2 Design Studio System Requirements
This chapter lists the minimum system requirements necessary for individual Design Studio users to successfully install and run Oracle Communications Service Catalog and Design - Design Studio.
See "Hardware Sizing Guidelines" for information about hardware sizing recommendations.
Software Requirements
This section describes the software requirements required to install and use Design Studio.
Operating System Requirements
Table 2-1 lists the operating systems supported by Design Studio.
Table 2-1 Operating System Requirements
| Product | Version |
Windows 10 |
64-bit |
Additional Software Requirements
Table 2-2 lists the additional software required to install and use Design Studio.
Table 2-2 Additional Software Requirements
| Product | Version |
Oracle Enterprise Pack for Eclipse |
Version 12.2.1.9 (or later), based on Eclipse Photon (4.8.0) |
Java SE JDK |
Java 8 (use the latest service pack) |
Eclipse Business Intelligence, Reporting, and Charting feature |
Eclipse Graphical Editing Framework Zest Visualization Toolkit feature |
Hardware Requirements
Table 2-3 lists the minimum hardware required to install and use Design Studio.
Application performance is directly related to processor performance and memory. For larger projects, consider increasing the processor power and the initial memory and maximum memory settings for the Java heap size.
Table 2-3 Minimum Hardware Requirements
| Component | Requirement |
Processor |
Minimum Intel dual core (or equivalent) |
Memory |
Recommended 8 GB or above |
Monitor |
Screen Resolution:
Design Studio Product Compatibility
Design Studio is compatible with specific Oracle Communications applications releases. The Compatibility Matrix guide is available on the Oracle Help Center.
Design Studio Feature Dependencies
The Design Studio installation is an aggregation of individual features. When you install Design Studio, you install the full feature set (you do not install individual features). The following Design Studio individual features are included in the installation:
Design Studio Platform
Design Studio Domain Modeling
Design Studio for Activation
Design Studio for Activation SRT
Design Studio for IP Service Activator
Design Studio for Order and Service Management
Design Studio for Order and Service Management Orchestration
Design Studio Integration (includes the Design Studio Activation Task feature)
Design Studio for Network Integrity
Design Studio for Unified Inventory Management
Design Studio Design Pattern
Design Studio Guided Assistance
Design Studio Reference Reports
