Get Job Details by ID
get
/job/{id}
Get details of a given job.
Request
Path Parameters
Back to Top
Response
200 Response
The job details were retrieved successfully.
Examples
The following example shows how to retrieve details for a job by ID by submitting a GET request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X GET "hostname:port/job/15" -H "accept: */*"
Example of Response Body
If successful, the response code 200 is returned with a response body. For example:
"_id": 15,
"tag": [
"TODO-job"
"name": "TODO-job",
"type": "0",
"description": "TODO-job",
"scenarioCount": 1,
"executionConfig": {
"name": "Name",
"group": [
"name": "Name",
"execution": "2",
"scenarios": [
"_id": "6409a9db6102f60f98d476ec",
"name": "null"
"execution": "serial",
"environment_id": 1
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
