Retrieve a list of communication edges terminated on a location
get
/topology/v2/edge/communication/location/eid/{loceid}
Request
Path Parameters
loceid(required): string
The entityid of the location
Query Parameters
nodecategory: string
The node category for the devices
ratecode: string
The ratecode for the edges
technology: string
The technology for the edges
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
Edges retrieved successfully
Nested Schema : schema
Type:
Show Source
object
autoSuggestName: string
availableCapacity: boolean
businessObjectClass: string
capacities: array
capacities
channels: array
channels
costValue1: number
(double)
costValue2: number
(double)
costValue3: number
(double)
createdDate: string
(date)
createdUser: string
edgeType: string
entityId: integer
(int64)
entityVersion: integer
(int32)
fromNode: integer
(int64)
fromNodeBusinessObjectClass: string
fromNodeData: string
fromNodeReferenceId: string
inventoryStatus: string
isChannelized: boolean
isPipeInterfaceTerminated: boolean
lastModifiedDate: string
(date)
lastModifiedUser: string
maxBandwidth: number
maxContiguousChannels: integer
(int32)
pathIds: array
pathIds
Unique Items Required:
true
properties: object
properties
Additional Properties Allowed: additionalProperties
protectedEdge: boolean
ratecode: string
referenceId: integer
(int64)
specName: string
technology: string
toNode: integer
(int64)
toNodeBusinessObjectClass: string
toNodeData: string
toNodeReferenceId: string
totalCapacity: number
trailPaths: integer
(int32)
unitBitRate: number
Nested Schema : Vertex
Type:
Show Source
object
activeEvent: integer
(int64)
activeEventDesc: string
area: string
availablePositions: string
category: string
circle: string
city: string
communication: integer
(int64)
country: string
createdDate: string
(date)
createdUser: string
deviceIdentifier: string
deviceInterfaceId: string
deviceInterfaceName: string
district: string
entityId: integer
(int64)
(int32)
equipmentCategory: string
fromNodeSubNetwork: integer
(int64)
ipv4: string
ipv4Subnet: string
ipv6: string
ipv6Subnet: string
(date)
latitude: number
(double)
locationCode: string
locationName: string
longitude: number
(double)
macAddress: string
networkStatus: string
nodeCategory: string
nodeType: string
occupiedPositions: string
operator: string
pathIds: array
pathIds
true
physicalPortId: string
physicalPortName: string
postalCode: string
properties: object
properties
province: string
(int64)
region: string
relationships: object
relationships
specName: string
state: string
subCategory: string
subNetworkEntityId: integer
(int64)
subNetworkName: string
subType: string
toNodeSubNetwork: integer
(int64)
topologyType: string
zoneId: string
Examples
400 Response
The request isn't valid
401 Response
The request is unauthorized
403 Response
The request is forbidden
404 Response
The requested resource not found
500 Response
An Internal Server Error has occurred
