Delete Scenario Result by ID
delete
/runtime/scenarioresult/{id}
Deletes a specific scenario result based on the ID.
Request
Path Parameters
Back to Top
Response
200 Response
Successfully deleted the scenario result
404 Response
Scenario result not found
500 Response
Server error
Examples
The following example shows how to delete a scenario result by submitting a DELETE request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X DELETE 'hostname:port/runtime/scenarioresult/136" -H "accept: */*"
Example of the Response Body
If successful, the response code 200 is returned along with a header.
