Working with Design Studio Menus
Design Studio has two types of menus: the Studio menu and the context menu. Both provide access to many of the same actions. The Studio menu is in the Design Studio Workbench menu that appears at the top of the Design Studio interface. The Studio menu enables you to create new Design Studio entities. The context menu is accessed by right-clicking in a Design Studio view or editor, and enables you to configure Design Studio entities.
The Studio menu contains the following:
Menu Option | Use |
New |
Select to access:
Show Environment Perspective |
Select to switch to the Environment perspective. |
Show Design Perspective |
Select to switch to the Design perspective. |
Guided Assistance |
Select to open the Design Studio Guided Assistance dialog box, which provides a range of context-sensitive learning aids mapped to the editor or view in focus. See "Using Guided Assistance" for more information. |
Import Studio Project |
Select to import data from external sources into your Design Studio workspaces. See "Importing Projects" for more information. |
Design Pattern |
Select to apply a design pattern using the Design Pattern wizard. See "Working with Design Patterns" and Design Studio Developer's Guide for more information. |
Deploy |
Perform deploy actions directly from the Design perspective. This enables you to deploy cartridges without needing to switch to the Environment perspective. Additionally, you can select to access actions for Optimize Deploy. See "Deploying Cartridge Projects with Optimize Deploy" for more information. |
Related Topics
