UCaaS CCaaS - Changes in the Message Flow Window
In the Message flow window, for a MS Teams to PSTN DR Call, Operations Monitor now supports the ability to see the signaling and media information for the MS Teams/ UCaaS. Similarly, for a PSTN to MS Teams Direct Routing call as well.
UCaaS CCaaS introduces 2 new messages in the Message Flow based on the Meta Data
received from UCaaS CCaaS Service (MS Teams) - UCaaS_CCaaS Media and UCaaS_CCaaS
Signaling:
- UCaaS_CCaaS Signalling: All contents of Meta Data except "Segments" data part is considered as UCaaS_CCaaS Signalling data.
- UCaaS_CCaaS Media: "Segments" data part of Meta Data is considered as UCaaS_CCaaS Media data.
Reflexive IP Address >> IP Address >> Relay IP Address >> 1.1.1.1(Static IP)
These 2 UCaaS CCaaS messages are available in all Message Flow options like
SVG, PDF and Message Flow Download.
![PSTN to MS Teams Message Flow PSTN to MS Teams Message Flow](img/sm_52_ucas_cas_msg_flow.png)
![Signal Leg Signal Leg](img/sm_52_ucas_cas_signal_leg.png)
![Signal Leg Signal Leg](img/sm_52_ucas_cas_signal_leg2.png)
These 2 new flows in Message Flow do not correspond to any raw SIP message but only are representative of the leg between MS Teams client and MS Teams proxy.Figure 7-14 PSTN to MS Teams Message Flow
Figure 7-15 UCaaS_CCaaS Signalling Leg
Figure 7-16 UCaaS_CCaaS Media Leg
