SIPREC Call Flows
This section provides examples of call flow scenarios that can occur in a SIPREC environment. SIP recording call flow examples include:
For Selective Recording:
The SBC does not support early media recording in SIPREC.
Selective Recording
Normal Call (recording required)
The following illustration shows a normal call using selective recording with recording required. For SDP and Metadata information in Notes 1 and 2 , see Sample SDP and Metadata.
The selective recording normal call call flow is described in the following list.
I
  • UA-A sends INVITE to Oracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller forwards INVITE with SDP and metadata to SRS.
  • SRS responds with OK to Oracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller sends INVITE to UA-B.
  • UA-B responds with OK to Oracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller sends re-INVITE with SDP and metadata
 changes to SRS.
  • Oracle Communications Session Border Controller forwards OK response to UA-A.
  • RTP stream initiated between UA-A and Oracle Communications Session Border Controller.
  • RTP stream initiated between Oracle Communications Session Border Controller and UA-B.
  • RTP stream initiated between Oracle Communications Session Border Controller and SRS.
  • UA-A sends BYE to Oracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller responds with OK to UA-A.
  • Oracle Communications Session Border Controller sends BYE to Oracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller sends BYE to UA-B.
  • Oracle Communications Session Border Controller sends BYE to SRS.
The following sample SDP and Metadata pertain to Notes 1 and 2 in the previous Call Flow diagram.
--[Note 1]------------------------------
Content-Type: application/sdp
v=0
o=- 171 213 IN IP4 10.0.0.2
s=-
c=IN IP4 10.0.0.1
t=0 0
m=audio 6000 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=label:1
Content-Type: application/rs-metadata+xml
Content-Disposition: recording-session
<?xml version='1.0' encoding='UTF-8'?>
<recording xmlns='urn:ietf:params:xml:ns:recording'>
        <dataMode>complete</dataMode>
        <session id="urn:uuid:79b2fcd8-5c7f-455c-783f-db334e5d57d0">
                <start-time>2011-06-27T17:03:57</start-time>
        </session>
        <participant id="urn:uuid:10ac9063-76b7-40bb-4587-08ba290d7327" session="urn:uuid:79b2fcd8-5c7f-455c-783f-db334e5d57d0">
                <aor>sip:sipp@168.192.24.40</aor>
                <name>sipp </name>
                <send>urn:uuid:07868c77-ef8e-4d6f-6dd5-a02ff53a1329</send>
        </participant>
        <participant id="urn:uuid:797c45f5-e765-4b12-52b0-d9be31138529" session="urn:uuid:79b2fcd8-5c7f-455c-783f-db334e5d57d0">
                <aor>sip:service@168.192.24.60</aor>
                <name>sut </name>
        </participant>
        <stream id="urn:uuid:4a72a1ed-abb2-4d7c-5f4d-6d4c36e2d4ec" session="urn:uuid:79b2fcd8-5c7f-455c-783f-db334e5d57d0">
                <mode>separate</mode>
				<label>1</label>
        </stream>
</recording>
--[Note 2]------------------------------
v=0
s=-
c=IN IP4 10.0.0.1
t=0 0
a=label:1
m=audio 6002 RTP/AVP 0
a=label:2
        <dataMode>partial</dataMode>
        </session>
                <name>sut </name>
                <send>urn:uuid:4a72a1ed-abb2-4d7c-5f4d-6d4c36e2d4ec</send>
                <start-time>2011-06-27T17:03:58</start-time>
        </participant>
        <stream id="urn:uuid:07868c77-ef8e-4d6f-6dd5-a02ff53a1329" session="urn:uuid:79b2fcd8-5c7f-455c-783f-db334e5d57d0">
				<label>2</label>
        </stream>
</recording>
Normal Call (recording not required)
The following illustration shows a normal call using selective recording with recording optional.
The normal call without required recording call flow is described in the following list.
  • Oracle Communications Session Border Controller forwards INVITE to UA-B.
  • Oracle Communications Session Border Controller sends INVITE with SDP and metadata to SRS.
  • RTP stream initiated between UA-A, Oracle Communications Session Border Controller,
 and UA-B.
REFER Pass-Through Call (REFER handled by User Agent)
The following illustration shows a REFER pass-through call using selective recording and the User Agent (UA) handling the REFER on the call. Recording is required in this call flow.
The REFER pass-through call handled by the UA call flow is described below.
  • Oracle Communications Session Border Controller forwards INVITE with SDP Offer and metadata to SRS.
  • Oracle Communications Session Border Controller sends re-INVITE with SDP and metadata changes to SRS.
  • UA-A sends REFER-TO: C to Oracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller forwards REFER-TO: C to UA-B.
  • UA-B responds with 202 ACCEPTED to Oracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller forwards 202 ACCEPTED to UA-A.
  • UA-B sends INVITE TO: C to Oracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller sends INVITE to UA-C.
  • UA-C responds with OK to Oracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller forwards OK response to UA-B.
  • Oracle Communications Session Border Controller sends NOTIFY with OK reponse to UA-A.
  • Oracle Communications Session Border Controller sends re-INVITE to SRS with new SDP and metadata, adds participant C, stops participant A .
  • RTP stream initiated between Oracle Communications Session Border Controller and UA-C.
  • UA-C sends BYE to Oracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller responds with OK to UA-C.
MIB Tree Structure
MIBs are arranged in a tree-structured fashion, similar in many ways to a operating system directory structure of files.
SRS Indicates Busy in Call (recording not required)
The following illustration shows the Session Recording Server (SRS) is BUSY for a call session. Recording is not required in this call flow.
The SRS indicates busy without recording required call flow is described below.
  • Oracle Communications Session Border Controller sends INVITE to SRS1 with SDP and metadata.
  • SRS1 responds to Oracle Communications Session Border Controller with 436 BUSY HERE.
  • RTP stream initiated between UA-A andOracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller sends INVITE to SRS2 with SDP and metadata.
  • SRS2 responds with OK to Oracle Communications Session Border Controller.
  • RTP stream initiated between Oracle Communications Session Border Controller and SRS2.
  • Oracle Communications Session Border Controller sends BYE to SRS2.
Call Transfer Scenario (recording required)
The following illustration shows the Re-INVITE from Oracle Communications Session Border Controller to SRS on receiving in-dialog-requests INVITE/ UPDATE/ Re-INVITE during call session. Recording is required in this call flow.
The call transfer with required recording call flow is described below.
  • Oracle Communications Session Border Controller updates the INVITE message to the Metadata in SRS.
  • Oracle Communications Session Border Controller sends an INVITE to UA-B.
  • Oracle Communications Session Border Controller sends INVITE to SRS in Recording Session.
  • UA-A sends an UPDATE message to Oracle Communications Session Border Controller.
  • Oracle Communications Session Border Controller forwards UPDATE message to UA-B.
  • Oracle Communications Session Border Controller forwards OK to UA-A..
  • Oracle Communications Session Border Controller sends a re-INVITE to SRS in Recording Session.
  • Oracle Communications Session Border Controller forwards BYE to UA-B.
  • Oracle Communications Session Border Controller forwards OK to UA-B.
  • Oracle Communications Session Border Controller sends BYE to SRS in Recording Session.
  • SRS responds with OK to Oracle Communications Session Border Controller in Recording Session.
