Delete an existing edge based on the entityId
delete
/topology/v2/edge/eid/{eid}
Delete an existing edge based on entityId.
Request
Path Parameters
eid(required): string
The entityId of the edge.
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
The edge was deleted successfully.
Root Schema : schema
Type:
string400 Response
The request isn't valid.
401 Response
The request is unauthorized.
403 Response
The request is forbidden.
404 Response
The requested resource not found.
500 Response
An Internal Server Error has occurred.
