Retrieve the count of Edges
get
/topology/v2/graph/edge/count
Return the count of Edges
Request
There are no request parameters for this operation.
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
Count of Edges retrieved successfully
Root Schema : schema
Type:
integer(int64)
Examples
400 Response
The request isn't valid
401 Response
The request is unauthorized
403 Response
The request is forbidden
404 Response
The requested resource not found
500 Response
An Internal Server Error has occurred
