Order Editor Permissions Tab
Use the Order editor Permissions tab to assign roles to the order and to customize the role settings. The following table describes the fields on the Order editor Permissions tab.
Field | Use |
Roles |
Add the roles that will have access to this order type in the Task web client. Click Select to select from existing roles or New to create a new role. To view permissions for existing roles, select the role and click Open. The system displays the role in the Role editor, where you can view the permissions assigned to the role. Select a role and click Remove if you want to delete an associated role from the task. |
When modeling order permissions, see the following topics for more information:
