Custom Headers for the Calls Page
You can define custom header fields in which the field string is searched across all SIP messages, to parse and extract the values and display the headers as a new field in the Calls table.
Defining custom headers enables custom monitoring of calls and filtering calls based on your requirements. This feature supports parsing of messages of only SIP protocol. Messages of other protocols like ISUP, ENUM, MEGACO, DIAMETER, MGCP etc are not supported. SIP messages belonging to Calls only are supported, messages related to other functionalities like Registrations, Subscriptions are not supported.
The SIP messages of a call are parsed and searched for the custom header values in the following order. Note that the body of a SIP message is not used to search for custom headers.
Custom headers are displayed in the following pages:
  • Dashboard
  • Calls
  • Devices
  • User Tracking
  • IP Tracking
By default, the custom header columns are displayed on all Calls panels except the Dashboard. To view on the Dashboard, add the columns manually using the Set Columns option.
