Stop Job Execution
post
/taas/job/stop/{executionID}
Stops executing the job with the given ID in TES Engine.
Request
Path Parameters
Back to Top
Response
200 Response
The job execution was stopped successfully.
404 Response
The execution ID was not found.
Back to Top
Examples
The following example shows how to stop a job execution by submitting a POST request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X POST "hostname:port/taas/job/stop/29" -H "accept: */*" -H "Content-Type: application/json"
Example of Response Body
If successful, the response code 200 is returned along with a header. For example:
"Job-Execution-Status":"TIMED_WAITING"
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
Back to Top
