Delete an existing edge based on typeId and referenceId
delete
/topology/v2/edge/typeid/{typeid}/referenceid/{referenceid}
Delete an existing edge based on typeId and referenceId.
Request
Path Parameters
referenceid(required): string
The referenceId of the edge.
typeid(required): string
The typeId of the edge.
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
The edge was deleted successfully.
Root Schema : schema
Type:
string400 Response
The request isn't valid.
401 Response
The request is unauthorized.
403 Response
The request is forbidden
404 Response
The requested resource not found
500 Response
An Internal Server Error has occurred
