Activation Test Case Editor Order Data Tab
Use the Order Data tab to define global parameters and extended work order properties for the work orders that will be tested using the test case.
Field | Use |
Add |
In the Global Parameters area, click to add a global parameter. You can use a global parameter in place of identical values of service action parameters in the work order. See "Creating Activation Test Cases" for more information. In the Extended Work Order Properties area, click to add a property that needs to be enabled in ASAP. See ASAP System Administrator's Guide and ASAP Developer's Guide. |
Remove |
In the Global Parameters area, click to remove a global parameter. In the Extended Work Order Properties area, click to remove an extended work order property. |
