Delete an existing edge based on the fromNode and the toNode
delete
/topology/v2/edge/fromnode/{fromnode}/tonode/{tonode}
Delete an existing edge based on the fromNode and the toNode.
Request
Path Parameters
fromnode(required): string
The fromNode entityId of the edge.
tonode(required): string
The toNode entityId of the edge.
Query Parameters
label: string
The label of the edge.
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
The edge was deleted successfully.
Root Schema : schema
Type:
string400 Response
The request isn't valid.
401 Response
The request is unauthorized.
403 Response
The request is forbidden.
404 Response
The requested resource not found.
500 Response
An Internal Server Error has occurred.
