Delete Scenario by ID
delete
/runtime/scenario/{id}
Deletes the given scenario.
Request
Path Parameters
Back to Top
Response
200 Response
The scenario was deleted successfully.
Examples
The following example shows how to delete a scenario by submitting a DELETE request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X DELETE 'hostname:port/runtime/scenario" -H "accept: */*"
Example of the Response Body
If successful, the response code 200 is returned along with a header.
