
Enable Statistics |
Logging Level |
Max Log File Size |
Select to monitor the input stream for potential issues such as stalled data flow. |
Interval |
Interval Unit |
Number of Threads |
Read Timer |
Record Grouping AP for Wireless Settings
Table 3-58 describes the basic settings for a Record Grouping AP node.
Table 3-58 Basic Settings Tab
| Flush Time | Enter the duration, in seconds, before an aggregated NAR is flushed. |
| Compression Threshold | Enter the number of state keys to allow before compressing the duplicate key table. |
| Set Flush Time From | Select when to set or reset the flush time for a given duplicate key table entry. Possible options are First Record and Last Record. |
| MCC and MNC (IMSI) | Enter the Mobile Country Code (MCC) and Mobile Network Code (MNC) digits of the International Mobile Subscriber Identity (IMSI) (5 or 6 digits). |
Record Processing EP Cartridge Kit Settings
Recycle AQ Job Collection Cartridge Kit Settings
Table 3-59 describes the basic settings for an AQ Job CC node.
Table 3-59 Basic Settings Tab
| Batch Size | Enter the maximum number of records to process in a single batch. The default is 500. |
| User | Enter the user name for connecting to the Oracle database. |
| Password | Enter the password for connecting to the Oracle database. |
| Host | Enter the host name or IP address of the Oracle database server. |
| Port | Enter the port number used to connect to the Oracle database. The default port is 1521. |
| SID | Enter the Oracle System Identifier (SID) for the database instance. |
| Service Name | Enter the Oracle service name of the database. |
| Queue | Enter the queue name from which this node dequeues messages. |
| Event | Enter the event name that triggers the recycle process. |
| Thread sleep time in seconds | Enter the duration, in seconds, that the thread will sleep. |
| Enable Polling | Select to poll the Oracle AQ queue. |
| File Parse Delay |
(Only appears when Enable Polling is selected) Enter how often to poll the queue for files. |
| Polling interval unit |
(Only appears when Enable Polling is selected) Select the delay unit: Day, Hour, or Minute. |
Table 3-60 describes the advanced settings for an AQ Job CC node.
Table 3-60 Advanced Settings Tab
| Field | Description |
| Enable Statistics | Enable this option to collect processing statistics for the Record Filter EP node. This is useful for monitoring performance and troubleshooting. |
Recycle EP Cartridge Kit Settings
Table 3-61 describes the basic settings for a Recycle EP Cartridge node.
Table 3-61 Basic Settings Tab
| Batch Size | Enter the number of records per transaction. |
| Port | Enter the port number on which the listener is running. |
| Category | Enter the group name to which the category belongs to. The value should match PIPELINE_CATEGORY in suspended record. |
| SQL Header File | Enter the absolute path to the file containing the SQL statement for retrieving the header information. |
| SQL Detail File | Enter the absolute path to the file containing the SQL statement for retrieving the detailed information. |
Table 3-62 describes the advanced settings for a Recycle EP Cartridge node.
Table 3-62 Advanced Settings Tab
| Backup NAR Files | Select to enable a back up of all NAR files. |
| File Retention Period |
| Interval |
| Interval Unit |
| Number of Threads |
Sequencing EP Cartridge Kit Settings
Table 3-63 describes the basic settings for a Sequencing EP Cartridge node.
Table 3-63 Basic Settings Tab
| Expiry Interval (minutes) | Enter the minutes to wait for out of sequence records. (1 to 1440) |
| Log Duplicate Entries | Select to log duplicate entries. |
| Missing Record Monitoring | Select to enable missing record monitoring. |
(Only appears when Missing Record Monitoring is selected) Select the severity of the alarm or choose for logging: Informational, Warning, Minor, Major, or Critical. |
Session Aggregation AP for Wireless Settings
Table 3-64 describes the basic settings for a Session Aggregation AP node.
Table 3-64 Basic Settings Tab
| Flush Time |
| Volume Field |
| Max Volume |
| Max volume unit |
Session Aggregation for IMS AP for Wireless Settings
Table 3-65 describes the basic settings for a Session Aggregation for IMS EP node.
Table 3-65 Basic Settings Tab
| Flush Time |
Enter the interval, in seconds, at which the node sends aggregated NARs to the next node in the chain. Note: The recommended configuration for the Flush Time is twice the configured Expiry Interval on the Session Sequencing EP. In addition, the Flush Time value should be higher than the configured Interim Accounting value on the CSCF to avoid premature generation of CDRs. |
| Compression Threshold | Enter the number of stale records the node allows before compressing the aggregation table. |
| Flush Time | Enter the time, in minutes, the node waits before generating a partial CDR. |
Table 3-66 describes the basic settings for a Session Sequencing EP node.
Table 3-66 Basic Settings Tab
Enter the duration, in minutes, that the node will hold on to out-of-sequence records before either sequencing them or flushing them. |
Select to log duplicate record entries. |
Select to monitor for missing records. |
(Only appears when Missing Record Monitoring is selected) Select the severity level to assign to missing record events: Informational (Log only), Warning, Minor, Major, Critical. |
Subscriber State Management EP for Wireless Settings
Table 3-67 describes the basic settings for a Subscriber State Management EP node.
Table 3-67 Basic Settings Tab
Lookup File |
Enter the path to the lookup file. This file contains data used to enrich or transform subscriber state information. |
Lookup Table Name |
Enter the name of the specific table or data structure within the lookup file to use for the lookup operation. This allows you to select a particular dataset within a larger lookup file. |
Select to continue processing even if the lookup file has an invalid format. If this option is not selected, processing will halt if an invalid file format is encountered. |
Suspense Distribution Cartridge Kit Settings
Table 3-68 describes the basic settings for a Suspense DC node.
Table 3-68 Basic Settings Tab
| Default Source Node | Enter the name of the default source node for this cartridge. This node name is included in the generated Event Data Records (EDR) when no other source node is specified. |
| Category | Enter the category identifier that defines the type of records being processed. The category is used for classification and routing. |
| Suspended Batch Mode | Select whether suspended records are processed individually or in batch mode. When disabled, records are handled one at a time. |
| EDR Field Mapping Name | Enter the field mapping name or identifier used to map incoming record fields into the EDR. |
| Create Event Type | Enter the event type to be assigned when a new suspended usage record is created in ECE. |
| Update Event Type |
Enter the event type to be assigned when an existing suspended usage record is updated in ECE. |
Table 3-69 describes the advanced settings for a Suspense DC node.
Table 3-69 Advanced Settings Tab
| Backup NAR Files | Select to back up all NAR files. |
(This setting is available separately for both Create output and Update output, allowing you to configure independent backup and cleanup policies for newly created suspended events (Create output) and for updates to existing suspended events (Update output).) Select to manage processed output files by either archiving them to a specified directory or permanently deleting them after processing. When enabled, you can configure the archive directory path and the retention period (in days) if archiving is chosen, or delete files directly if deletion is selected. |
| Archive File |
| Retention Period (in Days) |
| Delete Files |
| Output Directory |
(Available separately for both Create File Output and Update File Output) Enter the directory in which to store output files. |
| File Name |
(Available separately for both Create File Output and Update File Output) Enter the name to prepend to the output file. |
(Available separately for both Create File Output and Update File Output) Enter the file name extension for files that have not been processed yet. |
| Completed File Extension |
(Available separately for both Create File Output and Update File Output) Enter the file name extension for processed files. |
(Available separately for both Create File Output and Update File Output) Enter the time period before pushing output files. |
| Time Unit |
(Available separately for both Create File Output and Update File Output) Select the unit of time in days, hours, minutes, or seconds. |
(Available separately for both Create File Output and Update File Output) Enter the maximum number of records in each output file. The minimum value is 1 and the maximum value is 200000. |
| Output the tags even if the string field has no value? | Select to output the tags associated with a field, even if the string field itself is empty. |
| Replace empty string field with | Enter the value that should be replaced in the output if a string field in the input record is empty. |
Enable Statistics |
Select to collect processing statistics for this node. The statistics are useful for monitoring performance and troubleshooting. |
Logging Level |
Select whether to create a log file. The possible values are On or Off. |
Max Log File Size |
Enter the maximum size, in bytes, for the log file. After the maximum is reached, the node creates a new log file. |
Input Stream Monitoring |
Select to monitor the input stream for potential issues such as a stalled data flow. |
Select to enable batch processing of read and write operations. |
Read Timer |
Enter the duration, in seconds, between checking for incoming data. |
Syslog Collection Cartridge for VoIP Settings
Table 3-70 describes the basic settings for a Syslog CC node.
Table 3-70 Basic Settings Tab
| Time Unit |
| Prefix |
| Suffix |
| Add Host |
| Username |
| Password |
| Host |
Directory Path |
| File Pattern Mode |
| Prefix |
| Suffix |
Table 3-71 describes the advanced settings for an Syslog CC node.
Table 3-71 Advanced Settings Tab
| Prefix |
| Suffix |
| Enable Statistics | Select to collect processing statistics for this node. This is useful for monitoring performance and troubleshooting. |
| Logging Level | Select whether to create a log file. The possible values are On or Off. |
| Max Log File Size | Enter the maximum size, in bytes, for the log file. After the maximum is reached, the node creates a new log file. |
| Number of Threads |
(Only appears when Use Multiple Threads is selected) Enter the number of threads to use for processing. The minimum value is 1 and the maximum value is 2147483647. |
| Produce Output Files in the Order they are Read and Processed |
(Only appears when Use Multiple Threads is selected) Select to ensure that the output files are produced in the same order as the input files are read and processed. |
| Optimize Reading and Writing of Files | Select to enable batch processing of read and write operations. |
XML DC for Wireless Settings
Table 3-72 describes the basic settings for an XML DC node.
Table 3-72 Basic Settings Tab
| Send Output Using FTP | Select to send the output to a remote system using FTP. When selected, you can enter the FTP information for your environment. See "Common FTP Settings" for more information on these settings. |
Table 3-73 describes the advanced settings for an XML DC node.
Table 3-73 Advanced Settings Tab
| File-level Transactions – Input Records Succeed or Fail Together | Select to process the entire input file in a single transaction. If any record within the file fails processing, the entire file is rejected. |
(Only appears when Backup NAR Files is selected) Enter the maximum number of days to retain backup NAR files. |
| Enable Output File Archive/Delete | Select to archive or delete the output files. |
| Archive File |
| Delete Files |
| Output Directory Path | Enter the directory in which to store output files. |
| File Name | Enter the name to prepend to the output file. |
| Current File Extension | Enter the file name extension for files that have not been processed yet. |
| Processed File Extension | Enter the file name extension for processed files. |
| Max Records per Output File | Enter the maximum number of records in each output file. The minimum value is 1 and the maximum value is 200000. |
| Enable Statistics | Select to add statistics to the log file. |
| Input Stream Monitoring | Select to monitor the input stream. |
| Interval |
| Interval Unit |
| Number of Threads |
| Read Timer | Enter the number of seconds between checking for incoming data. (Min=1, Max=3600) |
XML Distribution Cartridge Kit Settings
Table 3-74 describes the basic settings for an XML Distribution Cartridge node.
Table 3-74 Basic Settings Tab
Table 3-75 describes the advanced settings for an XML Distribution Cartridge node.
Table 3-75 Advanced Settings Tab
| Archive File |
| Delete Files |
| Interval |
| Interval Unit |
| Number of Threads |
Zero Rating EP for Wireless Settings
Common FTP Settings
Table 3-76 describes all the common FTP settings. These settings only appear when Send Output Using FTP is selected.
Table 3-76 Common FTP Settings
Select your remote host access. The two options available are Secure (SFTP) or Regular. |
Remote Directory Path |
Enter your remote FTP directory path. |
User ID |
Enter your remote FTP login name. |
Password |
Enter your remote FTP password. |
Host |
Enter the host name of your remote FTP host. |
Port |
Enter the remote FTP port number. The standard port is 21. |
FTP Interval |
Interval Unit |
Select the units for the FTP interval: Minutes or Hours. |
Transferred File Extension |
Enter the extension to append to the transfer file. |
Table 3-77 describes the common advanced settings for all CC nodes.
Table 3-77 Common CC Advanced Settings
Enter the maximum number of records to add to an output file. After the limit is reached, the system creates a new file. |
Enable Statistics |
Select to collect processing statistics for the RADIUS CC node. This is useful for monitoring performance and troubleshooting. |
Logging Level |
Select On to create a log file, or Off not to create a log file. |
Max Log File Size |
Enter the maximum size (in bytes) for the log file. When the log file reaches this limit, the node closes the current log file and opens a new one to prevent excessive disk usage. |
Optimize reading and Writing of Files |
Common EP and AP Advanced Settings
Table 3-78 describes common advanced settings for EP and AP nodes.
Table 3-78 Common EP and AP Advanced Settings
Backup NAR Files |
(Only appears when Backup NAR Files is selected) Enter the length of time, in days, to retain processed NAR files and backup NAR files. Files older than this are automatically deleted. |
Enable Statistics |
Select to collect processing statistics for this node. The statistics are useful for monitoring performance and for troubleshooting. |
Logging Level |
Select whether to create a log file. The possible values are On and Off. |
Max Log File Size |
Enter the maximum size, in bytes, for the log file. When the log file reaches this limit, the node closes the current log file and opens a new one to prevent excessive disk usage. |
Interval |
(Only appears when Input Stream Monitoring is selected) Enter the interval at which the input stream is checked for activity. |
Interval Unit |
(Only appears when Input Stream Monitoring is selected) Select the duration in days, hours, or minutes. |
Read Timer |
Common Threaded EP and AP Advanced Settings
Table 3-79 describes the common advanced settings for all threaded EP and AP nodes.
Table 3-79 Common Threaded EP and AP Advanced Settings
Backup NAR Files |
(Only appears when Backup NAR Files is selected) Enter the length of time, in days, to retain processed NAR files and backup NAR files. Files older than this period are automatically deleted. |
Enable Statistics |
Logging Level |
Max Log File Size |
Interval |
Interval Unit |
Read Timer |
Enter the duration, in seconds, between checks for incoming data. |
Table 3-80 describes the common advanced settings for all multithreaded EP nodes.
Table 3-80 Common Multithreaded EP Advanced Settings
File-level Transactions - Input Records Succeed or Fail Together |
Backup NAR Files |
Max NARs per Output File |
Enter the maximum number of records to add to an output file. After the maximum is reached, the node creates a new output file. |
Write Output After Idle Period |
Enter the duration, in seconds, the node waits before writing an idle record. The minimum value is 1 and the maximum value is 3600. |
Enable Statistics |
Logging Level |
Max Log File Size |
Enter the maximum size, in bytes, for the log file. When the log file reaches this limit, the node closes the current log file and opens a new one to prevent excessive disk usage. After the maximum is reached, the node creates a new log file. |
Interval |
Interval Unit |
Number of Threads |
Read Timer |
Table 3-81 Common DC Advanced Settings
Backup NAR Files |
Enable Statistics |
Logging Level |
Max Log File Size |
Interval |
Interval Unit |
Read Timer |
Rule Settings Reference
View detailed descriptions about the fields and options in the following dialog boxes:
Rules Editor Page
Use the Rules Editor dialog box to add a Node Programming Language (NPL) rules file to a node.
Table 3-82 describes the fields in the Rules Editor dialog box.
Table 3-82 Rules Editor Dialog Box
Filename |
Enter a unique name for the node's NPL rules file. |
Click to enter a line into the NPL rules file. Press the Enter key to add another line. |
Click to load the contents of a sample NPL rules file or another node's NPL rules file into the Rules Editor. You can use this file as a starting place for creating an NPL rules file for the node. |
Click to compile the lines in the NPL rules file. The Rules editor specifies whether the compilation succeeds or fails. |
Click to expand the window to a full screen. Press the Escape key to return the window to its original size. |
Save |
Click to save your changes to the NPL rules file. |
Load Rules Dialog Box
Use the Load Rules dialog box to load the contents from a sample or existing NPL rules file into the Rules editor.
Table 3-83 describes the fields in the Load Rules dialog box.
Table 3-83 Load Rules Dialog Box
Sample rules |
Select to load the contents from a specified sample NPL rules file. |
Reuse rules from a similar node |
Select to load the contents from another node's NPL rules file. |
Select the name of the sample or existing NPL rules file to load. |
Load |
Click to load the contents from an NPL rules file into the Rules editor. |
