Create a Scenario
post
/runtime/scenario
Creates a scenario.
Request
There are no request parameters for this operation.
Back to Top
Response
201 Response
The scenario was created successfully.
Back to Top
Examples
The following example shows how to create a new scenario by submitting a POST request on the REST resource using cURL. For more information about cURL, see "Use cURL".
The -d option specifies the file to attach as the request body.
curl -X POST "hostname:port/runtime/scenario" -H "accept: */*" -H "Content-Type: application/json" -d @file.json
where:
  • file.json is the JSON file the scenario details to create.
Example of Request Body
The following is an example of the contents of file.json sent as the request body:
  "name": "Subscriber Creation and Purchase Event",
  "description": "Subscriber Creation and Purchase Event",
  "type": null,
  "namespace": null,
  "tags": null,
  "id": "1",
  "mode": null,
  "priority": 0,
  "testScenarioResult": null,
  "loadedFromConfig": false,
  "cases": [
      "name": "Create a todo list and view them",
      "description": null,
      "type": null,
      "namespace": null,
      "tags": null,
      "id": "1",
      "mode": null,
      "priority": 0,
      "hasChildren": false,
      "parent": null,
      "persona": null,
      "hasCondition": false,
      "conditions": null,
      "testCaseResult": null,
      "child": false,
      "cases": [],
      "steps": [
          "name": "Given delete all todo tasks, for cleanup before running automation.",
          "type": null,
          "namespace": null,
          "tags": null,
          "id": "1",
          "action": {
            "path": "todo/delete/delete-all-todo-tasks",
            "name": "Delete all todo tasks",
            "description": "Delete all todo tasks",
            "tags": [
              "todo",
              "delete",
              "all"
            "bdd": "delete all todo tasks",
            "product": "todo",
            "actionType": "REST",
            "location": "",
            "resource": "todo",
            "method": "DELETE",
            "queryParameters": null,
            "request": null,
            "requestType": null,
            "requestVariables": null,
            "responseVariables": null,
            "expectedStatusCode": 202,
            "requestString": null
          "actionPath": null,
          "behaviour": null,
          "validations": [],
          "dataVariables": [
              "property": "id",
              "value": "all",
              "runtimeValue": null
          "saveVariables": [],
          "reference": null,
          "conditions": [],
          "repeatTimes": null,
          "repeatUntil": null,
          "repeatWhile": null,
          "runtimeInfo": {
            "runtimeURL": null,
            "runtimeStatusCode": 0,
            "expectedStatusCode": 0,
            "request": null,
            "response": null,
            "status": "NOT_EXECUTED"
          "stepResult": null,
          "statusValidation": null
          "name": "When add todo task, for buying hardware",
          "type": null,
          "namespace": null,
          "tags": null,
          "id": "2",
          "action": {
            "path": "TodoApp/add-todo-tasks/add-one-todo-task",
            "name": "Add one todo task",
            "description": "Add one todo task",
            "tags": [
              "todo",
              "read"
            "bdd": "add todo task",
            "product": "todo",
            "location": "",
            "resource": "todo",
            "method": "POST",
            "request": "add-one-todo-task.request.json",
            "requestType": "FILE",
            "expectedStatusCode": 200,
            "requestString": "{\r\n    \"name\" : \"Generate Automation Tasks\",\r\n    \"description\" : \"Generate Automation Tasks\"\r\n}\r\n"
          "actionPath": null,
          "behaviour": null,
          "validations": [
              "property": "$status",
              "propertyValue": null,
              "value": "200",
              "runtimeValue": null,
              "result": false
          "dataVariables": [
              "property": "name",
              "value": "Generate Automation Tasks",
              "property": "description",
          "saveVariables": [
              "variable": "firstTask.id",
              "value": "id",
              "variable": "firstTask.name",
              "value": "name",
              "variable": "firstTask.description",
              "value": "description",
          "reference": null,
          "conditions": [],
          "runtimeInfo": {
            "runtimeURL": null,
            "request": null,
            "response": null,
          "stepResult": null,
          "name": "Then read todo task, by id",
          "type": null,
          "namespace": null,
          "tags": null,
          "id": "3",
          "action": {
            "path": "TodoApp/read-todo-tasks/read-todo-task-by-id",
            "name": "Read todo task by id",
            "description": "Read todo task by id",
            "tags": [
              "todo",
              "read"
            "bdd": "read todo task",
            "product": "todo",
            "location": "",
            "resource": "todo",
            "method": "GET",
            "request": null,
          "actionPath": null,
          "behaviour": null,
          "validations": [
              "value": "200",
              "result": false
              "property": "name",
              "value": "Automation Test",
              "result": false
              "result": false
              "property": "status",
              "value": "TODO",
              "result": false
          "dataVariables": [
              "property": "id",
              "value": "1",
          "reference": null,
          "conditions": [],
          "runtimeInfo": {
            "runtimeURL": null,
            "request": null,
            "response": null,
          "stepResult": null,
Example of Response Body
If successful, the response code 201 is returned along with a header. For example:
  "_id": 80
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
Back to Top
