Create Scenario Result
post
/runtime/scenarioresult
Request
There are no request parameters for this operation.
Back to Top
Response
201 Response
Scenario created successfully
Back to Top
Examples
The following example shows how to create a scenario result by submitting a POST request on the REST resource using cURL. For more information about cURL, see "Use cURL".
The -d option specifies the file to attach as the request body.
curl -X POST "hostname:port/runtime/scenarioresult" -H "accept: */*" -H "Content-Type: application/json" -d @file.json
where:
  • file.json is the JSON file the execution details to create.
Example of Request Body
The following is an example of the contents of file.json sent as the request body:
  "id": "1",
  "name": "Create Basic Subscription",
  "description": "Creates a new Basic Subscription",
  "tags": null,
  "namespace": null,
  "type": "TestScenario",
  "status": "PASSED",
  "startTime": 1732603368316,
  "endTime": 1732603376192,
  "duration": 7876,
  "error": null,
  "stackTrace": null,
  "failure": null,
  "totalCount": 1,
  "passCount": 1,
  "failCount": 0,
  "skipCount": 0,
  "errorCount": 0,
  "resultNamespace": null,
  "testCaseResults": [
      "id": "45",
      "name": "Create basic subscription",
      "description": null,
      "tags": null,
      "namespace": null,
      "type": "TestCase",
      "status": "PASSED",
      "startTime": 1732603368470,
      "endTime": 1732603376048,
      "duration": 7578,
      "error": null,
      "stackTrace": null,
      "failure": null,
      "totalCount": 3,
      "passCount": 3,
      "failCount": 0,
      "skipCount": 0,
      "errorCount": 0,
      "testStepResults": [
          "id": "183",
          "name": "When set variable,",
          "tags": null,
          "namespace": null,
          "type": "TestStep",
          "status": "PASSED",
          "startTime": 1732603368625,
          "endTime": 1732603368642,
          "duration": 17,
          "error": null,
          "stackTrace": null,
          "failure": null,
          "totalCount": 0,
          "passCount": 0,
          "failCount": 0,
          "skipCount": 0,
          "errorCount": 0,
          "resultFiles": {},
          "actionName": "set variable",
          "validations": null,
          "dataVariables": null,
          "saveVariables": [
              "variable": "region",
              "value": "Bengaluru",
              "runtimeValue": "Bengaluru"
              "variable": "category",
              "value": "basic",
              "runtimeValue": "basic"
              "variable": "offer",
              "value": "basicOffer",
              "runtimeValue": "basicOffer"
              "variable": "paymentType",
              "value": "CREDITCARD",
              "runtimeValue": "CREDITCARD"
          "actionType": "REST",
          "stepLogs": [
              "level": "INFO",
              "timestamp": 1732603368471,
              "message": "\n------------------------------------------------------------",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368472,
              "message": "STEP STARTED : When set variable,",
              "error": ""
              "level": "INFO",
              "message": "------------------------------------------------------------",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368629,
              "message": "Get REST plugin from plugin manager",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368634,
              "message": "Initializinig the REST plugin",
              "error": ""
              "level": "INFO",
              "message": "com.oracle.cagbu.taas.plugin.rest.RestActionPlugin@1ec898c4",
              "error": ""
              "level": "INFO",
              "message": "Running the REST plugin with step ",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368635,
              "message": "Process set variable task : 4",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368639,
              "message": "Test Context : Updating key region : Bengaluru = Bengaluru",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368640,
              "message": "Test Context : Updating key category : basic = basic",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368641,
              "message": "Test Context : Updating key offer : basicOffer = basicOffer",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368642,
              "message": "Test Context : Updating key paymentType : CREDITCARD = CREDITCARD",
              "error": ""
          "id": "184",
          "name": "When create a new VT subscription",
          "tags": null,
          "namespace": null,
          "type": "TestStep",
          "status": "PASSED",
          "startTime": 1732603370701,
          "endTime": 1732603371324,
          "duration": 623,
          "error": null,
          "stackTrace": null,
          "failure": null,
          "totalCount": 0,
          "passCount": 0,
          "failCount": 0,
          "skipCount": 0,
          "errorCount": 0,
          "resultFiles": {
            "request": "{\"type\":\"BASIC\",\"name\":\"vt-user-basic-TBcBFFdOhEUGg\",\"region\":\"default region\",\"category\":\"default category\",\"offer\":\"default offer\",\"paymentType\":\"default payment type\"}",
            "response": "{\"type\":\"BASIC\",\"name\":\"vt-user-basic-TBcBFFdOhEUGg\",\"region\":\"default region\",\"category\":\"default category\",\"offer\":\"default offer\",\"paymentType\":\"default payment type\"}",
            "connection": {
              "name": "virtualtenant",
              "description": "virtualtenant_connection",
              "type": "REST",
              "url": "https://jpprasad-dev.snbomprshared1.gbucdsint02bom.oraclevcn.com:6502",
              "authorize": true,
              "authorization": {
                "type": "OAUTH2",
                "oauthConfig": {
                  "grantType": "client_credentials",
                  "tokenUrl": "https://idcs-e64ec1bbecdf4cce90b5a17df60402ab.identity.oraclecloud.com/oauth2/v1/token",
                  "clientId": "7761b1041ec64511983844512b46a213",
                  "clientSecret": "c030860c-3a21-44c5-a0b7-8e5e868e3990",
                  "scope": "https://jpprasad-dev.snbomprshared1.gbucdsint02bom.oraclevcn.com:443/taas ",
                  "username": null,
                  "password": null,
                  "lastUpdated": 1732603370698,
                  "accessToken": "eyJ4NXQjUzI1NiI6IlU0eUxXNVNYbi13UHVLZW9vWFNxd2xubHJGVjR4R2xNdy1pbzJlc0ZGc0EiLCJ4NXQiOiJjUmxNSm1rd3hWbGloLUc4TkVpMUVGMlpiTjgiLCJraWQiOiJTSUdOSU5HX0tFWSIsImFsZyI6IlJTMjU2In0.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.ajtEb4OZo-7gQWtbrNtA9OZvOWwuuvmwzOm4vAVjAdPqOvk_eKn1G3OtUMt2JLKv1gthhjj7BLVoRURtedZS87XzBtk3T1niAgjgYQoLLtNTKtX0_SGqmEi9_oRX-t4xl1CSgbnKPP3t-QEzDSvo66OCw_q8xx-D6x8q47V44IvjV_PRWk0XIVTuxohNIp1mb3OCXkivKImNLXQcg7aw00IiIE63UunygrL_dUoPlLPG5foErDEukgf4FmZbI0OaGHvrTAQkbwMp50m3Vz1JYlUvGTq_W6u-lwpRCQfqq1jeYXSmhHssVX5y8QQyt1RavYZKABP6iQ9aFrzRAN4q_Q"
              "hostname": "https://jpprasad-dev.snbomprshared1.gbucdsint02bom.oraclevcn.com",
              "product": "virtualtenant",
              "topologyType": "DEFAULT",
              "connectionURI": []
          "actionName": "Create new subscription",
          "validations": [
              "property": "$status",
              "propertyValue": "201",
              "value": "201",
              "runtimeValue": "SUCCESS",
              "result": true
          "dataVariables": [
              "property": "type",
              "value": "BASIC",
              "runtimeValue": "BASIC"
              "property": "name",
              "value": "vt-user-basic-npVWewiJfkMbLCp",
              "runtimeValue": "vt-user-basic-TBcBFFdOhEUGg"
          "saveVariables": null,
          "stepLogs": [
              "level": "INFO",
              "timestamp": 1732603368814,
              "error": ""
              "level": "INFO",
              "message": "STEP STARTED : When create a new VT subscription",
              "error": ""
              "level": "INFO",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368967,
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368968,
              "error": ""
              "level": "INFO",
              "message": "com.oracle.cagbu.taas.plugin.rest.RestActionPlugin@3341bca3",
              "error": ""
              "level": "INFO",
              "error": ""
              "level": "INFO",
              "message": "Get Connection for virtualtenant.REST",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368969,
              "message": "Get Environment : virtualtenant env : com.oracle.cagbu.taas.model.connection.APIConnection@17b120d0",
              "error": ""
              "level": "INFO",
              "message": "url : virtualtenant :: https://jpprasad-dev.snbomprshared1.gbucdsint02bom.oraclevcn.com:6502",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368970,
              "message": "name = Create new subscription\nbdd = create a new VT subscription\nproduct = virtualtenant\ndescription = Create a new VT subscription\nType = REST\ntags = [VIRTUALTENANT, SUBSCRIPTION]\nresource = mock\nrequest = subscription.request.json\nrequestType = FILE\nrequest string = {    \"type\" : \"DEFAULT\",    \"name\" : \"subscriber name\",    \"region\" : \"default region\",    \"category\":\"default category\",    \"offer\":\"default offer\",    \"paymentType\":\"default payment type\"    }\nmethod = POST\nqueryParams = null\nexpectedStatusCode = 201\npath = virtualtenant/subscription\n\n",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368971,
              "message": "URL: https://jpprasad-dev.snbomprshared1.gbucdsint02bom.oraclevcn.com:6502/mock",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603368974,
              "message": "URL : https://jpprasad-dev.snbomprshared1.gbucdsint02bom.oraclevcn.com:6502/mock",
              "error": ""
              "level": "INFO",
              "message": "Request : null",
              "error": ""
              "level": "INFO",
              "message": "Method : POST",
              "error": ""
              "level": "INFO",
              "message": "Action : Create new subscription",
              "error": ""
              "level": "DEBUG",
              "timestamp": 1732603368975,
              "message": "Processing Request",
              "error": ""
              "level": "DEBUG",
              "message": "Processing Parameters",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603369021,
              "message": "Request String : {\"type\":\"BASIC\",\"name\":\"vt-user-basic-TBcBFFdOhEUGg\",\"region\":\"default region\",\"category\":\"default category\",\"offer\":\"default offer\",\"paymentType\":\"default payment type\"}",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603371318,
              "message": "Status : 201",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603371322,
              "message": "Response :{\"type\":\"BASIC\",\"name\":\"vt-user-basic-TBcBFFdOhEUGg\",\"region\":\"default region\",\"category\":\"default category\",\"offer\":\"default offer\",\"paymentType\":\"default payment type\"}",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603371323,
              "message": "Validating if execution is successful using expected status code mentioned in action.json",
              "error": ""
              "level": "INFO",
              "message": "Validation is successful : Expected exitcode: 201, Actual : 201",
              "error": ""
          "id": "185",
          "name": "When create subscription event,",
          "tags": null,
          "namespace": null,
          "type": "TestStep",
          "status": "PASSED",
          "startTime": 1732603371745,
          "endTime": 1732603375813,
          "duration": 4068,
          "error": null,
          "stackTrace": null,
          "failure": null,
          "totalCount": 0,
          "passCount": 0,
          "failCount": 0,
          "skipCount": 0,
          "errorCount": 0,
          "resultFiles": {},
          "actionName": "Create subscription event",
          "dataVariables": [
              "property": "minDuration",
              "value": "1000",
              "runtimeValue": null
              "property": "maxDuration",
              "value": "5000",
              "property": "status",
              "value": "PASS",
          "actionType": "SIMULATION",
          "stepLogs": [
              "level": "INFO",
              "timestamp": 1732603371588,
              "error": ""
              "level": "INFO",
              "timestamp": 1732603371589,
              "message": "STEP STARTED : When create subscription event,",
              "error": ""
              "level": "INFO",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603371745,
              "message": "Get SIMULATION plugin from plugin manager",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603371748,
              "message": "Initializinig the SIMULATION plugin",
              "error": ""
              "level": "INFO",
              "message": "com.oracle.cagbu.taas.plugin.stepsimulation.StepSimulationActionPlugin@5d96ddec",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603371749,
              "message": "Running the SIMULATION plugin with step ",
              "error": ""
              "level": "INFO",
              "message": "Running simulation action plugin",
              "error": ""
              "level": "INFO",
              "message": "Event:create subscription event",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603371750,
              "message": "Event configuration is not found in Simulation configurations",
              "error": ""
              "level": "INFO",
              "timestamp": 1732603371751,
              "message": "Minimum duration:1000 ms",
              "error": ""
              "level": "INFO",
              "message": "Maximum duration:5000 ms",
              "error": ""
              "level": "INFO",
              "message": "Waiting for duration:4056 ms",
              "error": ""
  "resultFiles": {
    "map": {
      "design bdd": "Create_Basic_Subscription.design.scenario",
      "runtime bdd": "Create_Basic_Subscription.runtime.scenario"
    "json": "{\"design bdd\": \"Create_Basic_Subscription.design.scenario\",\"runtime bdd\": \"Create_Basic_Subscription.runtime.scenario\"}"
  "execution_id": 286
Example of Response Body
If successful, the response code 201 is returned along with a header. For example:
  "_id": 136
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
Back to Top
