2 OSM System Requirements
This chapter describes the Oracle Communications Order and Service Management (OSM) system requirements. It also describes information you need during the installation procedure.
Software Requirements
For details about the software required to support the OSM components for traditional deployment, see "OSM Traditional Deployment Software Compatibility" in OSM Compatibility Matrix.
Information Requirements
You must supply configuration-related information when you install OSM. Some of this information is determined during the installation. However, some information should already have been determined before the OSM installation is begun. Gather this information in advance.
You can obtain most of the required configuration information from your Oracle database administrator (DBA) and your system administrator.
Oracle Database Information
The information in Table 2-1 is needed to connect to an Oracle database instance.
Table 2-1 Oracle Database Connection Information
| Information Type | Description |
Database Instance Host |
The IP address or DNS name of the database instance on which the OSM schema will be installed. If you plan to use an Oracle RAC database, you need the Single Client Access Name (SCAN) for this field. |
Database Instance Port |
The port on which the database instance to which the OSM schema will be installed is listening. |
Database Instance SID |
The SID of the database instance on which the OSM schema will be installed. |
Database Service Name |
The name of the service used for OSM client connections. |
If the OSM database users have been created prior to the OSM installation, you must gather the information in Table 2-2 before installing OSM. If they have not been created, you can determine the following information during the installation.
Table 2-2 Oracle Database Credential Information
Core Schema User name |
The OSM core schema username. |
Core Schema Password |
The OSM core schema username password. |
Rule Engine Schema User name |
The OSM rule engine schema username. |
Rule Engine Schema Password |
The OSM rule engine schema username password. |
Reporting Schema User name |
The OSM Reporting Interface schema username. |
Reporting Schema Password |
The OSM Reporting Interface schema username password. |
Database Admin User name |
The user name of the Oracle DBA. |
Database Admin Password |
The password of the Oracle DBA. |
Table 2-3 shows the information used to indicate the tablespaces being used for the installation.
Table 2-3 Oracle Database Tablespace Information
Default Tablespace |
The tablespace to use if your data will all be on the same permanent tablespace. |
Temporary Tablespace |
If your database instance has only one temporary tablespace, the installer will find its name automatically. If there is more than one temporary tablespace in the database instance, you must know which one OSM is supposed to use. |
Model Data Tablespace |
The name of the tablespace to use for model data, if different from the default tablespace. |
Model Index Tablespace |
The name of the tablespace to use for the indexes for the model data, if different from the default tablespace. |
Order Data Tablespace |
The name of the tablespace to use for order data, if different from the default tablespace. |
Order Index Tablespace |
The name of the tablespace to use for the indexes for the order data, if different from the default tablespace. |
WebLogic Server Information
Table 2-4 shows the WebLogic Server information needed to connect to a WebLogic server.
Table 2-4 WebLogic Server Information
| Data | Description |
WebLogic Host Name |
The name or IP address of the computer where WebLogic Server is installed. |
WebLogic Port Number |
The port number of the WebLogic server. |
WebLogic SSL Port Number |
The SSL port number of the WebLogic server. |
WebLogic Admin User |
The user name of the WebLogic system administrator. |
WebLogic Admin Password |
The password of the WebLogic system administrator. |
OSM Server Information
Table 2-5 shows the information related to the OSM server installation. The following information is used to specify the SMTP mail server and the administrative e-mail addresses to deliver notifications via e-mail.
Table 2-5 Email Notification
Notification Email server |
DNS name or IP address of your e-mail server. |
Notification Email server Port |
Port that the e-mail server is listening. |
Administrator Email Address |
OSM Administrator's e-mail address. |
