Get Job Details
get
/job
Get details of jobs.
Request
There are no request parameters for this operation.
Back to TopResponse
200 Response
The job details were retrieved successfully.
Examples
The following example shows how to retrieve details of all jobs by submitting a GET request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X GET "hostname:port/job" -H "accept: */*"
Example of Response Body
If successful, the response code 200 is returned with a response body. For example:
"total": 12,
"limit": 10,
"offset": 0,
"page": 1,
"pages": 2,
"docs": [
"_id": 1,
"tag": [
"Publish Automation"
"name": "Publish Automation",
"type": "0",
"description": "Publish Automation",
"scenarioCount": 33,
"environment_id": 1,
"executionConfig": {
"group": [
"group": [],
"execution": "",
"scenarios": [
1,
2,
3,
4,
9,
10,
11,
12,
13,
14,
15,
16,
17,
18,
19,
20,
21,
22,
23,
24,
25,
26,
27,
28,
29,
30,
31,
32,
33,
5,
6,
7,
8
"execution": "serial"
"environment_name": "Tdaas"
"_id": 2,
"tag": [
"type": "0",
"scenarioCount": 12,
"environment_id": 2,
"group": [
"group": [],
"execution": "",
"scenarios": [
61,
62,
63,
64,
65,
66,
67,
68,
69,
70,
71,
72
"_id": 3,
"tag": [
"type": "0",
"scenarioCount": 3,
"group": [
"group": [],
"execution": "",
"scenarios": [
58,
59,
60
"_id": 4,
"tag": [
"type": "0",
"scenarioCount": 46,
"group": [
"group": [],
"execution": "",
"scenarios": [
34,
35,
36,
37,
38,
39,
40,
41,
42,
43,
44,
45,
46,
47,
48,
49,
50,
51,
52,
53,
54,
55,
56,
57,
58,
59,
60,
61,
62,
63,
64,
65,
66,
67,
68,
69,
70,
71,
72,
73,
74,
75,
76,
77,
78,
79
"_id": 6,
"tag": [
"type": "0",
"group": [
"group": [],
"execution": "",
"scenarios": [
61,
62,
63,
64,
65,
66,
67,
68,
69,
70,
71,
72
"_id": 7,
"tag": [
"type": "0",
"group": [
"group": [],
"execution": "",
"scenarios": [
61,
62,
63,
64,
65,
66,
67,
68,
69,
70,
71,
72
"_id": 8,
"tag": [
"type": "0",
"group": [
"group": [],
"execution": "",
"scenarios": [
61,
62,
63,
64,
65,
66,
67,
68,
69,
70,
71,
72
"_id": 9,
"tag": [
"type": "0",
"group": [
"group": [],
"execution": "",
"scenarios": [
61,
62,
63,
64,
65,
66,
67,
68,
69,
70,
71,
72
"_id": 10,
"tag": [
"test"
"name": "test_job_fsm",
"type": 0,
"description": "testing",
"scenarioCount": 1,
"group": [
"name": "",
"group": [],
"execution": "",
"scenarios": [
79
"environment_name": ""
"_id": 12,
"tag": [
"TODO-jobtestinggg"
"name": "TODO-jobtestss",
"type": "0",
"description": "TODO-jobtestinggg",
"scenarioCount": 1,
"name": "",
"group": [
"name": "",
"execution": "",
"scenarios": [
"_id": "6409a9db6102f60f98d476ec",
"name": "null"
"environment_name": "environment-100"
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
