Activation Test Case Editor
Use the Activation Test Case editor to test, within Design Studio, the activation work order completion for a cartridge project to verify that the work order is sent to the ASAP environment. In the Studio Projects view, double-click an activation test case entity to open the Activation Test Case editor.
See the following topics:
Field | Use |
Description |
Specify a description for the Activation Test Case editor. |
Test Order Primary Key Pattern |
Specify a pattern for the primary key that identifies a test case on ASAP server. See "About Test Case Configuration" for more information. |
Timeout (seconds) |
Specify the time, in seconds, for a work order to process. Beyond the specified time, the work order is dropped from the work order processing queue. |
Order Completion Status |
Select a notification for a work order that is sent to an ASAP user on work order completion or failure. |
Environment |
Select an environment for a work order to get processed. |
Run |
Click to run the test case. |
