Properties Activation Order Header Binding View
Use the Activation Order Header Binding view to review and edit mapping information between OSM data and Activation order header parameters.
Field | Use |
Order Header |
Displays the parameter label. |
Condition |
Enter the condition that determines whether the parameter is included in the request. If the condition evaluates to true, the parameter is sent. |
Binding Type |
Select to define the expression path as an XPath Expression or as an XSLT Snippet. For example, you might define the expression path as an XSLT snippet if you are mapping OSM data to a compound order header parameter. |
Binding |
Displays the mapping information for an order header parameter. Note: If you are mapping OSM data to a compound parameter, you can reference the CreateOrderByValueRequest_generated.xsl file to ensure that all XPath expressions are defined correctly. To review the CreateOrderByValueRequest_generated.xsl file, switch to the Java perspective and click the Package Explorer tab. Each activation task is listed in the Activation directory in the project resources folder. |
