Activation Tab
Use the Activation tab to modify the run-time type parameter of the data element added in the Parameters tab of the Atomic Action editor. This modification is specific to the atomic action entity.
| Field | Use |
Compound Member Label |
Displays the same name as the parameter in the Parameters area. You can use the compound member in the code generated Java Action processors (of Java code) to access the compound members of a compound parameter. To rename the compound member, you must select Refactoring from the Atomic Action editor context menu. See "About the Atomic Action Editor Context Menu" for more information. |
Runtime Type |
Displays the parameter as in the Data Dictionary for this data element. You can select any one of the following run-time type parameters, specific to this atomic action entity, and define in this tab:
Depending on the run-time type parameter, the labels in this tab are visible. See ASAP Developer's Guide for more information on parameter types. |
Atomic Action Label |
Displays the name of the parameter in the atomic action as in the Data Dictionary for this data element. You can specify a unique name for the atomic action, but this name will be specific to this atomic action entity. |
Service Action Label |
Displays the name of the parameter in a service action mapped to this atomic action. The name is unique and is same as the data element name. |
Indexed |
Select the check box if you want to index the run-time type parameter. |
Data Restrictions |
Specify any restriction on the value of the parameter. |
Dependent XML |
Displays the path of the XML that defines the parameter. This field is available only for the XPATH run-time type parameter. |
