2 Wireless Output Formats
This chapter contains call detail record (CDR) field descriptions and sample Wireless distribution cartridge (DC) output formats for the GGSN/SGSN node chain in Offline Mediation Controller.
Topics in this document:
CDR Fields
The following sections show all call detail record (CDR) fields that can be contained in a DC output file produced by Offline Mediation Controller for the Wireless service solution, following the 3GPP Technical Specification 32.015 v3.2.0 requirements.
ASN.1 Record Fields for 3GPP 32.015 v3.2.0
This section shows ASN.1 record fields for 3GPP 32.015 v3.2.0.
GGSN CDR
This section shows the GGSN record output in ASN.1 format for both ShastaTM and ContivityR GGSNs.
GGSNPDPRecord : := SET
recordType
networkInitiation
servedIMSI
ggsnAddress
chargingID
sgsnAddress
accessPointNameNI
pdpType
servedPDPAddress
dynamicAddressFlag
listOfTrafficVolumes
recordOpeningTime
duration
causeForRecClosing
diagnostics
recordSequenceNumber
nodeID
recordExtensions
localSequenceNumber
apnSelectionMode
servedMSISDN
ChargingCharacteristics
Table 2-1 shows the GGSN record output in ASN.1 format for both Shasta and Contivity GGSNs.
Table 2-1 ASN.1 Record Fields
| Field | Description |
recordType |
[0] CallEventRecordType, |
networkInitiation |
[1] NetworkInitiatedPDPContext OPTIONAL |
servedIMSI |
[3] IMSI, |
ggsnAddress |
[4] SNAddress, |
chargingID |
[5] ChargingID, |
sgsnAddress |
[6] SEQUENCE OF GSNAddress, |
accessPointNameNI |
[7] AccessPointNameNI, |
pdpType |
[8] PDPType, |
servedPDPAddress |
[9] PDPAddress, |
dynamicAddressFlag |
[11] DynamicAddressFlag OPTIONAL, |
listOfTrafficVolumes |
[12] SEQUENCE OF ChangeOfCharCondition, |
recordOpeningTime |
[13] TimeStamp, |
duration |
[14] CallDuration, |
causeForRecClosing |
[15] CauseForRecClosing, |
diagnostics |
[16] Diagnostics OPTIONAL, |
recordSequenceNumber |
[17] INTEGER OPTIONAL, |
nodeID |
[18] NodeID OPTIONAL, |
recordExtensions |
[19] ManagementExtensions OPTIONAL, |
localSequenceNumber |
[20] LocalSequenceNumber OPTIONAL, |
apnSelectionMode |
[21] APNSelectionMode, |
servedMSISDN |
[22] MSISDN OPTIONAL, |
ChargingCharacteristics |
[23] ChargingCharacteristics OPTIONAL, |
SGSN CDR Outputs
This section shows the SGSN record outputs in ASN.1 format.
S-CDR
The following is the format of the S-CDR with the appropriate ASN.1 types.
SGSNPDPRecord : := SET
recordType
networkInitiation
servedIMSI
servedIMEI
sgsnAddress
msNetworkCapability
routingArea
locationAreaCode
cellIdentity
chargingID
ggsnAddressUsed
accessPointNameNI
pdpType
servedPDPAddress
recordOpeningTime
duration
sgsnChange
causeForRecClosing
diagnostics
nodeID
recordExtensions
localSequenceNumber
apnSelectionMode
accessPointNameOI
servedMSISDN
systemType
cAMELInformationPDP
rNCUnsentDownlinkVolume
Table 2-2 shows the SGSN record outputs in ASN.1 format.
Table 2-2 SGSN Record Outputs Fields
recordType |
networkInitiation |
servedIMSI |
[3] IMSI, |
servedIMEI |
[4] IMEI OPTIONAL, |
sgsnAddress |
[5] GSNAddress, |
msNetworkCapability |
[6] MSNetworkCapability OPTIONAL, |
routingArea |
[7] RoutingAreaCode OPTIONAL, |
locationAreaCode |
[8] LocationAreaCode OPTIONAL, |
cellIdentity |
[9] CellId OPTIONAL, |
chargingID |
[10] ChargingID, |
ggsnAddressUsed |
[11] GSNAddress, |
accessPointNameNI |
[12] AccessPointNameNI, |
pdpType |
[13] PDPType |
servedPDPAddress |
[14] PDPAddress, |
[15] SEQUENCE OF ChangeOfCharCondition, |
recordOpeningTime |
[16] TimeStamp, |
duration |
[17] CallDuration, |
sgsnChange |
[18] SGSNChange OPTIONAL, |
[19] CauseForRecClosing, |
diagnostics |
[20] Diagnostics OPTIONAL, |
[21] INTEGER OPTIONAL, |
nodeID |
[22] NodeID OPTIONAL, |
recordExtensions |
[23] ManagementExtensions OPTIONAL, |
[24] LocalSequenceNumber OPTIONAL, |
apnSelectionMode |
[25] APNSelectionMode OPTIONAL, |
accessPointNameOI |
[26] AccessPointNameOI, |
servedMSISDN |
[27] MSISDN OPTIONAL, |
[28] ChargingCharacteristics OPTIONAL, |
systemType |
[29] SystemType OPTIONAL, |
cAMELInformationPDP |
[30] CAMELInformationPDP OPTIONAL, |
rNCUnsentDownlinkVolume |
[31] DataVolumeGPRS OPTIONAL, |
The G-CDR/S-CDR change of location container contains the following fields:
ChangeOfCharCondition ::= SEQUENCE
qosRequested
qosNegotiated
dataVolumeGPRSUplink
dataVolumeGPRSDownlink
changeCondition
changeTime
Table 2-3 shows the fields for G-CDR/S-CDR change of location container.
Table 2-3 G-CDR/S-CDR Fields
qosRequested |
[1] QoSInformation OPTIONAL |
qosNegotiated |
[2] QoSInformation OPTIONAL, |
dataVolumeGPRSUplink |
[3] DataVolumeGPRS, |
dataVolumeGPRSDownlink |
[4] DataVolumeGPRS, |
changeCondition |
[5] ChangeCondition, |
changeTime |
[6] TimeStamp |
M-CDR
The following is the format of the M-CDR with the appropriate ASN.1 types:
SGSNMMRecord : := SET
recordType
servedIMSI
servedIMEI
sgsnAddress
msNetworkCapability
routingArea
locationAreaCode
cellIdentity
changeLocation
recordOpeningTime
duration
sgsnChange
causeForRecClosing
diagnostics
nodeID
recordExtensions
localSequenceNumber
servedMSISDN
chargingCharacteristics
cAMELInformationPDP
Table 2-4 shows the format of the M-CDR with the appropriate ASN.1 types.
Table 2-4 M-CDR Fields
recordType |
servedIMSI |
[1] IMSI, |
servedIMEI |
[2] IMEI OPTIONAL, |
sgsnAddress |
[3] GSNAddress, |
[4] MSNetworkCapability OPTIONAL, |
routingArea |
[5] RoutingAreaCode OPTIONAL, |
locationAreaCode |
[6] LocationAreaCode OPTIONAL, |
cellIdentity |
[7] CellId OPTIONAL, |
changeLocation |
[8] SEQUENCE OF ChangeLocation OPTIONAL, |
recordOpeningTime |
[9] TimeStamp |
duration |
[10] CallDuration OPTIONAL, |
sgsnChange |
[11] SGSNChange OPTIONAL, |
[12] CauseForRecClosing, |
diagnostics |
[13] Diagnostics OPTIONAL, |
[14] INTEGER OPTIONAL, |
nodeID |
[15] NodeID OPTIONAL, |
recordExtensions |
[16] ManagementExtensions OPTIONAL, |
[17] LocalSequenceNumber OPTIONAL, |
servedMSISDN |
[18] MSISDN OPTIONAL, |
chargingCharacteristics |
[19] ChargingCharacteristics OPTIONAL, |
[20] CAMELInformationPDP OPTIONAL, |
The M-CDR change of location container contains the following fields:
ChangeLocation :: = SEQUENCE
-- used in SGSNMMRecord only
locationAreaCode
routingAreaCode
cellId
changeTime
Table 2-5 shows the fields of M-CDR change of location container.
Table 2-5 M-CDR Container Fields
locationAreaCode |
[0] LocationAreaCode, |
routingAreaCode |
[1] RoutingAreaCode, |
cellId |
[2] CellID OPTIONAL, |
changeTime |
[3] TimeStamp |
S-SMO-CDR
The following is the format of the S-SMO-CDR with the appropriate ASN.1 types:
SGSNMORecord ::= SET
recordType
servedIMSI
servedIMEI
servedMSISDN
msNetworkCapability
serviceCentre
recordingEntity
locationArea
routingArea
cellIdentity
messageReference
originationTime
smsResult
recordExtensions
nodeID
localSequenceNumber
systemType
destinationNumber
cAMELInformationSMS
S-SMO-CDR shows the format of the S-SMO-CDR with the appropriate ASN.1 types.
Table 2-6 S-SMO-CDR Fields
recordType |
servedIMSI |
[1] IMSI, |
servedIMEI |
servedMSISDN |
MSISDN OPTIONAL, |
serviceCentre |
AddressString, |
recordingEntity |
RecordingEntity, |
locationArea |
routingArea |
cellIdentity |
messageReference |
Message Reference, |
originationTime |
TimeStamp, |
smsResult |
SMSResult OPTIONAL, |
recordExtensions |
nodeID |
systemType |
destinationNumber |
CalledNumber OPTIONAL, |
cAMELInformationSMS |
[20] CAMELInformationSMS OPTIONAL, |
S-SMT-CDR
The following is the format of the S-SMT-CDR with the appropriate ASN.1 types:
SGSNMTRecord : := SET
recordType
servedIMSI
servedIMEI
servedMSISDN
msNetworkCapability
serviceCentre
recordingEntity
locationArea
routingArea
cellIdentity
originationTime
smsResult
recordExtensions
nodeID
localSequenceNumber
systemType
Table 2-7 shows the format of the S-SMT-CDR with the appropriate ASN.1 types.
Table 2-7 S-SMT-CDR Fields
recordType |
servedIMSI |
[1] IMSI, |
servedIMEI |
servedMSISDN |
MSISDN OPTIONAL, |
serviceCentre |
AddressString, |
recordingEntity |
RecordingEntity, |
locationArea |
routingArea |
cellIdentity |
originationTime |
TimeStamp, |
smsResult |
recordExtensions |
nodeID |
systemType |
CDR Field Changes for 3GPP 32.015 v3.6.0
This section identifies changes to call detail record (CDR) fields between the 3GPP Technical Specification 32.015 version 3.2.0 and version 3.6.0.
For the ASN.1 DC output, the record field “Cell Identity" from v3.2.0 changes to “Cell Identifier" in v3.6.0. The Cell Identifier field is either the cell identity or the Service Area Code (SAC) at the time of record creation.
The v3.6.0 Cell Identifier (SAC) field applies to the following CDRs:
S-CDR (SGSN record)
M-CDR (SGSN mobile station mobility management record)
S-SMO-CDR (SGSN mobile originated SMS record)
S-SMT-CDR (SGSN mobile terminated SMS record)
For the XML, ASCII, and IPDR DC output, the v3.2.0 record field “Cell Identity" will retain the same name in v3.6.0 output.
The “Charging Characteristics" field in v3.6.0 is two bytes. This change applies to the following records: S-CDR, G-CDR, M-CDR, S-SMO-CDR and S-SMT-CDR.
The “umtsQosInformation" field in v3.6.0 is an octet string.
For example, in v3.2.0, the “umtsQosInformation" field definition is:
QoSInformation::= CHOICE
gsmQosInformation [0] GSMQoSInformation,
umtsQosInformation [1] UMTSQoSInformation
UMTSQoSInformation ::= SEQUENCE
trafficClass [0] QoSTrafficClass,
maxBitRateUplink [1] QoSMaxBitRate,
maxBitRateDownlink [2] QoSMaxBitRate,
DeliveryOrder [3] QoSDeliveryOrder,
maxSDUsize [4] QoSMaxSDUsize,
sduErrorRatio [6] QoSSDUErrorRatio,
residualBER [7] QoSResidualBER,
erroneousSDUs [8] QoSErroneousSDUs,
transferDelay [9] QoSTransferDelay,
handlingPriority [10] QoSHandlingPriority,
allocRetenPriority [11] QoSAllcRetenPriority
}In v3.6.0, the “umtsQosInformation" field definition is:
umtsQosInformation [1] OCTET STRING (SIZE (12))
ASN.1 CDR Types
The following are the ASN.1 call detail record (CDR) types which are common to both GGSN and SGSN output records for 3GPP 32.015 v3.2.0 and v3.6.0:
CallEventRecordType ::= INTEGER
moCallRecord(0),
mtCallRecord(1),
roamingRecord(2),
incGatewayRecord(3),
outGatewayRecord(4),
transitCallRecord(5),
moSMSRecord(6),
mtSMSRecord(7),
moSMSIWRecord(8),
mtSMSGWRecord(9),
ssActionRecord(10),
hlrIntRecord(11),
locUpdateHLRRecord(12),
locUpdateVLRRecord(13),
commonEquipRecord(14),
moTraceRecord(15),
mtTraceRecord(16),
termCAMELIntRecord(17),
sgsnPDPRecord(18),
ggsnPDPRecord(19),
sgsnMMRecord(20),
sgsnSMORecord(21),
sgsnSMTRecord(22)
AccessPointNameNI::= IA5String (SIZE(1..63))
-- Network Identifier part of APN in "dot" representation
-- see TS 23.003
AccessPointNameOI::= IA5String (SIZE(1..37))
-- Operator Identifier part of APN in dot representation
-- see TS 23.003
APNSelectionMode::= ENUMERATED
-- See Information Elements TS 29.060
MSorNetworkProvidedSubscriptionVerified(0),
MSProvidedSubscriptionNotVerified(1),
NetworkProvidedSubscriptionNotVerified(2)
BCDDirectoryNumber::= OCTET STRING
CAMELAccessPointNameNI::= AccessPointNameNI
CAMELAccessPointNameOI::= AccessPointNameOI
CAMELInformationMM::= SET
sCFAddress [1] SCFAddress OPTIONAL,
serviceKey [2] ServiceKey OPTIONAL,
defaultTransactionHandling [3] DefaultGPRS-Handling OPTIONAL,
numberOfDPEncountered [4] NumberOfDPEncountered OPTIONAL,
levelOfCAMELService [5] LevelOfCAMELService OPTIONAL,
freeFormatData [6] FreeFormatData OPTIONAL,
fFDAppendIndicator [7] FFDAppendIndicator OPTIONAL
CAMELInformationPDP ::= SET
cAMELAccessPointNameNI [4] CAMELAccessPointNameNI OPTIONAL,
cAMELAccessPointNameOI [5] CAMELAccessPointNameOI OPTIONAL,
numberOfDPEncountered [6] NumberOfDPEncountered OPTIONAL,
levelOfCAMELService [7] LevelOfCAMELService OPTIONAL,
freeFormatData [8] FreeFormatData OPTIONAL,
fFDAppendIndicator [9] FFDAppendIndicator OPTIONAL
CAMELInformationSMS ::= SET
defaultSMSHandling [3] DefaultSMS-Handling OPTIONAL,
cAMELCallingPartyNumber [4] CallingNumber OPTIONAL,
cAMELDestinationSubscriberNumber [5] CalledNumber OPTIONAL,
cAMELSMSCAddress [6] AddressString OPTIONAL,
freeFormatData [7] FreeFormatData OPTIONAL
CalledNumber ::= BCDDirectoryNumber
CallingNumber ::= BCDDirectoryNumber
CellId ::= OCTET STRING (SIZE(2))
-- Coded according to TS 24.008
CauseForRecClosing::= INTEGER
-- in GGSN the value sGSNChange should be used for partial record
-- generation due to SGSN Address List Overflow
-- cause codes 0 to 15 are defined in GSM12.05 as 'CauseForTerm' (cause for termination)
normalRelease (0),
abnormalRelease (4),
cAMELInitCallRelease (5),
volumeLimit (16),
timeLimit (17),
sGSNChange (18),
maxChangeCond (19),
managementIntervention (20)
ChangeCondition::= ENUMERATED
qoSChange (0),
tariffTime (1),
recordClosure (2)
-- used in PDP context record only
qosRequested [1] QoSInformation OPTIONAL,
qosNegotiated [2] QoSInformation OPTIONAL,
dataVolumeGPRSUplink [3] DataVolumeGPRS,
dataVolumeGPRSDownlink [4] DataVolumeGPRS,
changeCondition [5] ChangeCondition,
changeTime [6] TimeStamp
ChangeLocation ::= SEQUENCE
locationAreaCode [0] LocationAreaCode,
routingAreaCode [1] RoutingAreaCode,
cellId [2] CellId OPTIONAL,
changeTime [3] TimeStamp
ChargingCharacteristics::= OCTET STRING (SIZE(1))
-- Descriptions for the bits of the flag set:
-- Bit 1: H (Hot billing) := '00000001'B
-- Bit 2: F (Flat rate) := '00000010'B
-- Bit 3: P (Prepaid service) := '00000100'B
-- Bit 4: N (Normal billing) := '00001000'B
-- Bit 5: - (Reserved, set to 0) := '00010000'B
-- Bit 6: - (Reserved, set to 0) := '00100000'B
-- Bit 7: - (Reserved, set to 0) := '01000000'B
-- Bit 8: - (Reserved, set to 0) := '10000000'B
ChargingID::= INTEGER (0..4294967295)
-- generated in GGSN, part of PDP context, see TS 23.060
-- 0..4294967295 is equivalent to 0..2**32-1
DataVolumeGPRS::= INTEGER
-- The volume of data transferred in octets.
DefaultGPRS-Handling ::= ENUMERATED {
continueTransaction (0),
releaseTransaction (1),
Diagnostics ::= CHOICE
gsm0408Cause [0] INTEGER,
-- See TS GSM 04.08
gsm0902MapErrorValue [1] INTEGER,
-- Note: The value to be stored here corresponds to
-- the local values defined in the MAP-Errors and
-- MAP-DialogueInformation modules, for full details
-- see TS GSM 09.02.
ccittQ767Cause [2] INTEGER,
-- See CCITT Q.767
networkSpecificCause [3] ManagementExtension,
-- To be defined by network operator
manufacturerSpecificCause [4] ManagementExtension
-- To be defined by manufacturer
Duration ::= INTEGER
DynamicAddressFlag::= BOOLEAN
ETSIAddress::= AddressString
--first octet for nature of address, and numbering plan indicator (3 for X.121)
--other octets TBCD
-- See TS 29.002
FFDAppendIndicator::= BOOLEAN
FreeFormatData::= OCTET STRING (SIZE(1..160))
-- Free formated data as sent in the FurnishChargingInformationGPRS
-- see TS 29.002
GSNAddress::= IPAddress
GSMQoSInformation::=SEQUENCE
reliability [0] QoSReliability,
delay [1] QoSDelay,
precedence [2] QoSPrecedence,
peakThroughput [3] QoSPeakThroughput,
meanThroughput [4] QoSMeanThroughput
IPAddress::= CHOICE
iPBinaryAddress IPBinaryAddress,
iPTextRepresentedAddress IPTextRepresentedAddress
IPBinaryAddress::= CHOICE
iPBinV4Address [0] OCTET STRING (SIZE(4)),
iPBinV6Address [1] OCTET STRING (SIZE(16))
IPTextRepresentedAddress::= CHOICE
-- IP address in the familiar "dot" notation
iPTextV4Address [2] IA5String (SIZE(7..15)),
iPTextV6Address [3] IA5String (SIZE(15..45))
LevelOfCAMELService ::= BIT STRING
basic (0),
callDurationSupervision (1),
onlineCharging (2)
LocationAreaCode ::= OCTET STRING (SIZE(2))
LocalSequenceNumber ::= INTEGER (0..4294967295)
-- Sequence number of the record in this node
-- 0.. 4294967295 is equivalent to 0..2**32-1, unsigned integer in four octets
MSNetworkCapability::= OCTET STRING (SIZE(1))
NetworkInitiatedPDPContext::= BOOLEAN
-- Set to true if PDP context was initiated from network side
NodeID::= IA5 string (SIZE(1..20))
NumberOfDPEncountered ::= INTEGER
PDPAddress::= CHOICE
iPAddress [0] IPAddress,
eTSIAddress [1] ETSIAddress
PDPType::= OCTET STRING (SIZE(2))
--OCTET 1: PDP Type Organization
--OCTET 2: PDP Type Number
-- See TS 29.060
QoSAllocRetenPriority::= ENUMERATED
-- See Quality of service TS 24.008
priorityLevel 1 (1),
priorityLevel 2 (2),
priorityLevel 3 (3)
QoSDelay::= ENUMERATED
delayClass1 (1),
delayClass2 (2),
delayClass3 (3),
delayClass4 (4)
QoSDeliveryOrder::= ENUMERATED
withDeliveryOrder (1),
withoutDeliveryOrder (2)
QoSErroneousSDUs::= ENUMERATED
noDetect (1),
delivered (2),
notDelivered (3)
QosHandlingPriority::= ENUMERATED
priorityLevel 3 (3)
QoSMaxBitRate::= OCTET STRING (SIZE(1))
-- See Quality of service TS 24.008--
-- In MS to network direction:
-- 0 0 0 0 0 0 0 0 Subscribed maximum bit rate for uplink
-- In network to MS direction:
-- 0 0 0 0 0 0 0 0 Reserved
-- In MS to network direction and in network to MS direction :
-- 0 0 0 0 0 0 0 1 The max bit rate is binary coded in 8 bits, using a granularity of 1 kbps
-- 0 0 1 1 1 1 1 1 giving a range of values from 1 kbps to 63 kbps in 1 kbps increments.
-- 0 1 0 0 0 0 0 0 MBR is 64 kbps+((the binary coded value in 8 bits -01000000)*8 kbps)
-- 0 1 1 1 1 1 1 1 giving a range of values from 64 kbps to 564 kbps in 8 kbps increments.
-- 1 0 0 0 0 0 0 0 MBR is 576 kbps + ((the binary coded value in 8 bits -10000000) * 64 kbps
-- 1 1 1 1 1 1 1 0 giving a range of values from 576 kbps to 8640 kbps in 64 kbps increments.
-- 1 1 1 1 1 1 1 1 Reserved
QoSMaxSDUsize::= OCTET STRING (SIZE(1))
-- The Maximum SDU size value is binary coded in 8 bits, using a granularity of 10 octets.
-- 00000000 Subscribed maximum SDU size
-- 11111111 Reserved
-- 00000000 Reserved
-- For values in the range 00000001 to 10010110 the Maximum SDU size value is binary coded in 8
-- bits,using a granularity of 10 octets, giving a range of values from 10 octets to 1500 octets.
-- Values above 10010110 are as below:
-- 10010111 1502 octets
-- 10011000 1510 octets
-- 10011001 1520 octets
QoSMeanThroughput::= ENUMERATED
bestEffort (0),
mean100octetPh (1),
mean200octetPh (2),
mean500octetPh (3),
mean1000octetPh (4),
mean2000octetPh (5),
mean5000octetPh (6),
mean10000octetPh (7),
mean20000octetPh (8),
mean50000octetPh (9),
mean100000octetPh (10),
mean200000octetPh (11),
mean500000octetPh (12),
mean1000000octetPh (13),
mean2000000octetPh (14),
mean5000000octetPh (15),
mean10000000octetPh (16),
mean20000000octetPh (17),
mean50000000octetPh (18)
QoSPeakThroughput::= ENUMERATED
unspecified (0),
upTo1000octetPs (1),
upTo2000octetPs (2),
upTo4000octetPs (3),
upTo8000octetPs (4),
upTo16000octetPs (5),
upTo32000octetPs (6),
upTo64000octetPs (7),
upTo128000octetPs (8),
upTo256000octetPs (9)
QoSPrecedence::= ENUMERATED
unspecified (0),
highPriority (1),
normalPriority (2),
lowPriority (3)
QoSReliability::= ENUMERATED
unspecifiedReliability (0),
acknowledgedGTP (1),
unackGTPAcknowLLC (2),
unackGTPLLCAcknowRLC (3),
unackGTPLLCRLC (4),
unacknowUnprotectedData (5)
QoSResidualBER::= ENUMERATED
-- The Residual BER value consists of 4 bits. The ranges from 5*10-2 to 6*10-8. 4.
5*10power2 (1),
1*10power2 (2),
5*10power3 (3),
4*10power3 (4),
1*10power3 (5),
1*10power4 (6),
1*10power5 (7),
1*10power6 (8),
6*10power8 (9)
QoSSDUErrorRatio::= ENUMERATED
1*10power2 (1),
7*10power3 (2),
1*10power3 (3),
1*10power4 (4),
1*10power5 (5),
1*10power6 (6)
QoSTrafficClass::= ENUMERATED
Subscribed (0),
Conversational (1),
Streaming (2),
Interactive (3),
Background (4)
QoSTransferDelay::= OCTET STRING (SIZE(1))
-- 0 0 0 0 0 0 Subscribed transfer delay
-- sIn network to MS direction:
-- 0 0 0 0 0 0 Reserved
-- 0 0 0 0 0 1 The Transfer delay is binary coded in 6 bits, using a granularity of 10 ms
-- 0 0 1 1 1 1 giving a range of values from 10 ms to 150 ms in 10 ms increments
-- 0 1 0 0 0 0 transfer delay is 200 ms +((the binary coded value in 6 bits - 010000)*50 ms)
-- 0 1 1 1 1 1 giving a range of values from 200 ms to 950 ms in 50ms increments
-- 1 0 0 0 0 0 transfer delay is 1000 ms + ((the binary coded value in 6 bits - 100000)*100 ms)
-- 1 1 1 1 1 0 giving a range of values from 1000 ms to 4100 ms in 100ms increments
-- 1 1 1 1 1 1 Reserved
RoutingAreaCode::= OCTET STRING (SIZE(1))
-- See TS 24.008 --
SCFAddress::= AddressString
-- See TS 29.002 ---
ServiceKey ::= INTEGER (0..2147483647)
SGSNChange::= BOOLEAN
-- present if first record after inter SGSN routing area update
-- in new SGSN
SystemType ::= ENUMERATED
umtsRel99 (1)
AddressString ::= OCTET STRING (SIZE (1..maxAddressLength))
-- This type is used to represent a number for addressing
-- purposes. It is composed of
-- a)one octet for nature of address, and numbering plan
-- indicator.
-- b)digits of an address encoded as TBCD-String.
-- a)The first octet includes a one bit extension indicator, a
-- 3 bits nature of address indicator and a 4 bits numbering
-- plan indicator, encoded as follows:
-- bit 8: 1 (no extension)
-- bits 765: nature of address indicator
-- 000 unknown
-- 001 international number
-- 010 national significant number
-- 011 network specific number
-- 100 subscriber number
-- 101 reserved
-- 110 abbreviated number
-- 111 reserved for extension
-- bits 4321: numbering plan indicator
-- 0000 unknown
-- 0001 ISDN/Telephony Numbering Plan (Rec CCITT E.164)
-- 0010 spare
-- 0011 data numbering plan (CCITT Rec X.121)
-- 0100 telex numbering plan (CCITT Rec F.69)
-- 0101 spare
-- 0110 land mobile numbering plan (CCITT Rec E.212)
-- 0111 spare
-- 1000 national numbering plan
-- 1001 private numbering plan
-- 1111 reserved for extension
-- all other values are reserved.
-- b)The following octets representing digits of an address
-- encoded as a TBCD-STRING.
maxAddressLength INTEGER ::= 20
TimeStamp::= OCTET STRING (SIZE(9))
-- The contents of this field are a compact form of the UTCTime format
-- containing local time plus an offset to universal time. Binary coded
-- decimal encoding is employed for the digits to reduce the storage and
-- transmission overhead
-- e.g. YYMMDDhhmmssShhmm
-- where
-- YY = Year 00 to 99 BCD encoded
-- MM = Month 01 to 12 BCD encoded
-- DD = Day 01 to 31 BCD encoded
-- hh = hour 00 to 23 BCD encoded
-- mm = minute 00 to 59 BCD encoded
-- ss = second 00 to 59 BCD encoded
-- S = Sign 0 = "+", "-" ASCII encoded
UMTSQoSInformation::=SEQUENCE
handlingPriority [10] QosHandlingpriority,
allocRetenPriority [11] QoSAllocRetenPriority
ISDN-AddressString ::=
AddressString (SIZE (1..maxISDN-AddressLength))
-- This type is used to represent ISDN numbers.
maxISDN-AddressLength INTEGER ::= 9
MSISDN::= ISDN-AddressString
TBCD-STRING ::= OCTET STRING
-- This type (Telephony Binary Coded Decimal String) is used to
-- represent several digits from 0 through 9, *, #, a, b, c, two
-- digits per octet, each digit encoded 0000 to 1001 (0 to 9),
-- 1010 (*), 1011 (#), 1100 (a), 1101 (b) or 1110 (c); 1111 used
-- as filler when there is an odd number of digits.
-- bits 8765 of octet n encoding digit 2n
-- bits 4321 of octet n encoding digit 2(n-1) +1
IMSI ::= TBCD-STRING (SIZE (3..8))
-- digits of MCC, MNC, MSIN are concatenated in this order.
RecordingEntity ::= AddressString
Sample Wireless DC Output Formats
This section contains sample distribution cartridge (DC) output formats for the GGSN/SGSN node chain, as follows:
ASCII DC Sample Data for GPRS
The following section displays ASCII DC record samples for GPRS releases 2.0, 3.0, and 4.0. For GPRS 5.0 sample data, see "ASCII Delimited DC Output Format". You can configure the delimiter and separator through the Offline Mediation Controller Administration GUI.
GPRS 2.0 ASCII Record Sample
The following is a sample of a record in ASCII delimited file format for GPRS 2.0.
Charging-ID,Access-Point-Name-Network-Identifier,Record-Opening-Time,Duration,Record-Sequence-Number,Call-Event-Record-Type,Served-PDP-Address,Cause-For-Record-Closing,APN-Selection-Mode,SGSN-Address,APN-Operator-Identifier,ServiceCentre,Recording-Entity,Origination-Time,List-Of-Traffic-Volumes,PDP-Type,MS-Network-Capability,Message-Reference,Network-Initiation,Remote-PDP-Address,Dynamic-Address-Flag,Node-ID,Local-Record-Sequence-Number,Served-IMEI,Routing-Area,Location-Area-Code,Cell-Identity,Change-Location,SGSN-Change,Served-MSISDN,Record-Extensions,Diagnostics,SMS-Result,Served-IMSI,GGSN-Address-Used,Inbound-Roamer-Flag,System-Type,RNC-Unsent-Downlink-Volume,Charging-Characteristics,Destination-Number,CAMEL-Information-PDP,CAMEL-Information-SMS,CAMEL-Information-MM,appId,msid,mdn,billGroup,callBillId,reqHorAccuracy,reqAltAccuracy,errorCode,repHorAccuracy,repAltAccuracy,lat,long,alt,src,conf,heading,speed,climb,cellLoc,timeDate,lerSource,connId,RecordIdentifier,ContextId,OperationType,BearerId,OperationTime,UserId,AccessType,PrePaidFlag,DialedNumber,Url,InbandBillingHeader,MetaProfileId,ProfileId,IncomingPortNumber,OutgoingPortNumber,BytesIncoming,BytesOutgoing,FragmentsIncoming,FragmentsOutgoing,CookiesIncoming,CookiesOutgoing,ConnectTime,TariffCode,Credits,ServiceCategory,FaultCode,NasIP,RemoteIP,LocalIP,NumberOfCreditsUsed,Wtlsclass,WtlssecLevel,WtlskeyRefreshRate,WtlskeyExchangeSuite,WtlsmacAlgorithm,WtlsbulkAlgorithm,UniqueId,Language,Bears,CellId,Alias,UserPasswd,CookieBehaviour,Tag,Ports,Qos,AllowCookies,FreeBrowsing,TotalCredits,FreeUrls,FreeUrlsCredits,Location,Confirmed,ServiceDescription,WsbNode,MobileType,TetraIP,CdpdIP,MimeType,DeliveryBeforeTimeStamp,DeliveryAfterTimeStamp,SourceReference,PpgNotifyTo,ProgressNotesRequested,QosPriority,QosDeliveryMethod,QosNetwork,QosNetworkRequired,QosBearer,QosBearerRequested,TargetAddress,RoamingFlag,MobileNetworkID,MobileNetworkDescription,GlobalRoamingAddress,Imsi,SecureConnectionRequired,Operation,UserAgentHeader,Status,SourceAddress,SourcePort,BearerType,DestAddress,DestPort,ReasonCode,ServerPushID,URI,EventLinkageId,EventId,SourceModuleId,DateTime,GeneratingEntity,ContentLength,NumShortMessages,MSISDN,BillHTTPHeader,BillHTTPValue,ClientId,ClassOfInterface,ClientAddress,CallBackAddress,CallBackProtocol,StoreDate,ForwardDate,PreferedBearer,ResultOfPush,PDUSize,ClassOfService,SessionTime,InputOctets,OutputOctets,StartTime,Transaction,RASAttributes,PushInitiatorId,PushType,ProxyNAVResult,SE:AppSrvID,SE:AppSrvVer,UE:NGS_ID,UE:Charge_ID,UE:GGSN_Ip,UE:App_ID,UE:Method,UE:Param,UE:Dev_Ip,UE:MSISDN,SC:Requestor,UE:User_ID,UE:Source_UserID,UE:Dest_UserID,UE:QoS,UE:Time,UE:Descr,UE:Status,UE:FR,UE:Unit_T,UE:N_Units,UE:Amount,UE:Currency,UE:Merchant_ID,UE:Add_Info,UE:NE_Ip,UE:URL,UE:APN,IPDRRec:startTime,UE:Service_ID,UE:N_Success,UE:NE_Usage,UE:Attributes,UE:Action,UE:Balance,UE:Criteria,UE:Dest_Address,UE:Expiry,UE:Keyword,UE:Media_Type,UE:PID,UE:Size,UE:Transaction_ID,UE:Options,UE:Volume,UE:Points_Awarded,UE:Charging_Parameters '36000301','wapcmg','02 06 04 11 20 16 + 02 00 ','4336','2','18','IPAddress=IPTextV4Address=10.11.197.19','0','0','IPTextV4Address=47.104.220.249','shasta.nortel.gprs','','','','ChangeCondition=2 ChangeTime=02 06 04 11 56 24 2b 02 00 QosNegotiated=GsmQosInformation=PeakThroughput=2 Delay=1 Precedence=2 MeanThroughput=3 Reliability=1 DataVolumeGPRSUplink=24 QosRequested=GsmQosInformation=PeakThroughput=2 Delay=1 Precedence=2 MeanThroughput=3 Reliability=1 DataVolumeGPRSDownlink=989 ChangeCondition=2 ChangeTime=02 06 04 12 56 42 2b 02 00 QosNegotiated=GsmQosInformation=PeakThroughput=2 Delay=1 Precedence=2 MeanThroughput=3 Reliability=1 DataVolumeGPRSUplink=989 QosRequested=GsmQosInformation=PeakThroughput=2 Delay=1 Precedence=2 MeanThroughput=3 Reliability=1 DataVolumeGPRSDownlink=76543','01 02 ','00 ','','00 ','','','Keitaro','1','00 00 00 00 00 00 10 10 ','08 ','0b 3c ','00 01 ','','00 ','01 87 57 76 65 f7 ','','Gsm0408Cause=0','','11 21 00 00 00 00 00 ','IPTextV4Address=47.104.98.191','','1','0','06 ','','SCFAddress=01 87 17 32 21 f3 CAMELAccessPointNameNI=APN_NI LevelOfCAMELService=00 FreeFormatData=ff 0a ServiceKey=10 NumberOfDPEncountered=2 CAMELAccessPointNameOI=APN_OI DefaultTransactionHandling=1 FFDAppendIndicator=00 ','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','' '36000302','wapcmg','02 06 03 11 20 16 + 02 00 ','6504','3','18','IPAddress=IPTextV4Address=10.11.197.19','0','0','IPTextV4Address=47.104.220.249','shasta.nortel.gprs','','','','ChangeCondition=2 ChangeTime=02 06 03 11 56 24 2b 02 00 QosNegotiated=GsmQosInformation=PeakThroughput=2 Delay=1 Precedence=2 MeanThroughput=3 Reliability=1 DataVolumeGPRSUplink=111 QosRequested=GsmQosInformation=PeakThroughput=2 Delay=1 Precedence=2 MeanThroughput=3 Reliability=1 DataVolumeGPRSDownlink=11111 ChangeCondition=2 ChangeTime=02 06 03 12 56 42 2b 02 00 QosNegotiated=GsmQosInformation=PeakThroughput=2 Delay=1 Precedence=2 MeanThroughput=3 Reliability=1 DataVolumeGPRSUplink=222 QosRequested=GsmQosInformation=PeakThroughput=2 Delay=1 Precedence=2 MeanThroughput=3 Reliability=1 DataVolumeGPRSDownlink=22222 ChangeCondition=1 ChangeTime=02 06 03 13 56 42 2b 02 00 QosNegotiated=GsmQosInformation=PeakThroughput=2 Delay=1 Precedence=2 MeanThroughput=3 Reliability=1 DataVolumeGPRSUplink=333 QosRequested=GsmQosInformation=PeakThroughput=2 Delay=1 Precedence=2 MeanThroughput=3 Reliability=1 DataVolumeGPRSDownlink=33333','01 02 ','00 ','','00 ','','','Keitaro','4','00 00 00 00 00 00 10 10 ','08 ','0b 3c ','00 01 ','','00 ','01 87 57 76 65 f7 ','','Gsm0408Cause=0','','11 21 00 00 00 00 00 ','IPTextV4Address=47.104.98.191','','1','0','06 ','','SCFAddress=01 87 17 32 21 f3 CAMELAccessPointNameNI=APN_NI LevelOfCAMELService=00 FreeFormatData=ff 0a ServiceKey=10 NumberOfDPEncountered=2 CAMELAccessPointNameOI=APN_OI DefaultTransactionHandling=1 FFDAppendIndicator=00 ','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','',''
GPRS 3.0 ASCII Record Sample
The following is ASCII sample data for GPRS 3.0.
Charging-ID,Access-Point-Name-Network-Identifier,Record-Opening-Time,Duration,Record-Sequence-Number,Call-Event-Record-Type,Served-PDP-Address,Cause-For-Record-Closing,APN-Selection-Mode,SGSN-Address,APN-Operator-Identifier,ServiceCentre,Recording-Entity,Origination-Time,List-Of-Traffic-Volumes,PDP-Type,MS-Network-Capability,Message-Reference,Network-Initiation,Remote-PDP-Address,Dynamic-Address-Flag,Node-ID,Local-Record-Sequence-Number,Served-IMEI,Routing-Area,Location-Area-Code,Cell-Identity,Change-Location,SGSN-Change,Served-MSISDN,Record-Extensions,Diagnostics,SMS-Result,Served-IMSI,GGSN-Address-Used,Inbound-Roamer-Flag,System-Type,RNC-Unsent-Downlink-Volume,Charging-Characteristics,Destination-Number,CAMEL-Information-PDP,CAMEL-Information-SMS,CAMEL-Information-MM,appId,msid,mdn,billGroup,callBillId,reqHorAccuracy,reqAltAccuracy,errorCode,repHorAccuracy,repAltAccuracy,lat,long,alt,src,conf,heading,speed,climb,cellLoc,timeDate,lerSource,connId,RecordIdentifier,ContextId,OperationType,BearerId,OperationTime,UserId,AccessType,PrePaidFlag,DialedNumber,Url,InbandBillingHeader,MetaProfileId,ProfileId,IncommingPortNumber,OutgoingPortNumber,BytesIncomming,BytesOutgoing,FragmentsIncomming,FragmentsOutgoing,CookiesIncomming,CookiesOutgoing,ConnectTime,TarrifCode,Credits,ServiceCategory,FaultCode,NasIP,RemoteIP,LocalIP,NumberOfCreditsUsed,Wtlsclass,wtlssecLevel,wtlskeyRefreshRate,wtlskeyExchangeSuite,wtlsmacAlgorithm,wtlsbulkAlgorithm,UniqueId,Language,Bears,CellId,Alias,UserPasswd,CookieBehaviour,Tag,Ports,Qos,AllowCookies,FreeBrowsing,TotalCredits,FreeUrls,FreeUrlsCredits,Location,Confirmed,Description,WsbNode,MobileType,TetraIP,CdpdIP,Operation,UserAgentHeader,Status,SourceAddress,SourcePort,BearerType,DestAddress,DestPort,ReasonCode,ServerPushID,URI,EventLinkageId,EventId,SourceModuleId,DateTime,GeneratingEntity,ContentLength,NumShortMessages,MSISDN,BillHTTPHeader,BillHTTPValue,ClientId,ClassOfInterface,ClientAddress,CallBackAddress,CallBackProtocol,StoreDate,ForwardDate,PreferedBearer,ResultOfPush,PDUSize,ClassOfService,SessionTime,InputOctets,OutputOctets,StartTime,Transaction,RASAttributes,PushInitiatorId,PushType,ProxyNAVResult,SE:AppSrvID,SE:AppSrvVer,UE:NGS_ID,UE:Charge_ID,UE:GGSN_Ip,UE:App_ID,UE:Method,UE:Param,UE:Dev_Ip,UE:MSISDN,SC:Requestor,UE:User_ID,UE:Source_UserID,UE:Dest_UserID,UE:QoS,UE:Time,UE:Descr,UE:Status,UE:FR,UE:Unit_T,UE:N_Units,UE:Amount,UE:Currency,UE:Merchant_ID,UE:Add_Info,UE:NE_Ip,UE:URL,UE:APN,IPDRRec:startTime '1624264','isp2apnlocallocal','01 10 24 18 13 00 + 00 00 ','3600','19','19','IPBinaryAddress=IPBinV4Address=10.248.133.216','17','0','IPBinV4Address=10.4.0.1','','','','','DataVolumeGPRSUplink=0 DataVolumeGPRSDownlink=0 ChangeTime=01 10 24 19 13 00 2b 00 00 ChangeCondition=2 QosNegotiated=GsmQosInformation=Precedence=3 Reliability=5 MeanThroughput=0 PeakThroughput=5 Delay=4','01 21 ','','','','','01 ','','','','','','','','','91 91 27 02 90 34 f0 ','','','','05 05 42 01 21 62 05 f0 ','IPBinV4Address=47.104.98.165','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','' '1656989','isp2apnlocallocal','01 10 24 18 13 09 + 00 00 ','3600','18','19','IPBinaryAddress=IPBinV4Address=10.249.5.174','17','0','IPBinV4Address=10.4.0.1','','','','','DataVolumeGPRSUplink=0 DataVolumeGPRSDownlink=0 ChangeTime=01 10 24 19 13 09 2b 00 00 ChangeCondition=2 QosNegotiated=GsmQosInformation=Precedence=3 Reliability=5 MeanThroughput=0 PeakThroughput=5 Delay=4','01 21 ','','','','','01 ','','','','','','','','','91 91 27 03 22 85 f4 ','','','','05 05 42 01 31 93 56 f4 ','IPBinV4Address=47.104.98.165','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','',''
GPRS 4.0 ASCII Record Sample
The following is ASCII sample data for GPRS 4.0. In this example, the comma (,) is the delimiter and the apostrophe (‘) is the text qualifier. You can configure these values in the Offline Mediation Controller Administration GUI.
Charging-ID,Access-Point-Name-Network-Identifier,Record-Opening-Time,Duration,Record-Sequence-Number,Call-Event-Record-Type,Served-PDP-Address,Cause-For-Record-Closing,APN-Selection-Mode,SGSN-Address,APN-Operator-Identifier,ServiceCentre,Recording-Entity,Origination-Time,List-Of-Traffic-Volumes,PDP-Type,MS-Network-Capability,Message-Reference,Network-Initiation,Remote-PDP-Address,Dynamic-Address-Flag,Node-ID,Local-Record-Sequence-Number,Served-IMEI,Routing-Area,Location-Area-Code,Cell-Identity,Change-Location,SGSN-Change,Served-MSISDN,Record-Extensions,Diagnostics,SMS-Result,Served-IMSI,GGSN-Address-Used,Inbound-Roamer-Flag,System-Type,RNC-Unsent-Downlink-Volume,Charging-Characteristics,Destination-Number,CAMEL-Information-PDP,CAMEL-Information-SMS,CAMEL-Information-MM,appId,msid,mdn,billGroup,callBillId,reqHorAccuracy,reqAltAccuracy,errorCode,repHorAccuracy,repAltAccuracy,lat,long,alt,src,conf,heading,speed,climb,cellLoc,timeDate,lerSource,connId,RecordIdentifier,ContextId,OperationType,BearerId,OperationTime,UserId,AccessType,PrePaidFlag,DialedNumber,Url,InbandBillingHeader,MetaProfileId,ProfileId,IncommingPortNumber,OutgoingPortNumber,BytesIncomming,BytesOutgoing,FragmentsIncomming,FragmentsOutgoing,CookiesIncomming,CookiesOutgoing,ConnectTime,TarrifCode,Credits,ServiceCategory,FaultCode,NasIP,RemoteIP,LocalIP,NumberOfCreditsUsed,Wtlsclass,wtlssecLevel,wtlskeyRefreshRate,wtlskeyExchangeSuite,wtlsmacAlgorithm,wtlsbulkAlgorithm,UniqueId,Language,Bears,CellId,Alias,UserPasswd,CookieBehaviour,Tag,Ports,Qos,AllowCookies,FreeBrowsing,TotalCredits,FreeUrls,FreeUrlsCredits,Location,Operation,UserAgentHeader,Status,SourceAddress,SourcePort,BearerType,DestAddress,DestPort,URI,EventLinkageId,EventId,SourceModuleId,DateTime,GeneratingEntity,ContentLength,NumShortMessages,MSISDN,BillHTTPHeader,BillHTTPValue,ClientId,ClassOfInterface,ClientAddress,CallBackAddress,CallBackProtocol,StoreDate,ForwardDate,PreferedBearer,ResultOfPush,PDUSize,ClassOfService,SessionTime,InputOctets,OutputOctets,StartTime,Transaction,RASAttributes,PushInitiatorId,PushType,ProxyNAVResult,SE:AppSrvID,SE:AppSrvVer,UE:NGS_ID,UE:Charge_ID,UE:GGSN_Ip,UE:App_ID,UE:Method,UE:Param,UE:Dev_Ip,UE:MSISDN,SC:Requestor,UE:User_ID,UE:Source_UserID,UE:Dest_UserID,UE:QoS,UE:Time,UE:Descr,UE:Status,UE:FR,UE:Unit_T,UE:N_Units,UE:Amount,UE:Currency,UE:Merchant_ID,UE:Add_Info,UE:NE_Ip,UE:URL,UE:APN,IPDRRec:startTime '','','02 01 22 16 12 16 + 00 00 ','414','3','20','','4','','IPBinV4Address=47.104.220.150','','','','','','','','','','','','','33','','02 ','01 59 ','00 02 ','','','','','','','05 05 42 01 21 51 00 f8 ','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','' '','','02 01 22 16 19 10 + 00 00 ','316','','20','','4','','IPBinV4Address=47.104.220.150','','','','','','','08 ','','','','','TPP159X','36','','01 ','01 59 ','00 01 ','','','11 16 14 21 51 10 f1 ','','','','05 05 42 01 21 51 00 f8 ','','','','','08 00 ','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','' '','','02 01 22 16 25 31 + 00 00 ','8','','20','','0','','IPBinV4Address=47.104.220.150','','','','','','','08 ','','','','','TPP159X','39','','01 ','01 59 ','00 01 ','','','11 16 14 21 51 10 f1 ','','','','05 05 42 01 21 51 10 f1 ','','','','','08 00 ','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','' '','','02 01 22 16 24 26 + 00 00 ','1072','1','20','','17','','IPBinV4Address=47.104.220.150','','','','','','','08 ','','','','','TPP159X','37','','02 ','01 59 ','00 02 ','','','11 16 14 21 51 10 f1 ','','','','05 05 42 01 21 51 00 f8 ','','','','','08 00
GGSN/SGSN DC Output Formats
The following samples are DC output formats for the GGSN/SGSN node chain based on the 3GPP 32.015 v3.6.0 format.
Version Hiding for 3GPP 32.015
Version hiding is only supported for 3GPP 32.015 v3.6 input to v3.2 or v3.6 output. “Forward" version hiding (v3.2 input to v3.6 output) is not supported.
List of Traffic Volume Field in ASCII Output
The order of appearance of the fields contained in the List of Traffic Volume field is not pre-determined.
The following are the only constant conditions:
The entries in the List of Traffic Volume field are outputted sequentially. For example, all fields of the first entry are output before all fields of the second entry and so on.
If a QosRequested/Negotiated field exists, its entire contents are outputted without interruption by any other fields such as DataVolumeGPRSUplink, DataVolumeGPRSDownlink, ChangeTime, and ChangeCondition.
Here is a sample of ASCII delimited DC output format for GGSN/SGSN. You can configure the delimiter and separator through the GUI.
GGSN/SGSN: ASCII delimited file format
Charging-ID,Access-Point-Name-Network-Identifier,Record-Opening-Time,Duration,Record-Sequence-Number,Call-Event-Record-Type,Served-PDP-Address,Cause-For-Record-Closing,APN-Selection-Mode,SGSN-Address,APN-Operator-Identifier,ServiceCentre,Recording-Entity,Origination-Time,List-Of-Traffic-Volumes,PDP-Type,MS-Network-Capability,Message-Reference,Network-Initiation,Remote-PDP-Address,Dynamic-Address-Flag,Node-ID,Local-Record-Sequence-Number,Served-IMEI,Routing-Area,Location-Area-Code,Cell-Identity,Change-Location,SGSN-Change,Served-MSISDN,Record-Extensions,Diagnostics,SMS-Result,Served-IMSI,GGSN-Address-Used,Inbound-Roamer-Flag,System-Type,RNC-Unsent-Downlink-Volume,Charging-Characteristics,Destination-Number,CAMEL-Information-PDP,CAMEL-Information-SMS,CAMEL-Information-MM,appId,msid,mdn,billGroup,callBillId,reqHorAccuracy,reqAltAccuracy,errorCode,repHorAccuracy,repAltAccuracy,lat,long,alt,src,conf,heading,speed,climb,cellLoc,timeDate,lerSource,connId,RecordIdentifier,ContextId,OperationType,BearerId,OperationTime,UserId,AccessType,PrePaidFlag,DialedNumber,Url,InbandBillingHeader,MetaProfileId,ProfileId,IncomingPortNumber,OutgoingPortNumber,BytesIncoming,BytesOutgoing,FragmentsIncoming,FragmentsOutgoing,CookiesIncoming,CookiesOutgoing,ConnectTime,TariffCode,Credits,ServiceCategory,FaultCode,NasIP,RemoteIP,LocalIP,NumberOfCreditsUsed,Wtlsclass,WtlssecLevel,WtlskeyRefreshRate,WtlskeyExchangeSuite,WtlsmacAlgorithm,WtlsbulkAlgorithm,UniqueId,Language,Bears,CellId,Alias,UserPasswd,CookieBehaviour,Tag,Ports,Qos,AllowCookies,FreeBrowsing,TotalCredits,FreeUrls,FreeUrlsCredits,Location,Confirmed,ServiceDescription,WsbNode,MobileType,TetraIP,CdpdIP,MimeType,DeliveryBeforeTimeStamp,DeliveryAfterTimeStamp,SourceReference,PpgNotifyTo,ProgressNotesRequested,QosPriority,QosDeliveryMethod,QosNetwork,QosNetworkRequired,QosBearer,QosBearerRequested,TargetAddress,RoamingFlag,MobileNetworkID,MobileNetworkDescription,GlobalRoamingAddress,Imsi,SecureConnectionRequired,Operation,UserAgentHeader,Status,SourceAddress,SourcePort,BearerType,DestAddress,DestPort,ReasonCode,ServerPushID,URI,EventLinkageId,EventId,SourceModuleId,DateTime,GeneratingEntity,ContentLength,NumShortMessages,MSISDN,BillHTTPHeader,BillHTTPValue,ClientId,ClassOfInterface,ClientAddress,CallBackAddress,CallBackProtocol,StoreDate,ForwardDate,PreferedBearer,ResultOfPush,PDUSize,ClassOfService,SessionTime,InputOctets,OutputOctets,StartTime,Transaction,RASAttributes,PushInitiatorId,PushType,ProxyNAVResult,SE:AppSrvID,SE:AppSrvVer,UE:NGS_ID,UE:Charge_ID,UE:GGSN_Ip,UE:App_ID,UE:Method,UE:Param,UE:Dev_Ip,UE:MSISDN,SC:Requestor,UE:User_ID,UE:Source_UserID,UE:Dest_UserID,UE:QoS,UE:Time,UE:Descr,UE:Status,UE:FR,UE:Unit_T,UE:N_Units,UE:Amount,UE:Currency,UE:Merchant_ID,UE:Add_Info,UE:NE_Ip,UE:URL,UE:APN,IPDRRec:startTime,UE:Service_ID,UE:N_Success,UE:NE_Usage,UE:Attributes,UE:Action,UE:Balance,UE:Criteria,UE:Dest_Address,UE:Expiry,UE:Keyword,UE:Media_Type,UE:PID,UE:Size,UE:Transaction_ID,UE:Options,UE:Volume,UE:Points_Awarded,UE:Charging_Parameters '947678','wap.viaginterkom.de','05 02 04 23 45 00 + 01 00 ','900','6','18','IPAddress=IPBinV4Address=10.38.139.172','17','','IPBinV4Address=10.80.2.102','mnc007.mcc262.gprs','','','','ChangeCondition=2 ChangeTime=05 02 05 00 00 00 2b 01 00 DataVolumeGPRSUplink=103817 DataVolumeGPRSDownlink=107350','01 21 ','','','','','','','21674760','','01 ','77 a2 ','00 0d ','','','','','','','62 02 37 69 70 77 48 f3 ','IPBinV4Address=62.180.77.4','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','' '8363110','wap.viaginterkom.de','05 02 04 23 45 03 + 01 00 ','900','2','18','IPAddress=IPBinV4Address=10.59.92.214','17','','IPBinV4Address=10.80.2.102','mnc007.mcc262.gprs','','','','ChangeCondition=2 ChangeTime=05 02 05 00 00 03 2b 01 00 DataVolumeGPRSUplink=0 DataVolumeGPRSDownlink=0','01 21 ','','','','','','','21674765','','01 ','77 8b ','68 1d ','','','','','','','62 02 37 59 00 44 58 f9 ','IPBinV4Address=82.113.117.193','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','' '954744','internet','05 02 04 23 58 56 + 01 00 ','65','','18','IPAddress=IPBinV4Address=10.49.241.152','0','0','IPBinV4Address=10.80.2.100','mnc007.mcc262.gprs','','','','ChangeCondition=2 ChangeTime=05 02 05 00 00 01 2b 01 00 QosNegotiated=UmtsQosInformation=ErroneousSDUs=3 HandlingPriority=3 ResidualBER=7 DeliveryOrder=2 AllocRetenPriority=2 MaxBitRateUplink=40 TrafficClass=4 MaxSDUsize=96 TransferDelay=3e MaxBitRateDownlink=40 SduErrorRatio=4 DataVolumeGPRSUplink=488 QosRequested=GsmQosInformation=PeakThroughput=4 Delay=4 Precedence=2 MeanThroughput=0 Reliability=3 DataVolumeGPRSDownlink=645','01 21 ','c4 ','','','','','SGSNFRA1T15K','21492544','','68 ','9d 70 ','90 aa ','','','91 94 71 99 20 95 11 ','','','','62 02 37 69 01 17 12 f9 ','IPBinV4Address=62.180.77.4','','','','08 ','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','','',''
3GPP 32.015 ASN.1 Output Format
Here is the 3GPP 32.015 ASN.1 output for the GGSN/SGSN node chain.
GGSN/SGSN: 3GPP 32.015 ASN.1 output format
value CallEventRecord ::= sgsnMMRecord : {
recordType sgsnMMRecord,
servedIMSI '05054201215100F8'H,
sgsnAddress iPBinaryAddress : iPBinV4Address : '2F68DC96'H,
routingArea '02'H,
locationAreaCode '0159'H,
cellIdentifier '0002'H,
recordOpeningTime '0201221612162B0000'H,
duration 414,
causeForRecClosing abnormalRelease,
recordSequenceNumber 3,
localSequenceNumber 33
msNetworkCapability '08'H,
routingArea '01'H,
cellIdentifier '0001'H,
recordOpeningTime '0201221619102B0000'H,
duration 316,
nodeID "TPP159X",
localSequenceNumber 36,
servedMSISDN '111614215110F1'H,
chargingCharacteristics '0800'H
servedIMSI '05054201215110F1'H,
routingArea '01'H,
recordOpeningTime '0201221625312B0000'H,
duration 8,
causeForRecClosing normalRelease,
nodeID "TPP159X",
localSequenceNumber 39,
XML DC Output Format
XML files are in HTML format. The general format of these files is a group of data lines for each count. Each data line contains an attribute tag, the associated value, and an ending tag.
Here is a sample of the XML DC output format for the GGSN/SGSN. The delimiter used in this sample is an Enter character.
GGSN/SGSN: XML DC output format
<?xml version="1.0"?> <XMLDoc> <rec> <Charging-ID>947678</Charging-ID> <Access-Point-Name-Network-Identifier>wap.viaginterkom.de</Access-Point-Name-Network-Identifier> <Record-Opening-Time>05 02 04 23 45 00 + 01 00 </Record-Opening-Time> <Duration>900</Duration> <Record-Sequence-Number>6</Record-Sequence-Number> <Call-Event-Record-Type>18</Call-Event-Record-Type> <Served-PDP-Address> <IPAddress> <IPBinV4Address>10.38.139.172</IPBinV4Address> </IPAddress> </Served-PDP-Address> <Cause-For-Record-Closing>17</Cause-For-Record-Closing> <SGSN-Address> <IPBinV4Address>10.80.2.102</IPBinV4Address> </SGSN-Address> <APN-Operator-Identifier>mnc007.mcc262.gprs</APN-Operator-Identifier> <List-Of-Traffic-Volumes> <MAP> <ChangeCondition>2</ChangeCondition> <ChangeTime>05 02 05 00 00 00 2b 01 00 </ChangeTime> <DataVolumeGPRSUplink>103817</DataVolumeGPRSUplink> <DataVolumeGPRSDownlink>107350</DataVolumeGPRSDownlink> </MAP> </List-Of-Traffic-Volumes> <PDP-Type>01 21 </PDP-Type> <Local-Record-Sequence-Number>21674760</Local-Record-Sequence-Number> <Routing-Area>01 </Routing-Area> <Location-Area-Code>77 a2 </Location-Area-Code> <Cell-Identity>00 0d </Cell-Identity> <Served-IMSI>62 02 37 69 70 77 48 f3 </Served-IMSI> <GGSN-Address-Used> <IPBinV4Address>62.180.77.4</IPBinV4Address> </GGSN-Address-Used> </rec> <rec> <Charging-ID>8363110</Charging-ID> <Access-Point-Name-Network-Identifier>wap.viaginterkom.de</Access-Point-Name-Network-Identifier> <Record-Opening-Time>05 02 04 23 45 03 + 01 00 </Record-Opening-Time> <Duration>900</Duration> <Record-Sequence-Number>2</Record-Sequence-Number> <Call-Event-Record-Type>18</Call-Event-Record-Type> <Served-PDP-Address> <IPAddress> <IPBinV4Address>10.59.92.214</IPBinV4Address> </IPAddress> </Served-PDP-Address> <Cause-For-Record-Closing>17</Cause-For-Record-Closing> <SGSN-Address> <IPBinV4Address>10.80.2.102</IPBinV4Address> </SGSN-Address> <APN-Operator-Identifier>mnc007.mcc262.gprs</APN-Operator-Identifier> <List-Of-Traffic-Volumes> <MAP> <ChangeCondition>2</ChangeCondition> <ChangeTime>05 02 05 00 00 03 2b 01 00 </ChangeTime> <DataVolumeGPRSUplink>0</DataVolumeGPRSUplink> <DataVolumeGPRSDownlink>0</DataVolumeGPRSDownlink> </MAP> </List-Of-Traffic-Volumes> <PDP-Type>01 21 </PDP-Type> <Local-Record-Sequence-Number>21674765</Local-Record-Sequence-Number> <Routing-Area>01 </Routing-Area> <Location-Area-Code>77 8b </Location-Area-Code> <Cell-Identity>68 1d </Cell-Identity> <Served-IMSI>62 02 37 59 00 44 58 f9 </Served-IMSI> <GGSN-Address-Used> <IPBinV4Address>82.113.117.193</IPBinV4Address> </GGSN-Address-Used> </rec> <rec>
