Get Job Patch Details
patch
/job/{id}
Retrieve the patch details for a given job.
Request
Path Parameters
Back to Top
Response
201 Response
The job details were retrieved successfully.
Examples
This example shows how to retrieve a job's path by submitting a PATCH request on the REST resource using cURL. For more information about cURL, see Use cURL.
curl -X PATCH 'http://hostname:port/user/userpassword/4' -d @sampleJobPath.json
Example of the Request Body
The following is an example of the contents of the sampleJobPath.json file sent as the request body.
"tag": [
"TODO-job"
"scenarioCount": 1,
"name": "TODO-job",
"description": "TODO-job",
"type": "0",
"executionConfig": {
"group": [
"scenarios": [
"6409a9db6102f60f98d476ec"
"name": "",
"execution": ""
"name": "",
"execution": "serial"
Example of the Response Body
If successful, the response code 201 is returned with the following response body.
"_id": 15,
"tag": [
"TODO-job"
"name": "TODO-job",
"type": "0",
"scenarioCount": 1,
"name": "",
"group": [
"name": "",
"execution": "",
"scenarios": [
"_id": "6409a9db6102f60f98d476ec",
"name": "null"
