20 Storage Expansion Support for Mediation Engine
The Storage Expansion tool allows administrators to increase the storage allocated to Session Monitor without requiring a full reinstallation.
This capability is achieved using a command-line script that supports both single-disk and dual-disk system configurations, enabling a flexible expansion of MySQL database and Block Storage independently or together, according to the available space.
Key Capabilities
  • Expand storage for MySQL database, Block Storage, or both.
  • Support for single-disk and dual-disk system setups.
  • Ensure zero downtime during expansion without requiring system reinstallation.
  • Validate inputs robustly and confirm with users to reduce misconfiguration risks.
  • Provide comprehensive information and Help command options.
  • Exclude support for reducing (shrinking) storage allocations.
Important Notes
  • Storage expansion is supported on Mediation Engine and Mediation Engine + Probe nodes only.
  • Only dual-disk system setups support separate expansion of MySQL and Block storage.
  • It is recommended to run the script during off-peak traffic hours.
