8 Configuring the Nortel CS 2000 AMADNS Cartridge Pack
This chapter describes how to configure the nodes included in the Oracle Communications Offline Mediation Controller Nortel CS 2000 AMADNS Cartridge Pack.
Topics in this chapter:
About the Nortel CS 2000 AMADNS Collection Cartridge Pack
The Nortel CS 2000 AMADNS Collection cartridge pack supports the collection of Nortel CS 2000 SN09 AMADNS records. The AMADNS files produced by the Nortel Communication Server 2000 (CS 2000) will be either FTP pushed to the CS 2000 CC or FTP pulled from the Nortel CS 2000 Carrier Voice over IP softswitch through an intermediate FTP server.
The CS 2000 AMADNS records are sent from the Nortel CS 2000 AMADNS CC node to the Nortel CS 2000 AMADNS DC node.
Configuring the Nortel CS 2000 AMADNS CC Node
The Nortel CS 2000 AMADNS CC node receives Nortel CS 2000 SN09 AMADNS records.
To configure the Nortel CS 2000 AMADNS CC node, you configure standard parameters, include FTP connection configurations.
There are two rule files you can use:
Nortel CS 2000 SN09 AMADNS. This is the default.
Reprocess - Nortel CS 2000 SN09 AMADNS. Use this rule file when there is no match with the Service Provider Lookup file. This can be used in a separate instance of the node, placed after the default implementation in the node chain.
