Get Environment Details by ID
get
/environment/{id}
Retrieves the specified environment.
Request
Path Parameters
Query Parameters
expand:
Set this parameter to true to expand environment details.
Response
200 Response
The environment details were retrieved succesfully.
Examples
The following example shows how to retrieve details of an environment by ID by submitting a GET request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X GET "hostname:port/environment/5" -H "accept: */*"
Example of Response Body
If successful, the response code 200 is returned with a response body. For example:
"_id": 5,
"name": "update----environment-100",
"count": 1,
"connections": [
"_id": 29,
"name": "test-update1",
"properties": [
"_id": 274923071405041,
"name": "name--2",
"value": "value--2"
"_id": 274923071784208,
"name": "name--2",
"value": "value--2"
"_id": 274923071789083,
"name": "name--3",
"value": "value--3"
"_id": 274923071792791,
"name": "name--1",
"value": "value--1"
"_id": 274923071796166,
"name": "name--1",
"value": "value--1"
"_id": 274923071799541,
"name": "name--1",
"value": "value--1"
"_id": 274923071802875,
"name": "name--1",
"value": "value--1"
"_id": 274923071806083,
"name": "name--1",
"value": "value--1"
"_id": 274923071809333,
"name": "name--1",
"value": "value--1"
"_id": 274923071812541,
"name": "name--1",
"value": "value--1"
"_id": 274923071815625,
"name": "name--1",
"value": "value--1"
"_id": 357844231324209,
"name": "new-name--1",
"value": "newvalue"
"_id": 357844231328042,
"value": "newvalue"
"description": "connecction--1-100 description"
"description": "environment nfVSoxIWbQUgJLH"
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
