20 Publishing Data using Command Line Interface
Solution Test Automation Platform utilizes the command-line interface to perform various actions. The help command provides a comprehensive list of all commands within STAP. Running the help displays each command's name alongside a brief description of its function
To retrieve information on how to run actions in STAP, run the help
command:
$ ./stap --helpThe following is the syntax of the output received after running the
help
command:
$ ./stap --help
Solution Test Automation Platform CLI
Version : 1.25.0
Usage: stap --<service> -<command> [<parameters>]
Global Options:
--version Shows the STAP CLI version
--help Shows the STAP CLI command documentation
[<service> [<command>]] Print help for module or command in module
--automation automation client operations
-compile Compiles the automation scenarios
workspace STAP workspace location
Valid folder path
Default Value: Current Directory
scenarios one or more scenarios to compile
List of values
Default Value:
generate Generate the result files from compile
One of the values : [NO, YES, MERGE]
config compile configuration
Valid file path
-run Run the automation scenarios
Valid folder path
scenarios one or more scenarios to run
List of values
Default Value: Selects scenarios as per configuration or tags
Optional Group : Scenario Selection
tags Select scenarios matching the tags
List of values
caseTags Select cases matching the tags
List of values
Depends on : tags
Valid file path
mode Execution mode
One of the values : [trail, execute]
--publish publish action
-action publish
Valid folder path
-environment publish
Valid folder path
-scenario publish
Valid folder path
--simulation Run simulation
-run publish
Valid folder path
-compile publish
Valid folder path
--secure environment simulation
filepath path to the JCEKS file
Valid folder path
Mandatory: Yes
keyfilepath Provide the path to your .properties file containing the data to be encrypted.
Valid folder path
Mandatory: Yes
keystorepass keystore password.
Valid folder path
Mandatory: Yes
aliasname alias name identifying the secret key
Valid folder path
Mandatory: YesThe help command provides all the information required to perform
various actions in STAP. For example, to retrieve information about your
current STAP version, run the following
command:
$ ./stap --version
Version : 1.25.0Run the following command to run
scenarios:
./stap --automation -run "workspace=<path>"Alternatively,
you can also run the help command to specifically search for command
lines for a particular type of action. For example, to retrieve all commands
related to running STAP run the following command:
$ ./stap --help secureThe following is the example output upon running this command:
$ ./stap --help
secure:
Version : 1.25.0.0
config/cli/secure.service.properties
Global Options:
Valid folder path
Mandatory: Yes
Valid folder path
Mandatory: Yes
Valid folder path
Mandatory: Yes
Valid folder path
Mandatory: YesYou can use this syntax to run the secure command in your STAP
environment. On the basis of the above response, secure your STAP
environment using the following
command:
./stap --secure -environment filepath=<path> keyfilepath=<path> keystorepass=<keystorepass> aliasname=<name>Upon running this command, you will receive a response similar to
the
following:
./stap --secure -environment filepath=<path> keyfilepath=<path> keystorepass=<keystorepass> aliasnam=<name>
[hostname STAP]$ ./stap --secure -environment keyfilepath=encrypt/env.jceks filepath=sampleWorkSpace/config/environments/tdaasEnvironment.properties keystorepass=Welcome@1 aliasname=password
STAP Automation Platform CLI
Version : 1.25.1.0.0
basic.password=${SECURE_PWD}
Enter new password for "basic.password":
password
Password updated successfully.
[hostname STAP]$To publish automation reports to third-party web servers, see "Publishing Reports Using Third-Party Web Servers".
