Run a Job by ID
post
/taas/runJob/{jobID}
Runs the given job.
Request
Path Parameters
Back to Top
Response
Default Response
Sets the default response.
Back to Top
Examples
The following example shows how to run a job by its ID by submitting a POST request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X POST "hostname:port/taas/runJob/1" -H "accept: */*" -H "Content-Type: application/json"
Example of Response Body
If successful, the response code 200 is returned along with a header. For example:
"Status":"In-progress",
"Job-Execution-ID":"20"
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
Back to Top
