8 Synthetic Data
Learn about Oracle Communications Solution Test Automation Platform (STAP) Synthetic Data generation.
Topics in this chapter:
STAP Synthetic Data Generation
The Synthetic Data Generator is a critical component of a test automation platform, designed to produce diverse, scalable, and high-quality data for testing applications. It eliminates the reliance on real-world data by generating customizable data sets that emulate production conditions, ensuring comprehensive test coverage and improving testing efficiency.
STAP offers two types of plug-ins for synthetic data generation: Internal and External.
  • Internal plug-ins handle various data types, including numeric, alphanumeric, and text.
  • External plug-ins connect with third-party providers, with the currently supported plug-in being the global plug-in, which integrates with Data Faker.
For more information about Data Faker, see their website at https://www.datafaker.net/.
For more information on External Generators, refer to Fake Data Plug-in.
Configuration
Synthetic Data Generation plug-ins are assigned or configured with attribute data configuration which is used in STAP BDD automation. To configure and use synthetic data generation plug-ins within the STAP Behavior Driven Development automation framework:
  1. Configure the attribute home location in config.properties.
    Add the property in the ${WORKSPACE}/config/config.properties file. For more details, see Configuration Folder.
    attributeData.home=${Workspace_home}/config/attributeData
  2. Add attribute data configuration properties files in ${WORKSPACE}/config/attributeData directory. Each configuration file name should end with -attributeData.properties.
  3. In BDD, use the attribute values in synthetic-data1.html to retrieve next and current values:
Table 8-1 Synthetic Data Syntax
Value Description Syntax Example
get Next Value Computes the next value based on configuration and generates a new value
@{<attributeName>}
or
@{<attributeName>.nextValue}
@{mobileNumber} or @{mobileNumber.nextValue}
get Current Value Retrieves the current generated value.
@{<attributeName>.currentValue}
@{mobileNumber.currentValue}
Plug-in with Internal Generators
This plug-in is a versatile tool for number generation, offering two distinct modes to cater to various needs:
Number Generation
Table 8-2 describes Unique Number Generation type, its properties, and runtime BDD:
Unique Number Generation:
In this mode, the plug-in ensures that every number generated is distinct, providing a sequence of non-repeating values. It is ideal for creating identifiers, serial codes, or any application where uniqueness is essential. Each number is carefully selected to guarantee exclusivity within the generated set.
Table 8-2 Unique Number Generation Table
Type Description Properties Runtime BDD
NUMBER_UNIQUE_BOUND number is bound in range of [startValue, endValue) mobileNumber1-attributeData.properties
# Attribute Name
name=customerMobile
# Short description
description=10 digit mobile number
#Plugin associated with the attribute
plugin=NumberDataPlugin
type=NUMBER_UNIQUE_BOUND
# Persist data to be used in multiple executions
# Persist YES/NO
#persist=NO
# Plugin Properties for generating data
minValue=9999900000
maxValue=9999990009
increment=1
number_unique_bound.scenario
Scenario: AttributeData
Description: Attribute Data Scenario for data generation
Tags: [attribute, data]
#Persona:
Case: UniqueNumberGeneration
When set variable, generate unique customer mobile numbers Save:
#|  Property  |  Value                           |  Runtime Value  |
 |  name      |  @{customerMobile.currentValue}  |  9999900000     |
 |  name      |  @{customerMobile}               |  9999900001     |
 |  name      |  @{customerMobile.nextValue}     |  9999900002     |
 |  name      |  @{customerMobile.currentValue}  |  9999900002     |
 |  name      |  @{customerMobile}               |  9999900003     |
NUMBER_UNIQUE_INFINITE number has startValue and no endValue. Infinite values are generated mobileNumber2-attributeData.properties
# Attribute Name
name=serviceMobile
# Short description
type=NUMBER_UNIQUE_INFINITE
minValue=999990004
increment=1
number_unique_infinite.scenario
#Persona:
When set variable, generating unique service mobile numbers
Save:
 |  name      |  @{serviceMobile.currentValue}  |  999990004      |
 |  name      |  @{serviceMobile}               |  999990005      |
 |  name      |  @{serviceMobile.nextValue}     |  999990006      |
 |  name      |  @{serviceMobile.currentValue}  |  999990006      |
 |  name      |  @{serviceMobile}               |  999990007      |
NUMBER_UNIQUE_DIGITS number has startValue and no endValue. Number of digits in the value is specified. mobileNumber3-attributeData.properties
# Attribute Name
name=agentMobile
# Short description
type=NUMBER_UNIQUE_DIGITS
minValue=999990009
increment=1
numOfDigits=10
number_unique_digits.scenario
#Persona:
When set variable, generating unique agent mobile numbers
Save:
 |  name      |  @{agentMobile.currentValue}  |  999990009      |
 |  name      |  @{agentMobile}               |  999990010      |
 |  name      |  @{agentMobile.nextValue}     |  999990011      |
 |  name      |  @{agentMobile.currentValue}  |  999990011      |
 |  name      |  @{agentMobile}               |  999990012      |
NUMBER_UNIQUE_VALUES number has startValue and no endValue. Number of values generated is specified. mobileNumber4-attributeData.properties
# Attribute Name
name=transactionMobile
# Short description
type=NUMBER_UNIQUE_VALUES
minValue=9999900014
increment=1
numOfValues=5
number_unique_values.scenario
#Persona:
When set variable, generating unique transaction mobile numbers
Save:
 |  name      |  @{transactionMobile.currentValue}  |  9999900014     |
 |  name      |  @{transactionMobile}               |  9999900015     |
 |  name      |  @{transactionMobile.nextValue}     |  9999900016     |
 |  name      |  @{transactionMobile.currentValue}  |  9999900016     |
 |  name      |  @{transactionMobile}               |  9999900017     |
Random Number Generation
Random Number Generation:
Here, the focus is on randomness rather than uniqueness. This mode produces a series of numbers without any specific pattern, making it suitable for simulations, gaming, or statistical modeling. The random numbers can be generated within a defined range, allowing users to customize the output according to their requirements.
Table 8-3 decribes Randome Number Generation types, its properties, and runtime BDD:
Table 8-3 Random Number Generation
NUMBER_RANDOM_VALUES random number; arguments passed are minimum_value and maximum_value; number is bound in range of [minimum_value, maximum_value)
randomNumber1-attributeData.properties
# Attribute Name
name=subscriptionID
# Short description
description=random number
type=NUMBER_RANDOM_VALUES
minValue=9999900000
maxValue=9999990000
#Persona:
Case: RandomNumberGeneration
When set variable, for generating random subscription IDs
Save:
 |  name      |  @{subscriptionID.currentValue}  |  9999900000     |
 |  name      |  @{subscriptionID}               |  9999943495     |
 |  name      |  @{subscriptionID.nextValue}     |  9999932406     |
 |  name      |  @{subscriptionID.currentValue}  |  9999932406     |
 |  name      |  @{subscriptionID}               |  9999980535     |
NUMBER_RANDOM_DIGITS random number; arguments passed are minimum_digits and maximum_digits
randomNumber2-attributeData.properties
# Attribute Name
name=phoneNumber
# Short description
type=NUMBER_RANDOM_DIGITS
minDigits=5
maxDigits=10
Scenario: 3.AttributeData
#Persona:
When set variable, for generating random phone numbers
Save:
 |  name      |  @{phoneNumber.currentValue}  |  4713264118     |
 |  name      |  @{phoneNumber}               |  9633152371     |
 |  name      |  @{phoneNumber.nextValue}     |  8724706855     |
 |  name      |  @{phoneNumber.currentValue}  |  8724706855     |
 |  name      |  @{phoneNumber}               |  6736490057     |
Text Generation
Table 8-4 describes Text Generation types, its properties, and runtime BDD:
Table 8-4 Text Generation Table
Type Description Properties Runtime bdd
TEXT_INIT_UPPER Initial letter is uppercase, remaining letters are lower case
text1-attributeData.properties
# Attribute Name
name=MessageHeader
# Short description
description=random text of certain/variable length which starts with capital letter
plugin=TextDataPlugin
type=TEXT_INIT_UPPER
minLength=4
maxLength=4
text_init_upper.scenario
#Persona:
Case: TextDataGeneration
When set variable, generating random Message headers
Save:
 |  name      |  @{MessageHeader.currentValue}  |  Vzhn           |
 |  name      |  @{MessageHeader}               |  Cebx           |
 |  name      |  @{MessageHeader.nextValue}     |  Pyjc           |
 |  name      |  @{MessageHeader.currentValue}  |  Pyjc           |
 |  name      |  @{MessageHeader}               |  Vqwl           |
TEXT_LOWER All letters of the string are in lowercase
text2-attributeData.properties
# Attribute Name
name=channelId
# Short description
description=random text of certain/variable length which has all letters in lower case
type=TEXT_LOWER
minLength=5
maxLength=10
text_lower.scenario
#Persona:
When set variable, generating random channel IDs
Save:
 |  name      |  @{channelId.currentValue}  |  wplqxfftdw     |
 |  name      |  @{channelId}               |  xnqnjnl        |
 |  name      |  @{channelId.nextValue}     |  ouedleyk       |
 |  name      |  @{channelId.currentValue}  |  ouedleyk       |
 |  name      |  @{channelId}               |  hxbhksr        |
TEXT_UPPER All letters of the string are in uppercase
ttext3-attributeData.properties
# Attribute Name
name=TransmissionCode
# Short description
description=random text of certain/variable length which all letters are capital letters
type=TEXT_UPPER
minLength=7
maxLength=7
text_upper.scenario
#Persona:
When set variable, generating random Transmission Codes
Save:
 |  name      |  @{TransmissionCode.currentValue}  |  QGJPQZM        |
 |  name      |  @{TransmissionCode}               |  GNCDAYG        |
 |  name      |  @{TransmissionCode.nextValue}     |  IIHHWYF        |
 |  name      |  @{TransmissionCode.currentValue}  |  IIHHWYF        |
 |  name      |  @{TransmissionCode}               |  JVCJIUA        |
TEXT_ALPHANUMERIC Initial character of the string is a letter, remaining are alphanumeric characters
text4-attributeData.properties
# Attribute Name
name=sessionID
# Short description
description=random text of certain/variable length; Initial character of the string is a letter, remaining are alphanumeric characters
type=TEXT_ALPHANUMERIC
minLength=5
maxLength=15
text_alphanumeric.scenario
#Persona:
When set variable, generating random session IDs
Save:
 |  name      |  @{sessionID.currentValue}  |  E3GcSGp        |
 |  name      |  @{sessionID}               |  llDCNvLmW7C    |
 |  name      |  @{sessionID.nextValue}     |  DUTyLGj40su    |
 |  name      |  @{sessionID.currentValue}  |  DUTyLGj40su    |
 |  name      |  @{sessionID}               |  v4qqu70        |
TEXT_ALPHANUMERIC_SPECIAL Initial character of the string is a letter, remaining are alphanumeric and special characters
text5-attributeData.properties
# Attribute Name
name=accessKey
# Short description
description=random text of certain/variable length; Initial character of the string is a letter, remaining are alphanumeric and special characters
type=TEXT_ALPHANUMERIC_SPECIAL
minLength=10
maxLength=10
text_alphanumeric_special.scenario
#Persona:
When set variable, generating random access keys
Save:
 |  name      |  @{accessKey.currentValue}  |  RU-6t60gH!     |
 |  name      |  @{accessKey}               |  LP02z8~Uoj     |
 |  name      |  @{accessKey.nextValue}     |  r$:K6UW[9Z     |
 |  name      |  @{accessKey.currentValue}  |  r$:K6UW[9Z     |
 |  name      |  @{accessKey}               |  AJK/xg-/|I     |
Unique ID Generation
Table 8-5 describes Unique ID Generation type, its properties, and runtime BDD:
Table 8-5 Unique ID Generation table
UNIQUE_ALPHABETIC All characters are letters
uniqueID1-attributeData.properties
# Attribute Name
name=communicationToken
# Short description
description=Unique alphabetic value
plugin=UniqueDataPlugin
type=UNIQUE_ALPHABETIC
length=8
unique_alphabetic.scenario
#Persona:
Case: UniqueDataGeneration
When set variable, for generating random communication tokens
Save:
 |  name      |  @{communicationToken.currentValue}  |  poAAeAKL       |
 |  name      |  @{communicationToken}               |  LUoeAoAM       |
 |  name      |  @{communicationToken.nextValue}     |  peeUoKKN       |
 |  name      |  @{communicationToken.currentValue}  |  peeUoKKN       |
 |  name      |  @{communicationToken}               |  fUoAKUKE       |
UNIQUE_ALPHANUMERIC Random no. of letters and digits in the text; Initial character is a letter
uniqueID2-attributeData.properties
# Attribute Name
name=DeviceID
# Short description
description=Unique alphanumeric value; first character is a letter
type=UNIQUE_ALPHANUMERIC
length=18
#Persona:
When set variable, for generating random device IDs
Save:
 |  name      |  @{DeviceID.currentValue}  |  p73JD58DW79kjfA0e0  |
 |  name      |  @{DeviceID}               |  L73d3F832HdQ6f0AU0  |
 |  name      |  @{DeviceID.nextValue}     |  V7N9h5832vTkvBK000  |
 |  name      |  @{DeviceID.currentValue}  |  V7N9h5832vTkvBK000  |
 |  name      |  @{DeviceID}               |  fv39N583279k810AUA  |
UNIQUE_ALPHANUMERIC_SPECIAL Random no. of letters, digits and, special characters in the text; Initial character is a letter
uniqueID3-attributeData.properties
# Attribute Name
name=ProductKey
# Short description
description=Unique alphanumeric value including special characters; first character is a letter
type=UNIQUE_ALPHANUMERIC_SPECIAL
length=12
unique_alphanumeric_special.scenario
#Persona:
When set variable, for generating random product keys
Save:
 |  name      |  @{ProductKey.currentValue}  |  pU!Uooo!!!0V   |
 |  name      |  @{ProductKey}               |  L0A00oeK!!0W   |
 |  name      |  @{ProductKey.nextValue}     |  L!Ke0eo!A!0r   |
 |  name      |  @{ProductKey.currentValue}  |  L!Ke0eo!A!0r   |
 |  name      |  @{ProductKey}               |  L!!!!0!0!!Us   |
UNIQUE_FIRST_DIGITS First x-characters are digits, rest are letters
uniqueID4-attributeData.properties
# Attribute Name
name=SerialNo
# Short description
description=Unique alphanumeric value; first x-characters are digits, rest are letters
type=UNIQUE_FIRST_DIGITS
length=12
numOfDigits=4
unique_first_digits.scenario
#Persona:
Save:
 |  name      |  @{SerialNo.currentValue}  |  1000eeAKAoop   |
 |  name      |  @{SerialNo}               |  1000UoAoUoeW   |
 |  name      |  @{SerialNo.nextValue}     |  1000AKUUUAAr   |
 |  name      |  @{SerialNo.currentValue}  |  1000AKUUUAAr   |
 |  name      |  @{SerialNo}               |  1000KKeAeAUi   |
Fake Data Generation
Datafaker is a library for Java and Kotlin to generate fake data. This is helpful when generating test data to fill a database, to generate data for a stress test, or anonymize data from production services.
STAP leverages data faker 2.4.2 (current or latest) and creates a plug-in to use it to generate fake data for automation scenarios. It also supports the output in multiple languages.
For more information on Fake Data Plug-in, see Data Faker Resource and Data Faker Github.
Table 8-6 lists the Supported Generator or methods:
Table 8-6 Supported Generator or Methods
Providers Attributes
name fullName, firstName, lastName, femaleFirstName, malefirstName, nameWithMiddle, prefix, suffix, title,username
internet emailAddress, domainName, username, getIpV6Address
address city, streetName, zipCode, buildingNumber, cityPrefix, citySuffix, country, countryCode, countyByZipCode, fullAddress, latitude, longitude, postcode, secondaryAddress, state, stateAbbr, zipCode, timeZone
number randomNumber, digits, randomDouble, numberBetween, negative, positive, digit, randomDigitNotZero
timeAndDate future, past,birthday
phoneNumber phoneNumber, cellPhone, phoneNumberNational, subscriberNumber, extension
word noun, preposition, conjunction, adverb, adjective,interjection, verb
text text, lowercaseCharacter, uppercaseCharacter
barcode gtin14
currency name
subscription paymentMethods, paymentTerms, statuses,subscriptionTerms
unique fetchFromYaml
idNumber idNumber
Configuration
To generate fake data, select the provider and corresponding attribute from the Data Faker Library Documentations mentioned in Table 8-7:
Table 8-7 Data Faker Library Documentations
property key value (eg) description
name fakeData Name of the attribute Data should be fakeData.
description Fake data generator Any short description.
plugin DataFakerPlugin Plug-in name should be DataFakerPlugin.
type collection Should be the same value for pluginManager to recognize.
list email,Double,Number,future Enter comma separated custom named list of all the keys to be used in the case file for the scenarios.
<List>
[n1] email
[n2] firstName.
[n n] Double
internet.emailAddress
firstName=name.fullName
Enter each of the keys entered in the list and in values the corresponding provider and its attribute to be used to generate random data.
Format:
<key_name_provided_in_list> = <data_faker_provider>.<data_faker_attribute>(comma_separated_params/custom_values_to_be_passed_in_attribute)
For example,
list=Double
Double=number.randomDouble(2,500,700)
(the configuration is intended to generate a double upto two decimal places between 500 to 700)
locale in ,ar The language the output is expected in.
Ensure the src/main/java/com/oracle/cagbu/stap/data/plugins/datafaker/validMethods.properties file supports the entry in attributeData.properties configuration. For more information, see Data Faker Resource .
The following is an example attributeData.properties File:
# Attribute Name
name=fakeData
# Short description
description=Fake data generator
plugin=DataFakerPlugin
type=collection
# enter the list of methods to be used
list=emailAddress,ip,phoneNumber,fullName,discount,billcharge,dataPlan,future,past,accessKey,networkName,barcode,currency
# enter the key as the method for each of the keys from the above list and corresponding provider and attribute name as per data faker documentation
emailAddress=internet.emailAddress
ip=internet.getIpV6Address
phoneNumber=phoneNumber.phoneNumber
fullName=name.fullName
discount=number.numberBetween(1,5)
billcharge=number.randomDouble(2,500,700)
dataPlan=subscription.subscriptionTerms
future=timeAndDate.future
past=timeAndDate.past
accessKey=text.text(10,26,true,true,true)
networkName=word.noun
barcode=barcode.gtin14
currency=currency.name
# language to be used to generate data
locale=in
Fake Data Usage
Refer to the following format to invoke and use data faker plug-in in a scenario case files:
| variable | @{$<key_mentioned_in_attributeData.properties_file>.<METHOD>} |
example:
Data:
| name | @{$firstName.currentValue} |
| name | @{$firstName.nextValue} |
| name | @{$firstName} |
Table 8-8 lists the methods supported.
Table 8-8 Methods Supported
METHOD EXPECTED OUTPUT
currentValue
outputs the current value
if there is no previously generated value, calls nextValue
nextValue output is a newly generated value
<empty> defaults to nextValue
Fake Data Generation Example
Example 1:
The following example shows how to generate and store random data using a variable-based approach:
Case: DataFaker
When set variable, generating random email addresses
Save:
| emailID1 | @{$emailAddress.currentValue} |
| emailID2 | @{$emailAddress.nextValue} |
| emailID3 | @{$emailAddress} |
When set variable, generating random ip addresses
Save:
| ipAddress1 | @{$ip.nextValue} |
| ipAddress2 | @{$ip} |
When set variable, generating random phone numbers
Save:
| mobile1 | @{$phoneNumber.nextValue} |
| mobile2 | @{$phoneNumber} |
When set variable, generating random service agent names
Save:
| agentname1 | @{$fullName.nextValue} |
| agentname2 | @{$fullName} |
When set variable, generating random discount percentages
Save:
| discount1 | @{$discount.nextValue} |
| discount2 | @{$discount} |
When set variable, generating random billing charges
Save:
| billing1 | @{$billcharge.nextValue} |
| billing2 | @{$billcharge} |
When set variable, generating random data plans
Save:
| dataplan1 | @{$dataPlan.nextValue} |
| dataplan2 | @{$dataPlan} |
When set variable, generating random expiry dates
Save:
| date1 | @{$future.nextValue} |
| date2 | @{$future} |
When set variable, generating random previous expiry dates
Save:
| expdate1 | @{$past.nextValue} |
| expdate2 | @{$past} |
Save:
| access1 | @{$accessKey.nextValue} |
| access2 | @{$accessKey} |
When set variable, generating random network names
Save:
| network1 | @{$networkName.nextValue} |
| network2 | @{$networkName} |
When set variable, generating random bar codes
Save:
| barcode1 | @{$barcode.nextValue} |
| barcode2 | @{$barcode} |
When set variable, generating random currencies
Save:
| currency1 | @{$currency.nextValue} |
| currency2 | @{$currency} |
Saving Synthetic Data into a Variable(Release 1.25.1.1.0 or later)
You can save the synthetic data generated using a data faker into a variable for further use. For instance, when generating IP addresses dynamically, the next generated IP value can be stored in a predefined variable for easy reference and reuse.
ipAddress1 = $ip.nextValue
Here, $ip.nextValue represents the next generated IP address, which is then stored in the variable ipAddress1. This allows the saved value to be used in subsequent operations or references within the application.
The following example shows how to validate if an account name already exists in Siebel:
And set variable, assign account name value to a variable
Save: | uniqueAccountName | ${accountName} |
And validate account name exists, in Siebel regardless of whether the status code is 200 or 404
Data: | $query | searchspec=([Name] = "${accountName}") |
Validate: | $status |
$IGNORE_STATUS_VALIDATION |
And validate account name exists, in Siebel and execute the loop until the status is 200 and
generate account name using Data Faker
RepeatWhile: | ${response.status} | 200 |
| Validate: | $status | $IGNORE_STATUS_VALIDATION |
| firstName | @{$firstName} | | lastName | @{$lastName} | | accountName | %CONCAT(${firstName},
,${lastName}) |
And set variable, to save the account name which will be used to create account in Siebel
Save: | accountName | ${uniqueAccountName} |
Save:
| accountName | %CONCAT(${firstName}, ,${lastName}) |
