7 DTLS Encryption Protocol
Enable DTLS Protocol
Access the global security settings by navigating to Global, Basic Settings.
CipherSuite Name
- AES128-GCM-SHA256 (default)
- AES128-GCM-SHA256
Enable Session Renegotiation
When Session Renegotiation is enabled, a new handshake is established over the existing SSL connection and a new set of session keys are generated. When the current session expires, session renegotiation is initiated.
DTLS Session Lifetime
Whenever a new DTLS session is created, it is assigned a maximum session lifetime. This value is used only when Session Renegotiation is enabled.
