Details Tab
Use the Details tab to edit the data element display name and define specific constraint values. When you select a data element in the Parameters area, the details for the selected data element appear in the Parameter Details area.
| Field | Use |
Select |
(Optional) Select a data element that exists in the Data Dictionary, in case you want the selected parameter, in the Parameters area, to behave like a data element in the data schema. Click the Type label to open the data element. |
Primitive Type |
Displays the data type for simple data elements as in the data schema. |
Name |
Displays the name of the data element as in the data schema. |
Display Name |
Edit the data element display name. The Atomic Action editor supports multiple languages for this field. The field adjacent to Display Name displays your language. You can define a Display Name field value for any language you select from the list. If your preferences are set up to work in one language only, the system displays only the [default] option. See "Defining Language Preferences" for more information. |
Path |
Displays to which atomic action the parameter belongs.This field is read only. |
Namespace |
Not applicable in Activation. |
Multiplicity |
Select any one of the following:
Abstract and Internal |
Deprecated |
Select to discourage use of the data element. |
Length |
Specify the minimum and maximum length for String data type. This field is read only for data elements that inherit from a parent element. You must define the minimum and maximum lengths with a non-negative integer between 0 and 999999999. Select Unbounded to define the maximum length as 999999999. |
Default |
Specify a default value. If there is no value in the work order for the parameter the default value is used. |
