1 About the OSM Reporting Interface
Use the Oracle Communications Order and Service Management (OSM) Reporting Interface to generate reports about orders, tasks, and notifications.
The OSM Reporting Interface provides a standard interface to OSM data that can be accessed using many third-party report generation applications. You can also use Ant to run reports and output data to comma-separated values (CSV) and XML files.
The Reporting Interface augments the reports that are available through the OSM web client.
About the OSM Reports
Using the reporting interface, you can generate the following reports:
Orders Report: This report gives you an overview of pending and completed orders. You can filter the query to limit the number of responses. By specifying an OSM view (query task) mnemonic, you can display additional order information. See "About the Orders Report" for more information.
Order History Report: This report returns order change information for a specified time interval. See "About the Order History Report" for more information.
Pending Order At Task Report: This report gives you an overview of the pending orders and their related tasks information. See "About the Pending Order At Tasks Report" for more information.
Processes Report: This report shows all completed and pending processes, including main processes, creation processes, and processes invoked by sub-processing. See "About the Processes Report" for more information.
Tasks Report: This report creates a list of pending and completed tasks (excluding sub-process tasks). See "About the Tasks Report" for more information.
Notifications Report: This report contains a list of order and non-order based notifications. See "About the Notifications Report" for more information.
How OSM Reports are Implemented
Reports are implemented in two ways:
As Oracle database stored procedures.
As Oracle database views.
You use a third-party reporting application to access the procedures and views, configure parameters, and output results. You can also run reports using Ant to export report data to CSV or XML files.
The following reports are implemented as Oracle database stored procedures:
Orders (OMS_REPORT_ORDERS)
Order History (OMS_REPORT_ORDERS_HISTORY)
Pending Order At Task (OMS_REPORT_PENDING_AT_TASKS)
The following reports are implemented as Oracle database views:
Processes
Tasks
Notifications
This report gives you an overview of pending and completed orders. You can filter the query to limit the number of responses. By specifying an OSM view (query task) mnemonic, you can display additional order information for those records that contain it.
When you run the Orders report:
One row represents one order.
When displaying order data, if there are multiple data items for the data, all instances are displayed.
When viewing order-specific data, the mnemonic is used as the column name. The order of the columns is based on the view node position.
The report shows both pending and completed orders. You can use the order completion date to distinguish pending orders and completed orders. A pending order does not have a value in these columns:
completion date
time
Calculating Duration in the Orders Report
In the Orders report, duration for completed orders is calculated as follows:
completion_date - order_start_date
order_start_date is when the order was started, not when the order was created.
In the case of pending orders, the duration is calculated as follows:
sysdate - order_start_date
Orders Report Contents
The Orders report displays the following data:
Order ID
Reference number
Order type description and mnemonic
Order source description and mnemonic
Process description and mnemonic
This is the current process of an order. (This data is empty for completed orders.)
Process status description and mnemonic (last process status)
Order creation date and time
Order start date and time
Expected duration of the order in days
Actual duration of the order in days
Expected order completion date
Completion date of the order
This data is empty for pending orders
Namespace description and mnemonic
Version
Order-specific data (specified by a view/query task)
This report returns order delta information for a specified time interval.
Order delta information is given on an order-by-order basis. For each order, the last known delta for each node in the view for the specified time interval is shown.
This report gives you an overview of the pending orders and information about their tasks.
When you run the Orders at Tasks report:
If an order includes multiple rows, each row represents an instance of the order. If there are multiple data items for the data, all instances are displayed.
Subprocess tasks are not included in the report.
The actual duration is calculated as follows:
Order at Tasks Report Contents
The Order at Tasks report displays the following data:
Order ID
Reference number
Task description and mnemonic
Task type
State description and mnemonic
User name
Task start date and time
Expected task duration in days
Actual task duration in days
Expected task completion date
Version
Order history sequence ID
Order-specific data
Workgroups
This report shows all completed and pending processes. It includes processes invoked by subprocessing, main processes, and creation processes.
For pending processes, the completion date and time fields are left blank.
Processes Report Contents
The Processes report displays the following data:
Order sequence ID
Order state
Shows the current state the order is in, such as Suspended, Completed, or In Progress.
Execution mode
process_originator_description and mnemonic
A description of the process that took place before the current process.
relationship_to_originator
The report returns a blank to indicate a normal completion and E for a process exception.
Start date and time
The date and time when the order enters the process.
Start position
This is the first task that an order undergoes after it enters the current process. This is a process position mnemonic. It might not be the first task of the process if there is a process exception.
Completion date and time
The date and time at which time the order exits the process.
Last position
This is a position mnemonic to indicate the current pending position for a pending process or last position for a completed process.
Current position
This is a position mnemonic to indicate the current pending position of a pending process and is empty for completed processes.
Completion reason
Expected duration of the process, in days
Actual duration
The real length of time to complete the process.
Version
This report creates a list of pending and completed tasks (excluding subprocess tasks).
This report is grouped by order ID and sorted by start date.
The Tasks report displays the following data:
Order sequence ID
Process (invoking task) description and mnemonic
Indicates in which process the current task is operating.
Task type and mnemonic
Start date and time
The time and date that the order enters the task.
Task expected completion date and time
Task completion date and time
This value is empty for pending tasks at the current state.
Expected duration in days
User name
Status description and mnemonic
Version
For non-order based notifications, the order sequence ID, order type description, order type mnemonic, order source description, and order source mnemonic fields are left blank.
When a notification is sent to multiple users, the report returns multiple rows. Each row corresponds to one user. Only one user acknowledges the notification.
Notifications Report Contents
The Notifications report displays the following data:
Notification description and mnemonic
Order ID
User name
Date and time sent
Date and time acknowledged
This is empty if a notification is not acknowledged by the current user.
Version
About the OSM SDK
In this book, “traditional OSM” refers to the traditional way of installing and maintaining an OSM environment and “OSM cloud native” refers to OSM deployed in a cloud native environment.A number of directories within the SDK are referenced in procedures throughout this guide. For traditional OSM, if you selected Custom installation, then you can choose both the SDK and the Samples to be installed optionally. You can find the SDK inside the OSM_Home directory, where OSM is installed.
You can install only the SDK on a Windows, UNIX, or Oracle Linux machine by running the OSM Installer again and choosing Custom.For OSM cloud native, the SDK is a separate artifact that is available in the download pack.
