Dependency RPMs
This section describes the RPMs needed to install Session Monitor without an internet connection.
BaseOS Latest: https://yum.oracle.com/repo/OracleLinux/OL8/baseos/latest/x86_64/index.html.
- bash-4.4.20-4.el8_6.x86_64.rpm
- brotli-1.0.6-3.el8.x86_64.rpm
- bzip2-libs-1.0.6-26.el8.x86_64.rpm
- c-ares-1.13.0-6.el8.x86_64.rpm
- coreutils-8.30-13.0.1.el8.x86_64.rpm
- coreutils-single-8.30-13.0.1.el8.x86_64.rpm
- dejavu-sans-fonts-2.35-7.el8.noarch.rpm
- dejavu-serif-fonts-2.35-7.el8.noarch.rpm
- freetype-2.9.1-9.el8.x86_64.rpm
- glib2-2.56.4-159.0.1.el8.x86_64.rpm
- glibc-2.28-211.0.1.el8.x86_64.rpm
- gnutls-3.6.16-5.el8_6.x86_64.rpm
- krb5-libs-1.18.2-22.0.1.el8_7.x86_64.rpm
- libcap-2.48-4.el8.x86_64.rpm
- libcurl-7.61.1-25.el8_7.1.x86_64.rpm
- libcurl-minimal-7.61.1-25.el8_7.1.x86_64.rpm
- libgcc-8.5.0-16.0.2.el8_7.x86_64.rpm
- libgcrypt-1.8.5-7.el8_6.x86_64.rpm
- libgomp-8.5.0-16.0.2.el8_7.x86_64.rpm
- libibverbs-41.0-1.el8.x86_64.rpm
- libicu-60.3-2.el8_1.x86_64.rpm
- libnghttp2-1.33.0-3.el8_2.1.x86_64.rpm
- libnl3-3.7.0-1.el8.x86_64.rpm
- libpcap-1.9.1-5.el8.x86_64.rpm
- libpng-1.6.34-5.el8.x86_64.rpm
- libssh-0.9.6-3.el8.x86_64.rpm
- libstdc++-8.5.0-16.0.2.el8_7.x86_64.rpm
- libuuid-2.32.1-39.el8_7.x86_64.rpm
- libxcrypt-4.1.1-6.el8.x86_64.rpm
- libxml2-2.9.7-15.el8_7.1.x86_64.rpm
- libzstd-1.4.4-1.0.1.el8.x86_64.rpm
- lshw-B.02.19.2-6.el8.x86_64.rpm
- numactl-devel-2.0.12-13.el8.x86_64.rpm
- numactl-libs-2.0.12-13.el8.x86_64.rpm
- openssl-1.1.1k-7.el8_6.x86_64.rpm
- openssl-libs-1.1.1k-7.el8_6.x86_64.rpm
- openssl-perl-1.1.1k-7.el8_6.x86_64.rpm
- pciutils-3.7.0-1.el8.x86_64.rpm
- pcre2-10.32-3.el8_6.x86_64.rpm
- python3-requests-2.20.0-2.1.el8_1.noarch.rpm
- python3-setuptools-39.2.0-6.el8.noarch.rpm
- selinux-policy-3.14.3-108.0.2.el8_7.1.noarch.rpm
- selinux-policy-targeted-3.14.3-108.0.2.el8_7.1.noarch.rpm
- snappy-1.1.8-3.el8.x86_64.rpm
- sudo-1.8.29-8.el8_7.1.x86_64.rpm
- systemd-libs-239-68.0.2.el8_7.2.x86_64.rpm
- xmlrpc-c-1.51.0-8.el8.x86_64.rpm
- xmlrpc-c-client-1.51.0-8.el8.x86_64.rpm
- xz-libs-5.2.4-4.el8_6.x86_64.rpm
- unzip-6.0-46.0.1.el8.x86_64.rpm
- zlib-1.2.11-21.el8_7.x86_64.rpm
- libcom_err-devel-1.45.6-5.el8.x86_64.rpm
- keyutils-libs-devel-1.5.10-9.el8.x86_64.rpm
- libpkgconf-1.4.2-1.el8.x86_64.rpm
- libkadm5-1.18.2-21.0.1.el8.x86_64.rpm
- krb5-devel-1.18.2-21.0.1.el8.x86_64.rpm
- libsepol-devel-2.9-3.el8.x86_64.rpm
- libselinux-devel-2.9-6.el8.x86_64.rpm
- libverto-devel-0.3.2-2.el8.x86_64.rpm
- pcre2-devel-10.32-3.el8_6.x86_64.rpm
- pcre2-utf16-10.32-3.el8_6.x86_64.rpm
- openssl-devel-1.1.1k-7.el8_6.x86_64.rpm
- perl-Carp-1.42-396.el8.noarch.rpm
- pcre2-utf32-10.32-3.el8_6.x86_64.rpm
- perl-Data-Dumper-2.167-399.el8.x86_64.rpm
- perl-Errno-1.28-421.el8.x86_64.rpm
- perl-Exporter-5.72-396.el8.noarch.rpm
- perl-File-Path-2.15-2.el8.noarch.rpm
- perl-File-Temp-0.230.600-1.el8.noarch.rpm
- perl-Encode-2.97-3.el8.x86_64.rpm
- perl-Getopt-Long-2.50-4.el8.noarch.rpm
- perl-HTTP-Tiny-0.074-1.el8.noarch.rpm
- perl-IO-1.38-421.el8.x86_64.rpm
- perl-MIME-Base64-3.15-396.el8.x86_64.rpm
- perl-PathTools-3.74-1.el8.x86_64.rpm
- perl-Pod-Escapes-1.07-395.el8.noarch.rpm
- perl-Pod-Perldoc-3.28-396.el8.noarch.rpm
- perl-Pod-Simple-3.35-395.el8.noarch.rpm
- perl-Pod-Usage-1.69-395.el8.noarch.rpm
- perl-Scalar-List-Utils-1.49-2.el8.x86_64.rpm
- perl-Socket-2.027-3.el8.x86_64.rpm
- perl-Storable-3.11-3.el8.x86_64.rpm
- perl-Term-ANSIColor-4.06-396.el8.noarch.rpm
- perl-Term-Cap-1.17-395.el8.noarch.rpm
- perl-Text-ParseWords-3.30-395.el8.noarch.rpm
- perl-Text-Tabs+Wrap-2013.0523-395.el8.noarch.rpm
- perl-Time-Local-1.280-1.el8.noarch.rpm
- perl-Unicode-Normalize-1.25-396.el8.x86_64.rpm
- perl-constant-1.33-396.el8.noarch.rpm
- perl-macros-5.26.3-421.el8.x86_64.rpm
- perl-interpreter-5.26.3-421.el8.x86_64.rpm
- perl-parent-0.237-1.el8.noarch.rpm
- perl-libs-5.26.3-421.el8.x86_64.rpm
- perl-threads-2.21-2.el8.x86_64.rpm
- perl-podlators-4.11-1.el8.noarch.rpm
- perl-threads-shared-1.58-2.el8.x86_64.rpm
- pkgconf-1.4.2-1.el8.x86_64.rpm
- pkgconf-m4-1.4.2-1.el8.noarch.rpm
- pkgconf-pkg-config-1.4.2-1.el8.x86_64.rpm
- zlib-devel-1.2.11-20.el8.x86_64.rpm
- python3-chardet-3.0.4-7.el8.noarch.rpm
- python3-urllib3-1.24.2-5.0.1.el8.noarch.rpm
- python3-idna-2.5-5.el8.noarch.rpm
- net-snmp-libs-5.8-25.0.2.el8_7.1.x86_64.rpm
- python3-pysocks-1.6.8-3.el8.noarch.rpm
- lm_sensors-libs-3.4.0-23.20180522git70f7e08.el8.x86_64.rpm
- dejavu-fonts-common-2.35-7.el8.noarch.rpm
- fontpackages-filesystem-1.44-22.el8.noarch.rpm
- libmetalink-0.1.3-7.el8.x86_64.rpm
- cronie-1.5.2-8.el8.x86_64.rpm
- tar-1.30-6.el8_7.1.x86_64.rpm
- net-tools-2.0-0.52.20160912git.el8.x86_64.rpm
- avahi-libs-0.7-20.el8.x86_64.rpm
- binutils-2.30-117.0.3.el8.x86_64.rpm
- checkpolicy-2.9-1.el8.x86_64.rpm
- efivar-libs-37-4.el8.x86_64.rpm
- elfutils-devel-0.187-4.el8.x86_64.rpm
- elfutils-libelf-devel-0.187-4.el8.x86_64.rpm
- environment-modules-4.5.2-2.el8.x86_64.rpm
- glibc-devel-2.28-211.0.1.el8.x86_64.rpm
- glibc-headers-2.28-211.0.1.el8.x86_64.rpm
- kernel-headers-4.18.0-425.13.1.el8_7.x86_64.rpm
- libbabeltrace-1.5.4-4.el8.x86_64.rpm
- libgfortran-8.5.0-16.0.2.el8_7.x86_64.rpm
- libquadmath-8.5.0-16.0.2.el8_7.x86_64.rpm
- libtool-ltdl-2.4.6-25.el8.x86_64.rpm
- libxcrypt-devel-4.1.1-6.el8.x86_64.rpm
- libzstd-devel-1.4.4-1.0.1.el8.x86_64.rpm
- make-4.2.1-11.el8.x86_64.rpm
- mokutil-0.6.0-1.0.1.el8.x86_64.rpm
- policycoreutils-python-utils-2.9-20.0.1.el8.noarch.rpm
- python3-audit-3.0.7-4.el8.x86_64.rpm
- python3-libsemanage-2.9-9.el8.x86_64.rpm
- python3-policycoreutils-2.9-20.0.1.el8.noarch.rpm
- python3-setools-4.3.0-3.el8.x86_64.rpm
- tcl-8.6.8-2.el8.x86_64.rpm
- xz-devel-5.2.4-4.el8_6.x86_64.rpm
- zip-3.0-23.el8.x86_64.rpm
- elfutils-debuginfod-client-devel-0.187-4.el8.x86_64.rpm
- kernel-devel-4.18.0-425.13.1.el8_7.x86_64.rpm
AppStream Latest: https://yum.oracle.com/repo/OracleLinux/OL8/appstream/x86_64/index.html
- python39-3.9.13-2.module+el8.7.0+20879+a85b87b0.x86_64.rpm
- python39-libs-3.9.13-2.module+el8.7.0+20879+a85b87b0.x86_64.rpm
- python39-pyyaml-5.4.1-1.module+el8.5.0+20364+c7fe1181.x86_64.rpm
- python39-pip-20.2.4-7.module+el8.6.0+20625+ee813db2.noarch.rpm
- python39-pip-wheel-20.2.4-7.module+el8.6.0+20625+ee813db2.noarch.rpm python39-setuptools-wheel-50.3.2-4.module+el8.5.0+20364+c7fe1181.noarch.rpm
- python39-setuptools-wheel-50.3.2-4.module+el8.5.0+20364+c7fe1181.noarch.rpm
- libX11-1.6.8-5.el8.x86_64.rpm libjpeg-turbo-1.5.3-12.el8.x86_64.rpm
- libjpeg-turbo-1.5.3-12.el8.x86_64.rpm
- libmaxminddb-1.2.0-10.el8.x86_64.rpm
- libsmi-0.4.8-23.el8.x86_64.rpm libtiff-4.0.9-26.el8_7.x86_64.rpm
- libtiff-4.0.9-26.el8_7.x86_64.rpm
- net-snmp-5.8-25.0.2.el8_7.1.x86_64.rpm
- python3-reportlab-3.4.0-8.el8.x86_64.rpm
- sbc-1.3-9.el8.x86_64.rpm
- whois-5.5.1-2.el8.x86_64.rpm
- vsftpd-3.0.3-35.el8.x86_64.rpm
- drpm-0.4.1-3.el8.x86_64.rpm
- createrepo_c-libs-0.17.7-6.el8.x86_64.rpm
- createrepo_c-0.17.7-6.el8.x86_64.rpm
- perl-JSON-2.97.001-2.el8.noarch.rpm
- perl-Memoize-1.03-421.el8.noarch.rpm
- perl-Time-HiRes-1.9758-2.el8.x86_64.rpm
- libxcb-1.13.1-1.el8.x86_64.rpm
- libwebp-1.0.0-5.el8.x86_64.rpm
- python3-pillow-5.1.1-18.el8_5.x86_64.rpm
- mariadb-connector-c-3.1.11-2.el8_3.x86_64.rpm
- net-snmp-agent-libs-5.8-25.0.2.el8_7.1.x86_64.rpm
- libXau-1.0.9-3.el8.x86_64.rpm
- jbigkit-libs-2.1-14.el8.x86_64.rpm
- fribidi-1.0.4-9.el8.x86_64.rpm
- harfbuzz-1.7.5-3.el8.x86_64.rpm
- libX11-common-1.6.8-5.el8.noarch.rpm
- graphite2-1.3.10-10.el8.x86_64.rpm
- lcms2-2.9-2.el8.x86_64.rpm
- openjpeg2-2.4.0-5.el8.x86_64.rpm
- whois-nls-5.5.1-2.el8.noarch.rpm
- wget-1.19.5-10.0.1.el8.x86_64.rpm
- gcc-toolset-11-11.1-1.el8.x86_64.rpm
- boost-atomic-1.66.0-13.el8.x86_64.rpm
- boost-chrono-1.66.0-13.el8.x86_64.rpm
- boost-date-time-1.66.0-13.el8.x86_64.rpm
- boost-filesystem-1.66.0-13.el8.x86_64.rpm
- boost-regex-1.66.0-13.el8.x86_64.rpm
- boost-system-1.66.0-13.el8.x86_64.rpm
- boost-thread-1.66.0-13.el8.x86_64.rpm
- boost-timer-1.66.0-13.el8.x86_64.rpm
- cpp-8.5.0-15.0.1.el8.x86_64.rpm
- ctags-5.8-22.el8.x86_64.rpm
- gc-7.6.4-3.el8.x86_64.rpm
- gcc-8.5.0-15.0.1.el8.x86_64.rpm
- gcc-toolset-11-annobin-docs-10.23-1.el8.noarch.rpm
- gcc-toolset-11-binutils-2.36.1-2.0.1.el8.x86_64.rpm
- gcc-toolset-11-dwz-0.14-2.el8.x86_64.rpm
- gcc-toolset-11-dyninst-11.0.0-2.el8.x86_64.rpm
- gcc-toolset-11-elfutils-0.185-5.el8.x86_64.rpm
- gcc-toolset-11-elfutils-debuginfod-client-0.185-5.el8.x86_64.rpm
- gcc-toolset-11-elfutils-libelf-0.185-5.el8.x86_64.rpm
- gcc-toolset-11-elfutils-libs-0.185-5.el8.x86_64.rpm
- gcc-toolset-11-gcc-11.2.1-9.1.0.3.el8.x86_64.rpm
- gcc-toolset-11-gcc-c++-11.2.1-9.1.0.3.el8.x86_64.rpm
- gcc-toolset-11-gcc-gfortran-11.2.1-9.1.0.3.el8.x86_64.rpm
- gcc-toolset-11-gdb-10.2-5.0.1.el8.x86_64.rpm
- gcc-toolset-11-libquadmath-devel-11.2.1-9.1.0.3.el8.x86_64.rpm
- gcc-toolset-11-libstdc++-devel-11.2.1-9.1.0.3.el8.x86_64.rpm
- gcc-toolset-11-ltrace-0.7.91-1.el8.x86_64.rpm
- gcc-toolset-11-make-4.3-2.el8.x86_64.rpm
- gcc-toolset-11-perftools-11.1-1.el8.x86_64.rpm
- gcc-toolset-11-runtime-11.1-1.el8.x86_64.rpm
- gcc-toolset-11-strace-5.13-7.el8.x86_64.rpm
- gcc-toolset-11-systemtap-4.5-6.el8.x86_64.rpm
- gcc-toolset-11-systemtap-client-4.5-6.el8.x86_64.rpm
- gcc-toolset-11-systemtap-devel-4.5-6.el8.x86_64.rpm
- gcc-toolset-11-systemtap-runtime-4.5-6.el8.x86_64.rpm
- gcc-toolset-11-toolchain-11.1-1.el8.x86_64.rpm
- gcc-toolset-11-valgrind-3.17.0-6.el8.x86_64.rpm
- guile-2.0.14-7.0.1.el8.x86_64.rpm
- isl-0.16.1-6.el8.x86_64.rpm
- libatomic_ops-7.6.2-3.el8.x86_64.rpm
- libipt-1.6.1-8.el8.x86_64.rpm
- libmpc-1.1.0-9.1.el8.x86_64.rpm
- nspr-4.34.0-3.el8_6.x86_64.rpm
- nss-3.79.0-10.el8_6.x86_64.rpm
- nss-softokn-3.79.0-10.el8_6.x86_64.rpm
- nss-softokn-freebl-3.79.0-10.el8_6.x86_64.rpm
- nss-sysinit-3.79.0-10.el8_6.x86_64.rpm
- nss-util-3.79.0-10.el8_6.x86_64.rpm
- scl-utils-2.0.2-15.0.1.el8.x86_64.rpm
- source-highlight-3.1.8-17.el8.x86_64.rpm
- tbb-2018.2-9.el8.x86_64.rpm
- gcc-toolset-11-gcc-gdb-plugin-11.2.1-9.1.0.3.el8.x86_64.rpm
- gcc-toolset-11-binutils-devel-2.36.1-2.0.1.el8.x86_64.rpm
- gcc-toolset-11-elfutils-libelf-devel-0.185-5.el8.x86_64.rpm
Developer EPEL Packages: https://yum.oracle.com/repo/OracleLinux/OL8/developer/EPEL/x86_64/index.html
- gperftools-libs-2.7-9.el8.x86_64.rpm
- jemalloc-5.2.1-2.el8.x86_64.rpm
- openpgm-5.2.122-21.el8.x86_64.rpm
- spandsp-0.0.6-9.el8.x86_64.rpm
- zeromq-4.3.4-2.el8.x86_64.rpm
- libimagequant-2.12.5-1.el8.x86_64.rpm
- libraqm-0.7.0-4.el8.x86_64.rpm
- libunwind-1.3.1-3.el8.x86_64.rpm
UEK Release 7 Packages: https://yum.oracle.com/repo/OracleLinux/OL8/UEKR7/x86_64/index.html
- kernel-uek-devel-5.15.0-3.60.5.1.el8uek.x86_64.rpm
