2 Unified Inventory Management System Requirements
This chapter describes the hardware, operating system, software, server, and database requirements for installing Oracle Communications Unified Inventory Management (UIM).
Software Requirements
For details about the software required to support the UIM components for traditional deployment, see "UIM Traditional Deployment Software Compatibility" in UIM Compatibility Matrix.
Hardware Sizing Guidelines
Table 2-1 provides hardware sizing guidelines for UIM.
The information in this section is meant as a guideline only. The values in this section are approximate. Accurate sizing for a production system requires a detailed analysis of the proposed business requirements. Sizing guidelines are based on an average CPU utilization rate of 60% - 70%. The guidelines do not account for High Availability and Disaster Recovery environments.
For information on hardware sizing requirements for HP-UX Itanium, contact Oracle Support.
The UIM installer supports Internet Protocol version 6 (IPv6) addresses. You can install and deploy UIM on servers that support IPv6 addresses.
Table 2-1 Hardware Sizing Guidelines
Deployment Size | Small | Medium | Large | Extra-Large |
Services/day |
<= 300,000 |
<= 600,000 |
<= 1,500,000 |
<= 3,000,000 |
Services/hour |
<= 33,500 |
<= 66,500 |
<= 166,500 |
<= 333,000 |
# of Subscribers Base (in Millions) |
10 |
20 |
50 |
100 |
x86-64/Linux Platform - Application Server |
CPU: 1 x 4 core - 2.55 GHz AMD EPYC™ 77J3- 8 threads RAM: 1 x 60 GB HDD: 1 X 300 GB |
CPU: 2 x 4 core - 2.55 GHz AMD EPYC™ 77J3 - 16 threads RAM: 2 x 60 GB HDD: 2 X 300 GB |
CPU: 8 x 4 core - 2.55 GHz AMD EPYC™ 77J3-64 threads RAM: 8 x 60 GB HDD: 8 X 300 GB |
CPU: 14 x 4 core - 2.55 GHz AMD EPYC™ 77J3- 112 threads RAM: 14 x 60 GB HDD: 14 X 300 GB |
Oracle Cloud Infrastructure Equivalent for Application Server |
1 x VM.Standard.E4. Flex (4 OCPUs) |
2 x VM.Standard.E4.Flex (8 OCPUs) |
8 x VM.Standard.E4.Flex (32 OCPUs) |
14 x VM.Standard.E4.Flex (56 OCPUs) |
x86-64/Linux Platform - Database Server |
CPU: 1 x 8 core - 2.55 GHz AMD EPYC™ 77J3- 16 threads RAM: 1 x 120 GB Initial storage: 400 GB Storage growth (annual): 1.2 TB |
CPU: 2 x 16 core - 2.55 GHz AMD EPYC™ 77J3- 64 threads RAM: 2 x 240 GB Initial storage: 2 TB Storage growth (annual): 4 TB |
CPU: 21 x 24 core - 2.55 GHz AMD EPYC™ 77J3- 96 threads RAM: 2 x 320 GB Initial storage: 4 TB Storage growth (annual): 6 TB |
CPU: 2 x 24 core - 2.55 GHz AMD EPYC™ 77J3- 96 threads RAM: 2 x 320 GB Initial storage: 6 TB Storage growth (annual): 12 TB |
Oracle Cloud Infrastructure Equivalent for Database Server |
1 x VM.Standard.E4.Flex (8 OCPUs) |
2 x VM.Standard.E4.Flex (32 OCPUs) |
2 x VM.Standard.E4.Flex (48 OCPUs) |
Based on the 5G Mobile cartridge pack, one service invokes five Web service operations against UIM. Each service is composed of 1 CFS and 2 RFS.
DB Storage is listed without retention calculations. Storage requirements will increase with number of subscriber population and retention period requirements.
UIM 7.5 and later cloud native deployments require an additional 5% compute resources for Kubernetes and container management.
UIM 7.5 and later versions have native application monitoring capabilities which require a minimum 2 GB additional allocation in the heap if the monitoring feature is enabled.
Unified Topology for Inventory and Automation Hardware Sizing Guidelines
Unified Topology for Inventory and Automation (UTIA) is made up of several components that run in Kubernetes environment. The sizing for each of these components is listed in the following tables and the total value represents the hardware footprint that is required to run Kubernetes and the UTIA components. The sizing is divided between application components and database components.
The information in this section is meant as a guideline only. The values in this section are approximate. Accurate sizing for a production system requires a detailed analysis of the proposed business requirements. The guidelines do not account for High Availability, Disaster Recovery environments, or lower testing and development environments. The database storage is listed without retention calculations.
The following tables provide hardware sizing guidelines for UTIA.
Table 2-2 Hardware Sizing Guidelines for Application Components
UTIA Data Characteristics | |||
Vertices and Edges | 10 Million | 25 Million | 50 Million |
No. of Network Nodes | 0.5 Million | 1 Million | 2.5 Million |
No. of Equipments | 0.5 Million | 2 Million | 7.5 Million |
No. of Locations and Network Entity Codes | 0.5 Million | 1 Million | 2.5 Million |
No. of Connectivities | 1 Million | 2 Million | 4 Million |
UTIA Service | |||
UTIA API |
No. of pods: 2 Compute per pod (OCPUs): 1 RAM per pod (GB): 3 Total Compute (OCPUs): 2 Total RAM (GB): 6 |
No. of pods: 3 Compute per pod (OCPUs): 1 RAM per pod (GB): 3 Total Compute (OCPUs): 3 Total RAM (GB): 9 |
UTIA UI |
No. of pods: 1 Compute per pod (OCPUs): 4 RAM per pod (GB): 6 Total Compute (OCPUs): 4 Total RAM (GB): 6 |
No. of pods: 1 Compute per pod (OCPUs): 6 RAM per pod (GB): 9 Total Compute (OCPUs): 6 Total RAM (GB): 9 |
Sub-total |
Compute (OCPUs): 6 RAM (GB): 12 |
Compute (OCPUs): 7 RAM (GB): 15 |
Compute (OCPUs): 9 RAM (GB): 18 |
Unified Operations Message Bus | |||
Kafka Broker |
No. of pods: 2 Compute per pod (OCPUs): 0.5 RAM per pod (GB): 2 Total Compute (OCPUs): 1 Total RAM (GB): 4 |
No. of pods: 3 Compute per pod (OCPUs): 0.5 RAM per pod (GB): 2 Total Compute (OCPUs): 1.5 Total RAM (GB): 6 |
Kafka Consumer |
No. of pods: 2 Compute per pod (OCPUs): 0.25 RAM per pod (GB): 1 Total Compute (OCPUs): 0.5 Total RAM (GB): 2 Note: The capacity of this system allows a seamless processing of upto 20 TPS |
No. of pods: 3 Compute per pod (OCPUs): 0.25 RAM per pod (GB): 1 Total Compute (OCPUs): 0.75 Total RAM (GB): 3 Note: The capacity of this system allows a seamless processing of upto 30 TPS |
No. of pods: 5 Compute per pod (OCPUs): 0.25 RAM per pod (GB): 1 Total Compute (OCPUs): 1.25 Total RAM (GB): 5 Note: The capacity of this system allows a seamless processing of upto 50 TPS |
Kafka Zookeeper |
No. of pods: 1 Compute per pod (OCPUs): 0.5 RAM per pod (GB): 1 Total Compute (OCPUs): 0.5 Total RAM (GB): 1 |
Sub-total |
Compute (OCPUs): 2.0 RAM (GB): 7 |
Compute (OCPUs): 2.75 RAM (GB): 10 |
Compute (OCPUs): 3.25 RAM (GB): 12 |
In-memory Database | |||
PGX |
No. of pods: 2 Compute per pod (OCPUs): 2 RAM per pod (GB): 10 |
No. of pods: 2 Compute per pod (OCPUs): 2 RAM per pod (GB): 15 |
No. of pods: 2 Compute per pod (OCPUs): 2 RAM per pod (GB): 25 |
Sub-total |
Compute (OCPUs): 4 RAM (GB): 20 |
Compute (OCPUs): 4 RAM (GB): 30 |
Compute (OCPUs): 4 RAM (GB): 50 |
Common Authentication | |||
OAM |
No. of pods: 1 Compute per pod (OCPUs): 0.5 RAM per pod (GB): 8 Total Compute (OCPUs): 0.5 Total RAM (GB): 8 |
No. of pods: 1 Compute per pod (OCPUs): 1 RAM per pod (GB): 8 Total Compute (OCPUs): 1 Total RAM (GB): 8 |
OHS |
No. of pods: 1 Compute per pod (OCPUs): 0.5 RAM per pod (GB): 4 Total Compute (OCPUs): 0.5 Total RAM (GB): 4 |
No. of pods: 1 Compute per pod (OCPUs): 0.5 RAM per pod (GB): 4 Total Compute (OCPUs): 1 Total RAM (GB): 4 |
Sub-total |
Compute (OCPUs): 1 RAM (GB): 12 |
Compute (OCPUs): 2 RAM (GB): 12 |
Total Application Components | |||
AMD EPYC™ 77J3 |
Compute OCPUs: 13.5 RAM (GB): 53 |
Compute OCPUs: 16 RAM (GB): 66 |
Compute OCPUs: 18.5 RAM (GB): 90 |
Oracle Cloud Infrastructure equivalent | Shape VM.Standard.E4.Flex (14 OCPU) | Shape VM.Standard.E4.Flex (16 OCPU) | Shape VM.Standard.E4.Flex (19 OCPU) |
The following table provides the hardware sizing guidelines for the database components:
Table 2-3 Hardware Sizing Guidelines for Database Components
Deployment Size | Medium | Large | |
Database Components | |||
UTIA Database |
No. of RAC nodes: 2 Compute per node (OCPUs): 4 RAM per node (GB): 60 Total Compute (OCPUs): 8 Total RAM (GB): 120 Total Storage (TB): 0.3 |
No. of RAC nodes: 2 Compute per node (OCPUs): 8 RAM per node (GB): 120 Total Compute (OCPUs): 16 Total RAM (GB): 240 Total Storage (TB): 0.5 |
No. of RAC nodes: 2 Compute per node (OCPUs): 12 RAM per node (GB): 160 Total Compute (OCPUs): 24 Total RAM (GB): 320 Total Storage (TB): 1 |
OAM |
No. of RAC nodes: 1 Compute per node (OCPUs): 2 RAM per node (GB): 30 Total Compute (OCPUs): 2 Total RAM (GB): 30 Total Storage (TB): 0.1 |
No. of RAC nodes: 1 Compute per node (OCPUs): 4 RAM per node (GB): 60 Total Compute (OCPUs): 4 Total RAM (GB): 60 Total Storage (TB): 0.2 |
Total Database Components | |||
AMD EPYC™ 77J3 |
Compute OCPUs: 10 RAM (GB): 150 Storage (TB): 0.4 |
Compute OCPUs: 18 RAM (GB): 270 Storage (TB): 0.6 |
Compute OCPUs: 28 RAM (GB): 380 Storage (TB): 1.2 |
2 x Shape VM.Standard.E4.Flex 1 x Shape VM.Standard.E4.Flex (2 OCPU) |
2 x Shape VM.Standard.E4.Flex (8 OCPU) 1 x Shape VM.Standard.E4.Flex (2 OCPU) |
2 x Shape VM.Standard.E4.Flex (12 OCPU) 1 x Shape VM.Standard.E4.Flex (4 OCPU) |
Information Requirements
During UIM installation, you are required to enter configuration values such as host names and port numbers. You define some of these configuration values when you install and configure the Oracle database and WebLogic Server.
If you have already installed Oracle Communications products, the installer reads the values from the existing Oracle Communications products and uses them as default values. If no Oracle Communications products are installed, the installer uses the default values shown in the following tables.
Each chapter contains tables for the configuration values.
