Properties Tab
Use the Properties tab for defining values for the service action.
Field | Use |
Level |
Select a sequence level for the service action within the work order. See ASAP Developer's Guide. |
Service Action Completion Event |
(Optional) Select an event from the list that will be triggered when the service action is complete. See ASAP Developer's Guide and ASAP System Administrator's Guide. |
Rollback |
Select the Rollback check box to configure rollback on the service action. Ensure to select a rollback value in the Atomic Action(s) tab. |
Service Action Failure Event |
(Optional) Select an event from the list that will be called when the service action fails. See ASAP Developer's Guide and ASAP System Administrator's Guide. |
