19 Utility Reference
Learn how to use the stap utility to perform actions in Oracle Communications Solution Test Automation Platform (STAP).
STAP uses the stap utility to perform various actions. The help command provides a comprehensive list of all commands within STAP. Running the help displays each command's name alongside a brief description of its function.
./stap --help./stap --help ============================================================= Solution Test Automation Platform CLI Version : versionNumber ============================================================= Usage: stap --service -command [parameters] Options: --version --help --automation -compile workspace scenarios generate config -run workspace scenarios tags caseTags config mode --publish -action workspace -environment workspace -scenario workspace --simulation -run workspace -compile workspace --secure -environment filepath keyfilepath keystorepass aliasname
Parameters
--version
Displays the STAP version information.
--help
Shows documentation and help information about the stap utility commands. Optionally, you may specify a service or a specific command for more targeted help.
--automation
Indicates automation client operations.
-compile
Compiles the specified automation scenarios.
workspace
Specifies the STAP workspace location as a valid folder path. The default value is the current directory.
scenarios
Indicates one or more scenarios to compile or run. It accepts a list of values. The default value is either empty (to compile) or selected scenarios as per configuration or tags (to run).
generate
Specifies whether to generate result files from the compilation. Valid values are NO, YES, or MERGE.
config
Provides the file path for compile configuration as a valid file path.
-run
Runs the specified automation scenarios.
tags
Selects scenarios that match the specified tags. It accepts a list of values and belongs to the Scenario Selection group.
caseTags
Selects test cases that match the specified tags. It depends on the value of tags and accepts a list of values.
mode
Defines the execution mode. Possible values are trail or execute.
--publish
Enables the publish action for scenarios, environment, or workspace.
-action
Performs the publish action.
-environment
Carries out the environment publish action.
-scenario
Performs the publish action for a scenario.
--simulation
Executes a simulation.
-run
Runs a simulation publish action.
-compile
Compiles a simulation publish action.
--secure
Performs environment simulation with secure parameters.
-environment
Executes publishing in a secure environment.
filepath
Specifies the path to the JCEKS file, which must be a valid folder path and is mandatory.
keyfilepath
Supplies the path to the .properties file containing the data to be encrypted; this is a mandatory valid folder path.
keystorepass
Provides the keystore password, which must be supplied as a valid folder path and is mandatory.
aliasname
Identifies the secret key using an alias name; this is a mandatory value.
