Delete an Environment
delete
/environment/{id}
Deletes the specified environment.
Request
Path Parameters
Back to Top
Response
200 Response
The environment was deleted successfully.
404 Response
The environment is not found.
Examples
The following example shows how to delete an environment by submitting a DELETE request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X DELETE 'hostname:port/environment/20" -H "accept: */*"
Example of the Response Body
If successful, the response code 204 is returned along with a header.
