Get Environment Details
get
/environment
Retrieves all environments.
Request
There are no request parameters for this operation.
Back to Top
Response
200 Response
The environment details were retrieved successfully.
Back to Top
Examples
The following example shows how to retrieve details of all environments by submitting a GET request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X GET "hostname:port/environment" -H "accept: */*"
Example of Response Body
If successful, the response code 200 is returned with a response body. For example:
  "total": 6,
  "limit": 10,
  "offset": 0,
  "page": 1,
  "pages": 1,
  "docs": [
      "_id": 1,
      "name": "Tdaas",
      "build": null,
      "count": 8,
      "release": null,
      "connections": [
        1,
        2,
        3,
        4,
        5,
        6,
        7,
        8
      "description": null
      "_id": 2,
      "name": "Tdaas",
      "build": null,
      "count": 5,
      "release": null,
      "connections": [
        9,
        10,
        11,
        12,
        13
      "description": null
      "_id": 3,
      "name": "environment-100",
      "count": 1,
      "connections": [],
      "description": "environment-100 description"
      "_id": 4,
      "count": 1,
      "connections": [],
      "_id": 5,
      "name": "update----environment-100",
      "count": 1,
      "connections": [
        29
      "description": "environment nfVSoxIWbQUgJLH"
      "_id": 6,
      "name": "environment-100 nfVSoxIWbQUgJLH",
      "build": null,
      "count": 15,
      "release": null,
      "connections": [
        14,
        15,
        16,
        17,
        18,
        19,
        20,
        21,
        22,
        23,
        24,
        25,
        26,
        27,
        28
      "description": "environment-100 nfVSoxIWbQUgJLH"
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
Back to Top
