Properties Global Parameter Binding View
Use the Global Parameter Binding view to review and edit mapping information between OSM data and global parameters.
Field | Use |
Parameter |
Displays the parameter label. |
Condition |
Enter the condition that determines whether the parameter is included in the request. If the condition evaluates to true, the parameter is sent. |
Binding Type |
Select this option to define the expression path as an XPath Expression or as an XSLT Snippet. For example, you might define the expression path as an XSLT snippet if you are mapping OSM data to a compound global parameter. |
Binding |
Displays the mapping information for a global parameter. Note: If you are mapping OSM data to a compound parameter, you can reference the CreateOrderByValueRequest_generated.xsl file to ensure that all XPath expressions are defined correctly. To review the CreateOrderByValueRequest_generated.xsl file, switch to the Java perspective and click the Package Explorer tab. Each activation task is listed in the Activation directory in the project resources folder. |
