A Behaviors Quick Reference
The following pages contain a quick reference for Oracle Communications Order and Service Management (OSM) behaviors which you can print and keep as a work aid.
For comprehensive information on behaviors, see "Modeling Behaviors."
OSM Behavior Type Overview
Table A-1 provides an overview of the OSM behaviors.
Table A-1 Behavior Type Overview
Behavior Type Name Order Synopsis Default Applies To Parent/Child Inheritance
Calculate Behavior
1st
Calculates the value of the data instance node.
None
All value nodes.
Does not inherit.
Style Behavior: Appearance Facet
2nd
Specifies the appearance of a data instance node:
  • DEFAULT: the default appearance should be used
  • FULL: all choices should be rendered at all times.
  • COMPACT: a fixed number of choices should be rendered, with scrolling facilities as needed.
  • MINIMAL: a minimum number of choices should be rendered with a facility to temporarily render additional choices.
Data type specific.For Boolean type fields: CompactFor Lookup type fields: Minimal
Boolean and Lookup type value nodes.
Nodes with Lookup behaviors that have only one displayed column.
Does not inherit.
Style Behavior: CSS Style Facet
2nd
Specifies the HTML CSS style attributes of the data instance node and label.
None
All value and group nodes.
Does not inherit.
Style Behavior: CSS Class Facet
2nd
Specifies the HTML CSS Class name of the data instance node and label.
None
Does not inherit.
Style Behavior: Newline Facet
2nd
Specifies whether a line-break is inserted before the node causing it to be displayed at the start of a new line.
False
All value nodes.
Does not inherit.
Style Behavior: Secret Facet
2nd
Ensures unauthorized users are now allowed to view the contents of nodes containing sensitive information.
True
All value nodes except for modifiable (read/write) lookups and boolean values.
Does not inherit.
Style Behavior: Layout Facet
2nd
Specifies the organization of a group's child nodes into tabbed pages.
None
All group nodes.
Does not inherit.
Style Behavior: Location Facet
2nd
Specifies the tabbed page that this group will be placed in.
None
All group nodes.
Does not inherit.
Information Behavior
3rd
Specifies the label, hint, and help information for the data instance node.
None
Does not inherit.
Relevant Behavior
4th
Indicates whether the data instance node is currently relevant. Data instance nodes with this property evaluating to false are not displayed in the view. If this property is False, other behaviors for this node are not evaluated.
True
If any ancestor node evaluates to false, this value is treated as false. Otherwise, the local value is used.
Lookup Behavior
5th
Specifies a set of dynamic generated choices for the data instance node.
Static lookup values (if any) specified in the OSM Model data dictionary.
All value nodes that are of type lookup, number, or text.
Does not inherit.
Constraint Behavior: Attachment Facet
6th
Specifies a condition that needs to be satisfied for the associated order attachment content to be considered valid.
NOTE: This facet is only supported through programmatic behavior implementations.
True
Attachment nodes.
Does not inherit.
Read Only Behavior
7th
Describes whether the value is restricted from changing. This behavior overrides the static read-only value specified in the OSM Model View Node.
Default specified by the static read-only value on the OSM Model View Node.
If any ancestor node evaluates to true, this value is treated as true. Otherwise, the local value is used.
Event Behavior
8th
Specifies an action to perform when a given event occurs.
None
Value nodes.
Does not inherit.
Constraint Behavior
N/A
Specifies a condition that needs to be satisfied for the associated data instance node to be considered valid. If the condition is not satisfied (evaluates to false), then messages are displayed to the user.
True
Does not inherit.
Data Instance Behavior
N/A
Defines a container in which instances can be declared.
It has no affect on the user interface display of the element for which the behavior is defined.
None
All elements and structures
Children. (Applies to element relationships within a structure. This is different than the inheritance of behaviors between the data dictionary, order, and task levels.
Common Behavior Elements
This section describes the syntax for declaring common behavior elements.
Annotation Element
<annotation>
   <documentation lang=“NCName">… </documentation>
</annotation>
Description Element
<description>string</description>
Instance Element
<instance name=“NCName" lang=“NCName"
   xsi:type=“inlineInstanceType|externalInstanceType">
   For inlineInstanceType, any valid XML document is allowed up to
   4000 characters in length.
   For externalInstanceType, adapter followed by parameter*, and cache*
</instance>
Adapter Element [externalInstanceType]
<adapter>com.mslv.oms.view.rule.adapter.ObjectelAdapter
   |com.mslv.oms.view.rule.adapter.OrderAdapter
   |com.mslv.oms.view.rule.adapter.XMLAttachmentAdapter
   |com.mslv.oms.view.rule.adapter.XMLFileAdapter
   |javaClassNameType<
/adapter>
Parameter Element [externalInstanceType]
<parameter name=“string">string-expr</parameter>
Cache Element
<cache>
   <scope>NONE|NODE|SYSTEM</scope>
   <timeout>positiveInteger</timeout>
   <maxSize>positiveInteger</maxSize>
</cache>
Expression Element
<expression>boolean-expr</expression>
Declaring Behaviors in OSM XML Model
This section describes the syntax for declaring behaviors in OSM XML model.
Data Dictionary Level
<dataDictionary>   element+
   <element name=“nameType" xsi:type=“booleanType|currencyType|dateType
    |dateTimeType|phoneType|groupType|textType|numericType|lookupType">
      description, viewRule*, followed by type specific content
    </element>
</dataDictionary>
Master Order Template Level
<masterOrderTemplate>
   dataNode+
   <dataNode element=“NCName">
      viewRule*, followed by dataNode*
   </dataNode>
</masterOrderTemplate>
View Level
<viewNode element=“NCName">
   editable?, minOccurs?, maxOccurs?, viewRule*, viewNode*
   <editable>boolean</editable>
   <minOccurs>unsignedInt</minOccurs>
   <maxOccurs>unsignedInt</maxOccurs>
</viewNode>
Data Provider Overview
Table A-2 provides an overview of the built-in and custom data providers. See "Using Data Providers to Retrieve Data" for details.
Table A-2 Data Provider Overview
Data Provider Synopsis Parameter
Custom
Uses data provided by a custom-defined Java class.
Implementation-defined
JDBC
Lets OSM query any JDBC database, then use the results within a behavior.
oms:dataSource, oms:sql, in:1 . . . in:n?, out:1 . . . out:n?
Objectel
Uses results of an Objectel Server Extension as an instance.
obj:extensionName, obj:jmsFactory?, obj:queue?, obj:allowErrorResponse?. Other parameters passed to Objectel
Order
Uses data from any OSM order as an external instance.
oms:OrderID, oms:View | oms:OrderHistID
Property File
Retrieves an external Java property file with a given name from the classpath.
oms:url
SOAP
Lets you open up OSM to web services, using the HTTP protocol.
soap.endpoint, soap.action?, soap.envelope, soap.body, soap.header?, oms:credentials.username?, oms:credentials.password?, oms:credentials.scope.host?, soap.allowErrorResponse
XML Attachment
Uses an XML attachment from any OSM order as an instance.
oms:OrderID, oms:FileName
XML File
Uses an XML file from any URL as an instance.
oms:url
XML Validation
Validates a provided XML instance document according to a user-defined schema. The document may be either a URL or an element. The schema may also be a URL or an element.
document, schema
Programmatic Behavior Implementation Overview
Table A-3 provides an overview of the programmatic behavior implementation.
Table A-3 Programmatic Behavior Implementation Overview
Rule Type Name Java Interface Method Names Parameter Types Return Types
Calculate Rule
com.mslv.oms.view.CalculateRule
calculate_<mnemonic>
com.mslv.oms.view.rule.ViewRuleContext
org.w3c.dom.Node
Any Java primitive or descendent of java.lang.Object
Style Rule:
Appearance Facet
com.mslv.oms.view.StyleRule
appearance_<mnemonic>
org.w3c.dom.Node
int
NOTE: Return value must be one of FULL_APPEARANCE,COMPACT_APPEARANCE, MINIMAL_APPEARANCE defined on the StyleRule interface
Style Rule:
CSS Style Facet
style_<mnemonic>
styleForLabel_<mnemonic>
org.w3c.dom.Node
java.util.Map<String, String>
Style Rule:
CSS Class Facet
cssClass_<mnemonic>
cssClassForLabel_<mnemonic>
org.w3c.dom.Node
String
Style Rule:
Newline Facet
newline_<mnemonic>
org.w3c.dom.Node
boolean
Style Rule:
Secret Facet
secret_<mnemonic>
org.w3c.dom.Node
boolean
Information Rule
com.mslv.oms.view.InformationRule
information_<mnemonic>
org.w3c.dom.Node
Relevant Rule
com.mslv.oms.view.RelevantRule
relevant_<mnemonic>
org.w3c.dom.Node
boolean
Lookup Rule
com.mslv.oms.view.LookupRule
lookup_<mnemonic>
org.w3c.dom.Node
String[ ]
String[ ][ ]
java.util.Map<Object,Object>
java.util.Collection<Object>
Constraint Rule
com.mslv.oms.view.ConstraintRule
constraint_<mnemonic>
com.mslv.oms.view.rule.ConstraintContext
org.w3c.dom.Node
String[ ]
com.mslv.oms.view.rule.ConstraintResult
com.mslv.oms.view.rule. ConstraintResult[]
java.util.List<com.mslv.oms.view.rule. ConstraintResult>
Constraint Rule
Attachment Facet
constraint_attachment
org.w3c.dom.Node
java.io.InputStream
String[ ]
Read Only Rule
com.mslv.oms.view.ReadOnlyRule
readonly_<mnemonic
org.w3c.dom.Node
boolean
Event Rule
com.mslv.oms.view.EventRule
event_<mnemonic>
org.w3c.dom.Node
NOTE: Map key must be EventRule.VALUE_CHANGED_EVENT.
Map value must be one of EventRule.REFRESH_ACTION or EventRule.SAVE_ACTION
