2 Working with Inventory Entities
Oracle Communications Unified Inventory Management (UIM) stores items in your inventory as various kinds of entities. Some, such as physical devices or telephone numbers, represent physical or logical resources. Other entities are used for organization or to represent business processes.
Many tasks and procedures are common to most or all entity types, including both resources and other entities. The procedures you use to create, configure, manage, and search are fundamentally the same for most entities. The features and tasks that are specific to particular entity types are covered in the Help topics for those entity types.
See the following topics for more information about working with inventory entities:
Creating Entities
You use the same basic procedure to create all entity types. The specific information you supply varies depending on the entity type and on the specification used to define the entity.
You can create entities in bulk by uploading a spreadsheet with all the list of entities you want to create and uploading it into UIM. See "Creating Entities and Performing Entity-Specific Tasks in Bulk" for more information.
To create entities:
In the navigation section, click the entity link.
For example, if you are creating a Logical Device entity, click the Logical Device link in the Inventory - Resources group.
The entity Search page appears.
In the Search Results section, click Create.
The entity New page appears.
Entity New pages include required fields that are marked with asterisks.
In the Specification list, select the specification you want to use for this entity.
If the ID field does not contain the text AUTOGENERATE, enter a unique ID for the entity.
By default, most entity IDs are generated automatically. Whether the ID is generated automatically or entered manually, it cannot be changed after the entity is created.
(Optional) In the Name and Description fields, enter a name and a description for the new entity. Entering a name and description is optional, but systematic naming strategies are useful in managing your inventory.
Enter information into all fields marked with asterisks.
(Optional) Enter information into non-required fields.
(Optional) To create an additional entity based on the same specification, click Save and Add Another.
Click Save and Continue.
The Summary page for the entity you created appears. If you created multiple entities, you see the Summary page for the last entity you created. See "Working in Entity Summary Pages" for more information.
An entity Summary page appears when you open an entity from the Search Results section. A Summary page enables you to view entity information and complete tasks.
See the following topics for more information about working in Summary pages:
About Summary Pages
Summary pages contain information about an entity. The Summary pages of entities are either arranged into tabs or provide information in a single view.
The Summary pages of the following entities are arranged into tabs, each of which is used for a different purpose.
Logical Device
Device Interface
Logical Device Account
Physical Device
Physical Port
Pipe
Custom Network Address
Equipment
Telephone Number
Party
Place
Network
Inventory Group
Custom Object
Typically, the Summary page of these entities contains the following tabs, which are common to most entity types:
General Information: Displays basic information about the entity and the entity hierarchy. This tab is displayed by default when you open an entity Summary page.
Configurations: Displays any entity configurations created for the entity. This tab is available only when the specification on which the entity is based includes a reference to the entity configuration specification.
Associated Resources: Displays information about the parent entity, network nodes, and custom involvements.
Depending on the entity type, an entity Summary page displays additional or fewer subtabs in the Associated Resources tab. In case of a few specific entities, the Associated Resources tab displays information in subtabs, rather than in sections.
This tab contains the following subtabs/sections:
Parent Entity (where Entity is the entity type; for example, Parent Logical Device, Parent Physical Device, and so on): Displays any associations with the parent entity.
IP Resources: Displays IP resources assigned to the entity.
Network Nodes: Displays any network nodes with which an entity is associated.
Grants Media Streams: Displays any media streams with which the entity is associated.
Custom involvements: Displays any custom associations defined for the entity with other entities that are not otherwise associated.
Consumers: This tab contains the following sections:
Assignments: Displays information about the entities that are assigned to an entity.
References: Displays information about the entity references.
Business Interactions: Displays any business interactions with which the entity is associated.
Groups and Infrastructure: This tab contains the following sections:
Inventory Groups: Displays any inventory groups to which the entity is associated.
Roles: Displays any roles that are associated with the entity.
Places: Displays any places that are associated with the entity.
The Summary pages of the rest of the entities (other than the ones listed above) display information in a single view and are divided into sections that contain different kinds of information.
The sections that you see depend on the entity type. These sections enable you to define the entity's composition, relationships, dependencies, and other attributes.
Many of the sections in a Summary page include links that enable you to update the information displayed in that section. See "Viewing and Updating Entity Information" for more information.
Summary pages also include Actions, Related Pages, and business interaction menus that you use to perform various tasks specific to the entity type.
Opening Entity Summary Pages
You can open entity Summary pages in the following ways:
By searching for entities. See "Searching for Entities" for more information.
By following a link in another Summary page. For example, you can click a link in the Items section of an Inventory Group Summary page to go to corresponding entity Summary page.
You can view and update an entity's basic information from its Summary page. The Summary page displays much of the information entered during entity creation. Some data elements, such as the ID, cannot be changed after the entity is created.
To view and update entity information:
Do one of the following:
For entities whose Summary page displays information in a single view:
Open the Summary page for an entity and click Edit.
For entities that have their Summary page arranged into tabs:
Open the Summary page for an entity, on the General Information tab, click Edit.
Alternatively, search for an entity, select it in the search results, and click the Edit link in the toolbar.
The Information page for the entity appears.
Update the entity information.
You can update most fields, but you cannot change the entity's ID. Required fields are marked with an asterisk.
Click Save and Close.
You return to the entity's Summary page, which displays the updated information
Working with Tables
Much of the information in pages is displayed in tables. These tables all have the same basic functionality, although not all features are available in all tables. You can choose which columns are displayed and the order in which they appear. You can also filter and sort table contents so that only the most relevant information is displayed.
All tables include a View menu with commands that control appearance and content. Tables also have toolbars that contain icons for specific actions. The selection of icons varies from table to table. Some of the icons correspond to commands in the View menu. Others
See the following topics for more information about working with tables:
Showing and Hiding Columns
By default, tables display all the columns that are available to them. You can change the default arrangement of columns so that only the columns you want are displayed. Your changes persist only for the current session.
To show or hide table columns:
In the View menu of a table, select Columns.
The Columns menu appears. This menu includes the Show All option, a list of the first 10 columns in the table, and the Show More Columns option.
Select Show All to display all the available columns. The columns are displayed immediately.
Select or deselect a column name to show or hide that column. The changes appear immediately.
Select Show More Columns to open a dialog box in which you can work with all available columns.
The Show More Columns dialog box appears.
Select columns in the Hidden Columns or Visible Columns list and click the Move or Remove button to transfer columns from one list to the other.
Click the Move All or Remove All button to transfer all columns.
(Optional) Select columns in the Visible Columns list and click the up or down arrows to the right of the list to change the column order.
Click OK.
The table displays the column arrangement you specified.
Reordering Table Columns
You can specify the order of columns that appear in a table. Your changes persist only for the current session.
To reorder table columns:
In the View menu of a table, select Reorder Columns.
The Reorder Columns dialog box appears, containing a list of the visible columns in the table.
Select columns in the Visible Columns list and click the arrow buttons to the right of the list to change the column order.
Click OK.
The table displays the column order you specified.
Filtering Table Contents Using Query by Example
In some tables, you can filter contents by using Query by Example (QBE).
When you enter criteria in the QBE fields above columns, the table is filtered to show only rows that match all the criteria. For example, if you enter In Progress in the Status QBE field and Customer in the Specification QBE field, the table is filtered to show only rows that include the entities created with a specification that begins with the string Customer and that have a status of In Progress.
Criteria that you enter in a QBE field apply only to the column below the field.
To filter table contents:
In the View menu of a table, select Query By Example.
Text fields appear above the columns that are enabled for QBE.
Enter a filter criterion above a columns, then press the Enter key.
The table contents redisplays to show only rows that include the criterion you entered.
Repeat to apply additional criteria.
Sorting Tables
You can sort the contents of tables into ascending or descending order based on values in certain columns. For example, you could sort the places associated to a logical device into alphabetical order.
To sort table contents:
In the View menu of a table, select Sort, then select Advanced.
The Advanced Sort dialog box appears.
In the Sort By list, select a column. Note that not all columns are available for sorting.
Click Ascending or Descending.
Click OK.
UIM sorts the table contents based on your selections.
Scrolling Automatically in Tables
You can scroll automatically to the beginning or end of a table.
To scroll automatically in a table:
In the View of a table, select Scroll to First or Scroll to Last.
The table scrolls to the first or last entry in the table.
Detaching Tables
You can detach tables from the page in which they are located. A detached table appears in a separate window. Detaching a table is particularly helpful when the table is long or complex. The separate window provides additional space.
The detached window includes the same menus and toolbar icons that were available for the table in the original page.
To detach a table:
In the View of a table, select Detach.
The table appears in a new window separate from the original page.
Close the window to return to the original page.
Entity Summary Page
You use entity Summary pages to define the content for entities.
Two menus appear at the top of the page. See the following for a description of the commands:
Information in Summary pages is often displayed in tables. See "Working with Tables" for instructions about using tables.
The following table lists command options that are common among multiple entity Summary pages. See the Help for a specific entity Summary page for more information about the fields and sections that are unique to that entity.
| Command | Description |
Edit |
Click to change the values for fields that appear in the Information section. |
Topology |
Click to view the entity in a topology diagram that appears in the ATA application. See "Working with the Inventory Topology" for more information. |
Business Interaction context indicator |
This indicator is visible only for entities that support business interactions. Click and do one of the following:
Your selection sets the business interaction context and appears in the menu in the upper-left of the page. See "Working with Business Interactions" for more information. |
Related Pages Menu
Use this menu, which appears on entity Summary pages, to perform operations on pages that are related to the entity. The commands that appear in the Related Pages menu are determined by the entity Summary page from which you access the menu.
Conditions |
Select to define conditions for blocking resources from being used or assigned for a period of time or to define messages to be displayed when resources are assigned. See "Working with Conditions" for more information. |
Reservation |
Select to view, edit, or delete existing reservations or to create new reservations. Resources can be reserved by an entity or process to prevent them from being assigned to another entity or process. See "Creating a Reservation from a Summary Page" for more information. |
Map View |
Select to review the network nodes and edges visually and in relation to each other based on latitude and longitude. Network nodes must be associated with a place that includes a latitude and longitude or associated to a place that is associated with an address that has a latitude and longitude. See UIM Developer's Guide for information about setting up UIM for geocoding. See "Using the Map View" for more information about working in the Map View page. |
Map Profile |
Select to access the Map Profile page, which enables you to create custom map views. The map profile controls how a map displays when it opens for each network. You must select a map profile before you can review a network in the Map View page. There are additional implementations required to use map functionality. See UIM System Administrator's Guide for information about setting up UIM to use with maps. See "Working with Map Profiles" for information about setting up map profiles. |
Manual Configure |
Select to manually enable a pipe. This option is available for unversioned pipes with no configuration versions) only. See "Manually Enabling an Unversioned Pipe" for more information. You enable versioned pipes per configuration. See "Manually Enabling a Versioned Pipe" for more information. |
Graphic View |
Select to view a visualization of the enablement of a pipe or pipe configuration. See "Viewing a Pipe Enablement Visualization" for more information. |
Path Analysis |
Select to run a path analysis on the pipe. You can use path analysis to automatically enable a trail between two entities that you specify. See "Running a Path Analysis" for more information. |
Provides |
Select to view any existing child pipes or create new child pipes. See "Working with Child Pipes" for more information. |
Tree View |
Select to view and define the equipment hierarchy in the Equipment View page. See "Equipment View Page" for more information. |
Related Topics
Actions Menu
Use this menu, which appears on entity Summary pages, to perform actions specific to the entity displayed in the entity Summary page.
The commands that appear in the Actions menu are determined by the entity Summary page from which you access the menu. Not all commands apply to every entity. These commands are listed in alphabetical order.
Activate |
Select to make an entity available to support services or other resources. The inventory status is changed to Installed. |
Approve Configuration |
Select to change the status of service configurations in a business interaction from In Progress to Designed status. Service configurations already in Designed status are not affected. The status of the business interaction itself is not affected by this operation. |
Associate Business Interaction |
Select to associate a business interaction to a configuration version. The configuration summary must be set in the context of the desired business interaction or this action is disabled. You can use this when you want a configuration version associated to a business interaction, for instance for multiple pending configuration functionality support. This action overrides the start date of the configuration with the effective date and time of the business interaction. See "Working with Multiple Pending Configurations" for more information. |
Cancel |
Select to:
Cancel Hierarchy |
Select to cancel all of the business interactions in a hierarchy. You cannot cancel a business interaction hierarchy when it contain one or more child business interactions. See "Canceling a Business Interaction" for more information |
Complete |
Select to:
Complete Hierarchy |
Select to complete all of the business interactions in a hierarchy. See "Completing a Business Interaction" for more information. |
Deactivate |
Select to indicate that an entity is unavailable to support services or other resources. The inventory status is changed to Unavailable. |
Disassociate Business Interaction |
Select to remove a business interaction from an entity. |
Disconnect |
Select to disconnect a service, pipe, or connectivity. When you select this option, the resource status changes to Pending Disconnect. After the request to disconnect the service is completed, the status changes to Disconnected. You cannot disconnect a member service unless its parent network service has an active (In Progress) service configuration. You see an error message if you try to disconnect a member service when the parent network service has no active configuration. See "About Network-Oriented Services" for more information about network and member services. |
Issue Configuration |
Select to change the status of service configurations in a business interaction from Designed to Issued status. Service configurations already in Issued status are not affected. The status of the business interaction itself is not affected by this operation. |
Map Signal Structure |
Select to manually associate a pipe with a signal structure when the entity has not already been associated with a Pipe entity through the specification. See "Mapping a Signal Structure to a Pipe" for more information. |
Resume |
Select to reactivate a suspended service. |
Snapback |
Select to transition a telephone number from Ported Out state to Unassigned. See UIM Base Cartridges Guide for more information. |
Suspend |
Select to render a service temporarily nonfunctional. The resource assignments are maintained with an assignment status of Assigned. When you select this option, the status changes to Suspended. You can resume or disconnect a suspended service. You can also suspend a service that is in Pending Disconnect status. |
Validate |
Select to validate an entity or configuration. See "Validating Entities and Entity Configurations" for more information. |
Related Topics
Managing Entity Life Cycles
Many types of entities have a life cycle that you can manage. A life-cycle-managed entity has a set of statuses and transitions through which it moves over time. An entity's status is displayed in the Search Result section, Summary pages, and in page sections that display information about an entity.
An entity's inventory status is different from its assignment status. The inventory status reflects the entity's life cycle and the assignment status reflects whether it has been assigned as a resource.
The current inventory status of an entity governs which actions you can take and which statuses it can move to. For example, a service in Pending status can move only to In Service or Canceled status. See UIM Concepts for more information. See "Changing Entity Statuses" for information about changing an entity's status.
When you change the status of a parent entity, the status of any child entity in its hierarchy is also changed. For example, if you deactivate a logical device, all logical devices in the hierarchy are also deactivated.
All entities that can be included in business interactions are life-cycle managed. An entity's status and transitions can be different in the context of a business interaction than they are in current inventory. See "Working with Business Interactions" for more information.
Life cycles of configurations that are included in engineering work orders can be controlled by the life cycle of the work order. See "Controlling Configuration Version Life Cycles from Engineering Work Orders".
A life-cycle-managed entity moves through a series of transitions that change its status. The transitions can occur automatically when rulesets are triggered or as the result of a manual action in UIM.
To change entity statuses:
Open the Summary page for an entity.
See "Opening Entity Summary Pages" for more information.
From the Actions menu, select the command for the transition you want to make.
The available commands reflect transitions that are valid for the entity in its current status. After you select a command, the Summary page refreshes and the entity's status is updated.
Related Topics
Working with Entity Hierarchies
Many entities include hierarchies of child entities. The hierarchy can be any number of levels deep, so a child entity can also be a parent. An entity can have any number of children, but only one parent. In addition to child entities of the same type, some hierarchies can include additional kinds of entities. For example, a logical device hierarchy can include not only other logical devices, but also device interfaces.
In some cases, the entities that you can add to a hierarchy are constrained by relationships between entity specifications. For example, if a Logical Device specification includes specification relationships to one or more other Logical Device specifications, then only logical devices based on the related specifications can be added to the hierarchy.
An entity with a hierarchy includes a Hierarchy section in its Summary page. This section displays a collapsible tree view of child entities descending from the entity you are viewing. You use this section to add and remove child entities. Child entities appear in a Hierarchy section as clickable links, which enable you to navigate to the child entity Summary page.
Summary pages for some types of entities also include a Parent section that displays a link to the parent entity. If the entity does not currently have a parent, you can add one. You can also remove a parent entity relationship.
See the following topics for more information about working with entity hierarchies:
Adding Child Entities
You can add as many child entities to an entity as you require. You can create a nested hierarchy of entities by adding child entities that themselves already have children or by adding the children directly. You can add child entities to any entity that appears in the hierarchy.
You cannot add child entities that would create circular relationships. For example, you cannot add the same entity to more than one place in the same hierarchy. UIM displays an error message if you attempt to add an entity that is not valid in that location.
To add a child entity:
Open the Summary page for an entity to which you want to add a child entity.
In the Hierarchy section, expand the hierarchy to the level of the immediate parent of the child you want to add.
Right-click the parent of the new child entity, then select Add Child. (In some cases, the command is customized to the reflect the entity type.)
The Search page appears.
Search for an existing child entity. See "Searching for Entities" for more information.
Create a new child entity. See "Creating Entities" for more information.
In the Search Results section, select the entity you want to be the child.
Click OK.
The Hierarchy section in the Summary page is updated to include the entity you added. Click the entity name to view the child entity in the child entity Summary page.
Removing Child Entities
You can remove a child entity in the Hierarchy section of an entity's Summary page. This is equivalent of going to the child entity's Summary page and removing the child's parent.
You can remove child entities from any entity displayed in the Hierarchy section.
To remove a child entity:
Open the Summary page for an entity from which you want to remove a child entity.
In the Hierarchy section, expand the hierarchy to the level of the child you want to remove.
Right-click the child entity that you want to remove, then select Remove.
The entity is removed from the hierarchy.
Adding Parent Entities
You can define for an entity a single parent entity. Adding a parent entity establishes the same relationship as if you had added the current entity as a child from the parent entity's Summary page.
You can select as parent entities only active entities. Also, you cannot add an entity that would create a circular relationship. For example, you cannot add an entity as a parent that is already a child in the same hierarchy. UIM displays an error message if you attempt to add a parent entity in an invalid location.
Not all entities support hierarchies. Summary pages contain Parent sections only when the entity supports hierarchies.
To add a parent entity:
Open the Summary page for an entity to which you want to add a parent entity.
In the Parent section, click Associate.
Search for an existing parent entity. See "Searching for Entities" for more information.
Create a new parent entity. See "Creating Entities" for more information.
In the Search Results section, select the entity you want to be the parent.
Click OK.
The Parent section in the Summary page refreshes to include the entity.
Deleting Parent Entities
If you want to disassociate an entity from its parent, you can delete it from the Parent section of the entity's Summary page. This is equivalent to deleting the entity from the hierarchy in the parent entity's Summary page.
To delete a parent entity:
Open the Summary page for an entity from which you want to delete a parent entity.
In the Parent section, select an entity to delete.
Click Delete.
The parent entity is removed from the Parent section, and the Associate button is enabled.
Working with Entity Configurations
You can define configurations for some types of entities. Configurations enable you to record facts about the entity that change over time and maintain a history of successive versions. For example, when you add a new VPN site to an MPLS VPN service, you can create a new version of the service configuration to reflect the change.
The following types of entities can have configurations:
Flow Interfaces
Logical devices
Logical device accounts
Networks
Pipes
Places (of type Site only)
Services
You can add new versions to a configuration as the entity evolves over time. Typically, before you can add a new version, the previous version must have gone through its entire approval cycle and be in Completed status. (You can also cancel a version in In Progress status and then create a new version.) See "Managing Entity Life Cycles" and for more information.
When you create a new version of a configuration, it is initially the same as the previous version, except for the ID, name, and version number. You can make any changes required for the new version.
Configurations are separate entities that are defined by specifications. The specification of the base entity determines which specifications can be used for its configurations. When you add a configuration, you can choose from among the configuration specifications that allowed by the base entity specification.
Configurations include two features not available in other entities:
Configuration items define the content of the configuration. They are arranged hierarchically and display according to the order set up in configuration specification. Some items are included by default in the configuration. Others you must add manually.
Specification options define which types of entities can be assigned to or referenced by configuration items. A configuration item with a specification option includes a list of the specification types that are valid for that item. You choose the appropriate specification for the item, then you assign or reference an entity of that type.
You can have more than one pending configuration for some services. You can have multiple pending configurations, if the functionality is enabled, with pending configurations spread over a period of time for non-network services. So, you can add a new configuration version before the previous version is in Completed status. For multiple pending configurations, you must associate each configuration to a Business Interaction. The multiple pending functionality is enabled depending on a system property for the UIM installation. See "Working with Multiple Pending Configurations" for more information.
Understanding Entity Configurations
See the following topics for more information about working with entity configurations:
Working in Configuration Summary Pages
Entity configurations are displayed in Configuration Summary pages. Configuration Summary pages are similar to entity pages, with two major differences:
The Actions menu contains different commands.
Configuration Summary pages include a Configuration Items section. See "Working with Configuration Items".
Pipe Configuration Summary pages are different from others. See "Working with Pipe Configurations" for more information.
Configuration Summary Actions Menu
The Actions menu in Configuration Summary pages enables you control manage various aspects of configurations, including life cycle, validation, and auto-assignment of resources. These commands are in alphabetical order.
Approve |
Select to approve a configuration version. See "Managing Configuration Version Life Cycles" for more information. |
Auto-Configure |
When enabled by a ruleset, select to automatically assign resources. See "Assigning Resources Automatically" for more information. |
Cancel |
Select to cancel a configuration version. See "Managing Configuration Version Life Cycles" and "Canceling a Configuration Version with Multiple Pending" for more information. |
Complete |
Select to complete a configuration version. See "Managing Configuration Version Life Cycles" and "Completing a Configuration Version with Multiple Pending" for more information. |
Create New Version |
Select to create a new configuration version. Available only when the previous version is complete. See "Adding Additional Configuration Versions" for more information. |
Select to remove a business interaction from a configuration version. See "Working with Multiple Pending Configurations" for more information. |
Issue |
Select to issue a configuration version. See "Managing Configuration Version Life Cycles" for more information. |
Validate |
Select to validate the configuration. See "Validating Entities and Entity Configurations" for more information. |
Adding the First Version of a Configuration to an Entity
The following procedure describes how to add a new configuration for an entity with no previously defined configurations. See "Adding Additional Configuration Versions" if you are adding a new version for an existing configuration.
To add the first version of a configuration:
Open the Summary page of the entity for which you are creating a configuration.
In the Configurations section, click Create. The Create button is active if one of the following is true:
The configuration entity has no existing configurations.
The previous configuration version has a status of Completed.
Multiple pending configuration functionality is enabled and the entity is a non-network service.
The Configuration Information - New Version page appears.
(Optional) Change the automatically generated ID and name.
The default ID and name are based on the ID and name of the base entity with the version number of the configuration added.
(Optional) In the Start Date field, enter or select the date at which the configuration becomes valid.
The field displays the current date by default.
The Configuration Summary page appears.
Specify configuration characteristics and specify configuration item details.
See "Viewing, Entering, and Changing Characteristics" and "Working with Configuration Items" for more information.
You add additional configuration versions different ways depending on if you need multiple pending configuration functionality. In all cases, after the first version of a configuration has been completed, you can add versions when the configuration details change.
If multiple pending configuration functionality is enabled, then you can also add additional configuration versions for non-network service entities before the previous version reaches Completed status.
You can create new configuration versions and change their configuration item details in the following ways:
From the Summary or Configuration page when the previous configuration is in Completed status, see "Adding Additional Configuration Versions without Multiple Pending".
From the Service summary page when multiple pending configuration functionality is enabled (for a non-network service), see "Adding Additional Configuration Versions for Services with Multiple Pending".
Follow these steps if you do not need multiple pending configuration versions.
To add a configuration version:
Open the Summary page of the base entity.
Open the Configuration page of the previous version of the configuration.
In the Configurations section of the Summary page, click Create or from the Actions drop down, select Create New Version.
(Optional) Change the name and automatically generated ID.
The ID and name are incremented from the previous version.
(Optional) In the Start Date field, enter or select the date at which the configuration becomes valid. If the configuration version is in the context of a Business Interaction, the Start Date field will take the same value as the Effective Date on the Business Interaction.
The Configuration page appears, displaying the values from the previous version.
Change configuration characteristics and specify configuration item details as required.
When multiple pending configurations are enabled, you can add versions for changing the configuration details when:
You want multiple open or pending configuration versions for a non-network service, and
There are no configuration versions, or the preceding configuration is still in progress.
If previous configuration pending version exists, each is also associated to a Business Interaction.
You want multiple open or pending configuration versions on the same day but with different timestamp values.
Select Business Interactions and do the following:
In the Business Interaction search page, select Create.
Select the desired specification (for example, Service Order).
Enter the name as it is required.
In the Effective Date field, provide the value of the due date and time or start date and time of the configuration version. This is the date and time when the configuration version becomes valid.
If you select a Workflow Template, the system displays current date and time in Effective Date and changes the field as non-editable. -
Open the Summary page of the Service entity.
Expand the Configurations section of the Service entity.
If multiple pending configurations is disabled, the Create button is active only if the previous version is in Completed or Canceled status. After you click Create, the Configuration Information - New Version page appears.
The Start Date field defaults to the Effective Date and time of the associated Business Interaction. You can change the Start Date and time from the Configuration Information - New Version page.
You can create multiple pending configurations on the same day but with different timestamp values. -
The Service Summary is displayed with the new configuration version.
Select the new configuration version.
For certain types of services, UIM supports multiple pending configurations where more than one configuration may be in progress at a given time. Multiple pending configuration functionality is only available for non-network services. You determine if a service is a network service by the Network Oriented Service Type attribute setting on the service entity. For network services only one configuration can be in progress at a time.
Multiple pending configuration functionality is enabled with a system property in the system-config.properties file. The default is for the functionality to be enabled. See "Unified Inventory Management System Administration Overview"UIM System Administrator's Guide for information on this property.
You can create an in-progress configuration before or after any existing in-progress configuration when:
The multiple pending functionality is enabled in the system property file.
Each configuration version is associated to its own Business Interaction.
The entity for the configuration is a Service entity and it is a non-network service.
The effective date on the Business Interaction determines the start date and time value for the configuration. You can create configurations before or after a configuration that is in progress, however the start date must always be on or after the current date.
Each pending configuration version must have a different start date and time; no two pending configuration versions can have the same start date and time.
Often, when you change a configuration, it affects other pending configurations to reflect your change. The configuration items include their identifier in the name so you can see the cascading effects in future configurations.
See "About Unified Inventory Management"UIM Concepts for more information.
Adding to or Removing Resources from a Pending Configuration Version
With multiple pending configuration functionality, you can add and remove resources across multiple configuration versions that are in progress. For example, you can create a new configuration version and add a new telephone number. Then, you can add another future-dated configuration, and remove a telephone number. This results in two configuration versions being in progress.
See "Adding Additional Configuration Versions" for information on how to add more than one pending configuration.
Changing the Date for a Pending Configuration Version
With multiple pending configuration functionality, you can have more than one pending configuration version for a non-network service. If it is not associated to a Business Interaction, you must first select or create a Business Interaction and associate it to the service configuration version. To change the date of a pending configuration when the configuration version is associated to a Business Interaction:
Open the Configurations section of the non-network Service entity.
Select the configuration version for the date change.
The Service Configuration Version page appears.
Click the Associated To Business Interaction field value to display the associated Business Interaction entity.
The Business Interaction Summary page appears.
Click the Edit button.
The Business Interaction Information page appears for edit.
Change the date value of the Effective Date field.
The date is changed for the Business Interaction and also for the configuration's Start Date field. To view the configuration, select its ID value in the Business Interaction Items list.
See"About Unified Inventory Management" in UIM Concepts for more information.
You can cancel a pending configuration version by canceling the associated Business Interaction when multiple configurations versions are pending for a non-network Service.
You can also cancel a pending configuration version that is in between two in-progress configuration versions, provided that no resource assignment changes are made in the configuration version that immediately succeeds the configuration version that you are canceling.
If a service has multiple pending configurations, you cannot cancel the first service configuration version, regardless of the status of the resource assignments. However, if a service has only one service configuration, then you can cancel that service configuration version.
You cannot cancel a service configuration version on a service that is not in Pending Disconnect status if there are resource assignment changes in the future-dated service configuration version. However, you can cancel a service configuration version on a service that is in Pending Disconnect status, even if resource assignments are updated and are in Pending Unassign status in the future-dated disconnect service configuration version.
To cancel a pending configuration when the configuration is associated to a Business Interaction:
Select the configuration version that you want to cancel.
Click the Associated To Business Interaction field to display the associated Business Interaction entity.
Click the Actions menu, and click Cancel option.
The Business Interaction and the associated service configuration version are canceled.
See "About Unified Inventory Management" in UIM Concepts for more information.
You can complete a pending configuration version by completing the associated Business Interaction when multiple configurations versions are pending for a non-network Service.
If a non-network Service entity contains multiple pending configuration versions, you must first complete the initial version of the pending configuration before completing the immediate succeeding version. For example, if a non-network Service entity contains five configuration versions, you must first complete configuration version 1, and then complete configuration version 2, and so on.
To complete a pending configuration when the configuration is associated to a Business Interaction:
Select the configuration version that you want to complete.
Click the Actions menu, and click Complete option.
The Business Interaction and the associated service configuration version are completed.
Disconnecting a Service with Multiple Pending Configurations
To disconnect a service with multiple pending configurations, you must have the latest service configuration version associated to a Business Interaction. To disconnect a service with one or more pending configurations (when the configurations are associated to Business Interactions):
Open the Service entity that you want to disconnect.
Click the Actions menu, and click Disconnect option.
A new configuration version is created and the service transitions to Pending Disconnect status. The default for the start date of the new configuration version is the date of the latest pending configuration version plus one calendar day.
See "Changing the Date for a Pending Configuration Version" for more information.
Configuration versions have a life cycle that you can manage either manually or by using rulesets.
The configuration version status is different from the status of its parent entity.
| Command | Transitions from Status | Transitions to Status |
Approve |
In Progress |
Designed |
Issue |
Designed |
Issued |
Complete |
Issued Pending Cancel |
Complete Canceled |
Cancel |
In Progress Designed Issued |
Canceled Canceled Pending Cancel |
To change configuration version statuses:
Open the Summary page for a configuration.
See "Opening Configurations" for more information.
The available commands reflect transitions that are valid for the configuration in its current status. After you select a command, the Configuration Summary page refreshes and the configuration version's status is updated.
Entities that support configurations have a Configurations section in their Summary pages. This section displays the existing configurations and statuses. Versions that have been completed cannot be modified. You must create a new version to introduce any changes to the configuration.
To open a configuration:
In the Configurations section, click the version number link of the configuration you want to open.
The Configuration page appears. The hierarchy in the Configuration Items section is collapsed but includes the default selection of configuration items.
Managing the Configuration Hierarchy Display
Configurations often contain complex hierarchies of configuration items displayed in a collapsible tree view. You can expand and collapse individual lines in the tree view by clicking the triangles next to them. You can also expand and collapse the entire or hierarchy or portions of it.
To expand or collapse the hierarchy as a whole:
In the View menu in the Configuration Items section of a Configuration Summary page, select Expand All or Collapse All.
Select the highest-level row in the hierarchy, then right-click and select Expand All or Collapse All.
The hierarchy expands to display all configuration items.
To expand or collapse a section of the hierarchy:
In the Configuration Items section of a Configuration Summary page, select a row in the hierarchy.
In the View menu, select Expand All Below or Collapse All Below.
The hierarchy below the select row expands to display all configuration items.
To define the hierarchy and order of configuration items, refer to the configuration specification definition. For instructions on how to define configuration specifications in Design Studio, see "Getting Started with UIM (1)"in SCD Design Studio Modeling Inventory.
Configuration items define a hierarchy of information about how a configuration is implemented. Configuration items can be used to assign resources to a configuration or to refer to entities that have significance to the configuration. For example, a place configuration for a VPN site can include configuration items for resources that are consumed, such as PE VRF resources and CE service locations. Similarly, a cable TV subscription service configuration could include a configuration item for a reference to an access controller. In this case, the resource is not consumed, it is referenced.
Configuration items can also be used to collect information rather than assign resources. For example, a configuration item in a VPN service configuration could have a characteristic that defines the topology of a VPN service as meshed, hub-and-spoke, or hybrid.
Configuration items can contain other configuration items, so information can be nested to reflect how resources are organized. For example, a configuration item for PE VRF resources can include other configuration items such as route distinguishers, route targets, and protocols.
The selection, arrangement, order, and content of configuration items is defined in the specification for the configuration. The specification defines which configuration items are required, minimum and maximum quantities, the characteristics applied to items, and specification options that enable you to assign or reference resources to configuration items.
If a configuration specification defines a non-zero minimum quantity for a configuration item, that minimum quantity is created automatically when you create the configuration.
The configuration name includes two portions:
The name set up in Design Studio.
The system generated identifier for the configuration item.
Then, you can uniquely identify a configuration item when changes are cascaded forward. These changes can occur from multiple pending configurations. See "Working with Multiple Pending Configurations" for information on this functionality.
See the following topics for more information about working with configuration items:
Adding Configuration Items
When you add a configuration to an entity, the configuration automatically includes the required configuration items in the required quantities. You can add additional configuration items that are defined in the configuration's specification, up to the maximum quantity.
When you add a configuration item that includes specification options, you must assign to the item an entity based on one of the specifications. In some cases where rulesets have been defined, entities are assigned automatically. See "Assigning Entities to Configuration Items" for more information.
To add configuration items:
Open the Configuration page for the configuration to which you want to add configuration items.
In the Configuration Items section, expand the hierarchy until you reach the folder level that is immediately above the configuration item you want to add.
Right-click the folder and select Add Config Item.
The Choose Configuration Items to be Added dialog box appears, displaying a table of configuration items that are valid in this location in the hierarchy.
In the Quantity column, specify quantities for each item you want to add.
You can add quantities only up to the maximum defined for an item. Items that have reached their maximum quantity cannot be added.
Click Add Items.
The Configuration Items hierarchy refreshes to show the new items.
When a configuration item is defined for assignment, you use it to select entity to be consumed. You select a specification and then select an entity based on that specification.
UIM can be configured to assign resources automatically. See "Assigning Resources Automatically".
To assign entities to configuration items:
Open the Configuration page for the configuration to which you want to assign resources.
In the Configuration Items section, expand the hierarchy until you reach the configuration item to which you want to assign an entity.
In the Specification column, select the specification of the resource you want to assign. If only one specification is valid, it is automatically displayed.
In the Actions column, click Assign.
The Assign to Configuration page appears.
Search for an existing entity to assign. See "Searching for Entities" for more information.
Create a new entity to assign. See "Creating Entities" for more information.
In the Search Results section, select an entity then click OK
The entity you assigned appears as a link in the configuration item. You can click the link to go to the Summary page for the entity.
Referencing Entities to Configuration Items
If a configuration item is defined for entity reference rather than assignment, you use it to refer to an entity that has significance to the configuration. You select a specification, then select an entity based on that specification to be referenced by the configuration.
To reference entities from configuration items:
Open the Configuration page for the configuration in which you want to reference an entity.
In the Configuration Items section, expand the hierarchy until you reach the configuration item to which you want to reference an entity.
In the Specification column, select the specification of the entity you want to reference. If only one specification is valid, it is automatically displayed.
In the Actions column, click Reference.
The Reference Entity to Configuration page appears.
Search for an existing entity to reference. See "Searching for Entities" for more information.
Create a new entity to reference. See "Creating Entities" for more information.
In the Search Results section, select an entity and click OK
The entity you referenced appears as a link in the configuration item. You can click the link to go to the Summary page for the entity.
UIM can be customized to automatically assign resources based on default values. When you automatically assign resources, appropriate configuration items are created and resources automatically assigned to them.
Automatic assignment is enabled by rulesets. See "About Unified Inventory Management" in UIM Concepts and "Overview" in UIM Developer's Guide for more information about rulesets. Automatic assignment can take place at the level of individual configuration items or at the level of an entire configuration. Automatic assignment for individual items occurs when you add the item to a configuration (or when it is added as a default item).
To automatically assign resources to a configuration:
Open the Configuration page in which you want to automatically assign resources.
From the Related Pages menu, select Auto Configure.
UIM automatically assigns resources and redisplays the Configuration page. You can see the newly assigned items by expanding the hierarchy in the Configuration Items section.
Configuration items can have characteristics that store information about the item. These characteristics are defined in the specification for the configuration. For example, a configuration item for a protocol could include characteristics that define how the protocol is implemented. Characteristics can also be assigned to the configuration itself, at the top level of the configuration item hierarchy.
Characteristics can take several forms:
Text fields
Check boxes
Lists
Calendar fields
You view, enter, and change values for specific configuration items and for the configuration as a whole.
To view, enter, or change characteristics:
Open the Configuration page for the entity for which you want to change, view, or enter characteristics.
In the Configuration Items section, expand the hierarchy until you reach the item that has the characteristics you want.
Edit characteristics for the entire configuration.
Expand a configuration item.
An item called Characteristics appears.
Right-click Characteristics and select Maintain Characteristics.
The Configuration Item Characteristics dialog box appears, displaying all of the item's characteristics and their values.
Edit the configuration as necessary and click Save and Close.
Edit characteristics for a single configuration item:
Expand the Characteristics item.
Separate items for all the item's characteristics appear. The value of each characteristic is shown.
Right-click a characteristic and select Edit Characteristic.
The Configuration Item Characteristics dialog box appears, displaying the characteristic value.
Viewing Tags on Configuration Items
You can view tags on configuration items.
To view tags on configuration items:
Open the Configuration page for the entity for which you want to view tags.
In the Configuration Items section, expand the hierarchy until you reach the item that has the tags you want to view.
Renaming Configuration Items
You can change the names that are automatically assigned to configuration items.
To rename a configuration item:
Open the Configuration page for the configuration that includes the item you want to rename.
In the Configuration Items section, expand the hierarchy until you reach the configuration item you want to rename.
Right-click a configuration item and select Rename Item.
The Rename Configuration Item dialog box appears. You can only modify the portion of the name without the configuration item identifier.
Enter the new name for the item and click Rename Configuration Item.
The configuration item is renamed.
Changing the Entity Assigned to or Referenced from a Configuration Item
You can change the entity that is assigned to or referenced a configuration item. You can change resources that were assigned automatically as well as those that were assigned manually.
To change a resource assigned to or referenced from a configuration item:
Open the Configuration page for the configuration that contains the entity assignment or reference that you want to change.
In the Configuration Items section, expand the hierarchy until you reach the configuration item whose assignment or reference you want to change.
In the Actions column, click the Unassign or De-Reference link.
The assigned or referenced entity is removed. You can now assign or reference a different entity.
Removing Configuration Items
You can remove configuration items. You cannot remove a configuration item if doing so violates the minimum quantity of the item defined for the configuration.
To remove a configuration item:
Open the Configuration page for the configuration that includes the item you want to remove.
In the Configuration Items section, expand the hierarchy until you reach the configuration item you want to remove.
Right-click the configuration item and select Remove Item.
The configuration item is removed. An error message appears if you try to remove an item that is required by the item's minimum quantity or if you are attempting to remove an item that has an assignment or a reference.
Configuration New Page
You use an entity Configuration- New page to create new versions of the entity.
| Field | Description |
Specification |
Select a specification to define the new configuration. Configurations are separate entities that are defined by specifications. The specification of the base entity determines which specifications can be used for its configurations. When you add a configuration, only valid specifications appear as options in this field. |
Previous Configuration |
Displays the number of the configurations created prior to this version. If you are creating the first configuration version, this value is 0. This field is read only. |
Version |
Displays the version number of the configuration. This field is read only. |
ID |
(Optional) Edit the automatically generated ID, if necessary. The ID is based on the ID of the base entity and the version number of the configuration. |
Name |
(Optional) Edit the automatically generated name, if necessary. The name is based on the ID of the base entity and the version number of the configuration. |
Start Date |
Enter or select the date at which the configuration becomes valid. The field displays the current date by default. |
You can validate some types of entities and configurations. By default, these validations check basic integrity, but the rulesets governing them can be customized. For example, a validation ruleset might ensure that a Service configuration includes resources in the correct quantities. See "About Unified Inventory Management" in UIM Concepts and "Overview" in UIM Developer's Guide for more information about rulesets.
To validate an entity or entity configuration:
In the Configuration section, click the version number link of the configuration you want to validate.
From the Actions menu, select Validate.
UIM validates the entity or configuration and displays any resulting error messages in the upper part of the page. If no problems are found, no messages are displayed.
Working with Visualizations and Diagrams
A number of entities utilize visualizations or diagrams, each for a different purpose. The interface for each, however, is similar.
Service entities include a diagram of the service topology that appears in the ATA application. See "Working with the Inventory Topology".
Network entities include a topological view in which you can configure the network. See "Designing a Network in the Network Topological View".
Equipment entities include a visualization feature in which you can configure the equipment's hierarchy of child entities. See "About Equipment Visualizations".
The ATA application displays the topology diagram of your entire inventory. See "Working with the Inventory Topology".
Pipe and Connectivity entities include visualizations that depict their design and enablement. See "Viewing a Pipe Enablement Visualization" and "Working with the Connectivity Design Visualization".
See the following topics for more information about working with visualizations and diagrams:
About Visualization and Diagram Pages
Each diagram or visualization page has a different purpose and works in a somewhat different way. The basic arrangement of the page is similar for all, however:
A large page or canvas displays the diagram or visualization. The contents of the canvas depend on the page. You can move elements in the canvas. For example, you can adjust the positions of nodes in a network diagram. Automatic layout tools are also available in some cases. See "Changing the Layout" for more information.
A toolbar above the canvas enables you to control the view by zooming, panning, and so on.
An overview section appears to the right of the canvas. This section enables you to move around in the diagram or visualization when zoomed in. See "Using the Overview Section" for more information.
An information section appears below the overview, displaying information and links for the element selected in the canvas. See "Getting Information About Elements" for more information.
Changing the Layout
You can control the layout of elements in diagrams. (You can also move child entities in an Equipment visualization, but the reasons and methods for doing so are different. See "Moving Equipment within an Equipment Hierarchy"). For example, you may want to move the position of nodes in a network diagram to better illustrate their relationships.
There are two ways to change the layout:
By selecting elements, then dragging them to new positions. After dragging elements, make sure to save their positions. If you move a network node, its edges automatically shift to reflect the node's new position.
By clicking automatic layout buttons in the toolbar. Various different layout options are available. When you click a layout button, elements are arranged automatically into a particular kind of layout. The options you can use are described in the Help topics for the Network, Inventory Topology, and Service Topology pages.
The Overview section to the right of the canvas shows a small-scale view of the entire diagram or visualization. You can use the Overview section to orient yourself and to move the view when zoomed in.
To use the Overview section:
Use the Zoom or Zoom In button to zoom in on a portion of a diagram.
The overview displays a rectangle around the portion of the diagram that you have zoomed in on. If you zoom out, the rectangle becomes larger until it disappears when the entire diagram is displayed in the main view.
Drag the rectangle in the overview to another location in the diagram.
The main view of the diagram moves at its current zoom level to the new location.
You can get information about elements that you select in a diagram or visualization. When an element represents a resource in your inventory, the information section to the right of the canvas displays the name and ID of the selected element as links. You can click the links to go to the corresponding Summary page.
In some cases, you can also open an entity Summary page by right-clicking an element and selecting Summary Page.
To get information about elements:
In the toolbar, click the Select button.
The cursor changes to a pointer.
Click an element in the diagram or visualization.
The entity name and ID appear in the information section to the right of the diagram.
(Optional) Open the Summary page of an entity by clicking a link in the information section.
The Summary page appears.
Working with Resource Reservations
Resources can be reserved by an entity or process to prevent them from being used by another entity or process. Any consumable resource entity (except for Pipe entities) can be reserved as long as it:
Is not shareable. If the entity's specification is defined such that the entity can be assigned to multiple entities, the entity cannot be reserved.
Has not been assigned. The Resource Assignment status must be Unassigned.
Is not already reserved. Search results for entity types that can be reserved include a Reservation Type column that displays Shortterm or Longterm when a resource is reserved.
Does not have a Blocked condition that prevents the assignment. Search results include a Condition Type column that shows the conditions applied to an entity. See "Working with Conditions" for more information about conditions.
You can create and search for reservations from the navigation section. Reservations do not have Summary pages, however.
You reserve resources by associating them to a reservation. Each reservation has a single ID no matter how many entities are associated to it. You can add resources to a new reservation that you create in the process of adding the resources. See "Creating New Reservations" for more information. You can also add resources to an existing reservation. See "Updating Reservations" for more information.
You can remove a resource from a reservation only from the resource's Summary page. See "Removing Resources from Reservations" for more information.
By default, UIM does not check reservations when resources are assigned. As a result, a reserved resource can be assigned to any entity or process.
If UIM is configured to check reservations, it requires that reservations be redeemed before a reserved resource can be assigned. See "Redeeming Reservations" for more information. See UIM Concepts and UIM Developer's Guide for information about enabling reservation checking.
You can create new reservations and add resources to them in the following ways:
From the navigation section. See "Creating Reservations from the Navigation Section".
From the Summary page of a resource that you want to reserve. See "Creating a Reservation from a Summary Page".
From the Search Results section of a search for resource entities. See "Creating Reservations from a Search Results Page".
When you create a new reservation, you specify its type as either Shortterm or Longterm. The type defines the duration of the reservation's validity, unless you supply a specific expiry date. By default, Shortterm is defined as 10 minutes and Longterm as 30 days. These definitions can be changed by modifying rulesets and can be set to different lengths for different types of entities. See "Overview" in UIM Developer's Guide for more information.
When you create a new reservation starting from the navigation section, you must specify the resources it reserves. You can update the reservation later to include new resources.
To create a reservation from the navigation section:
In the Inventory - Resources group of the navigation section, click Reservations.
In the Search Results section, click Create.
In the Reservation For Type list, select the type of entity or process for which the reservation is made.
The options in the list vary depending on how UIM is configured. If reservation checking is enabled, this value must be specified during reservation redemption. See "Redeeming Reservations" for more information.
In the Reserved For field, enter text that identifies the agent making the reservation.
In the Reservation Type list, select Shortterm or Longterm.
In the Start Date field, enter the date on which the reservation becomes effective.
(Optional) In the Expiry Date field, enter the date on which the reservation expires.
(Optional) In the Reason field, enter a reason for the reservation.
In Add Resources section, click Resource Type.
A list of entity types appears.
Select the type of resource you want to reserve.
The entity Search page appears.
Do one of the following:
Enter search criteria in the Search section and click Search to reserve an existing entity. See "Searching for Entities" for more information.
Click Create in the Search Results section to create and reserve a new entity. See "Creating Entities" for more information.
In the Search Results section, select the resources you want to include in the reservation.
Click OK.
The Reservation page displays a list of resources included in the reservation.
Click Save and Close.
The page refreshes to show a message confirming the creation of the new reservation.
To create a reservation from a Search Results page:
Search for the resource that you want to reserve.
In the Search Results section, select the resources you want to reserve.
From the Actions menu, select Add to Reservation.
The Reservation Search page appears.
Click Create in the Search Results section to create a new reservation. See "Creating Entities" for more information.
The Reservation - New page appears. See "Reservation - New Page" for more information about the fields in this page.
In the Reserved For field, enter text that identifies who is making the reservation.
This value must be specified during reservation redemption. See "Redeeming Reservations".
If you set a date here, it overrides the Reservation Type setting.
To create a reservation from a Summary page:
Open the Summary page for the resource that you want to reserve.
From the Related Pages menu, select Reservations.
The Reservation page appears. If a reservation is already shown, you cannot reserve the resource unless you delete the existing reservation. See "Removing Resources from Reservations".
Click Create.
In the Reserved for Type list, select the type of entity or process for which the reservation is made.
Define a date here to override the Reservation Type setting.
The list of reservations reappears, now including the reservation you just created.
Adding an Entity to an Existing Reservation from a Search Results Page
To add an entity to an existing reservation from a search results page:
Click Actions and select Add to Reservation.
Search for the reservation to which you want to add the resource.
In the Search Results section, select the reservation to which you want to add the resource.
Click OK.
You can update a reservation's type, start date, expiry date, and reason.
To update a reservation:
Search for the reservation you want to update.
In the Search Results section, click the link for the reservation you want to update.
The Reservation Information page appears.
Update the Reservation Type, Start Date, Expiry Date, and Reason fields, as required.
The Search Results page appears, and a note confirms that you updated the reservation.
To remove a resource from a reservation:
Open the Summary page for the resource that you want to remove from a reservation.
A list of the resource's current reservations appears.
Select the reservation from which you want to remove the resource and click Delete.
The list refreshes and the reservation is removed.
The process of allocating a resource that has been reserved is called redeeming the reservation.
If resource reservation checking is enabled, UIM prompts you during resource redemption for the Reserved For and Reserved for Type values that were entered at the time the resource was reserved. If you enter the correct values, the reserved resource is assigned and removed from the reservation. If you enter incorrect values, UIM displays an error message and the resource remains reserved.
If resource reservation checking is not enabled, a reserved resource is assigned without any check.
Resource redemption is not supported for pipe configurations.
To redeem a reservation:
Select a reserved resource for assignment to a configuration item.
The Redeem Reservation dialog box appears.
From the Reserved for Type list, select the type that was entered when the reservation was created.
In the Reserved For field, enter the text that was entered at the time the reservation was entered.
Click OK.
The resource is assigned.
You use the Reservation - New page to create new reservations.
Reservation Information Section
Reserved For Type |
Select the type of entity or process for which the reservation is made. |
Reserved For |
Identify who is making the reservation. |
Reservation Type |
Select the length of the reservation, either Longterm or Shortterm. The type defines the duration of the reservation's validity, unless you supply a specific expiry date. By default, Shortterm is defined as 10 minutes and Longterm as 30 days. See "Overview" in UIM Developer's Guide for information about modifying rulesets to define different reservation type durations. |
Reservation Number |
Displays the reservation number after the reservation has been created. This number is generated automatically, and the field is read only. |
Start Date |
Enter the date on which the reservation becomes effective. |
Expiry Date |
If you selected Longterm in the Reservation Type field, enter the date on which the reservation expires. |
Reason |
Enter a reason for the reservation. |
Add Resources Section
Item |
Select the type of resource you want to reserve. You can select from existing entities or create new entities. See "Searching for Entities" and "Creating Entities" for more information. |
Delete |
Select an entity in the table and click Delete to remove the entity from the reservation. |
Reservation - Information Page
You use the Reservation - Information page to edit existing reservation information.
Reserved For Type |
Displays the type of entity or process for which the reservation is made. This field is read only. |
Reserved For |
Displays the person who is making the reservation. This field is read only. |
Reservation Type |
Start Date |
Expiry Date |
Reason |
Item |
Delete |
You use conditions to limit the availability of resources for a particular reason and period of time. You can also use conditions or to cause messages to be displayed when resources are assigned. For example, you can apply a condition to block a particular telephone number from being assigned.
There are three types of condition: Blocked, Warning, and Informational. By default, only the Blocked condition has an effect on the availability of a resource. A Blocked condition prevents a resource from being assigned. For example, if an Equipment entity has a Blocked condition, it cannot be assigned to a service.
UIM can be customized with rulesets to define behavior associated with Warning and Information conditions. See "Overview"UIM Developer's Guide for more information about rulesets.
See the following topics for more information about working with conditions:
Adding Conditions
You add conditions from a resource's Summary page or from the Search page Search Results section. You can define multiple conditions for a resource, but each condition must have unique reasons and start dates.
See the following topics for more information about adding conditions:
Adding Conditions from a Summary Page
You add conditions from a resource's Summary page. You can define multiple conditions for a resource, but each condition must have unique reasons and start dates.
To add a condition from a resource Summary page:
From the Related Pages menu, select Conditions.
The Conditions page appears, displaying a list of any existing conditions.
Click Create.
The Condition - New page appears.
Enter or select values in the Condition Type, Reason, and Start Date fields.
These are required fields. See "Condition - New Page" for information about the fields in this page.
(Optional) Enter a description of the condition.
(Optional) In the End Date field, enter the last date on which the condition will apply.
The Conditions page displays the new condition.
Adding Conditions from the Search Results Section
You add conditions from a resource Search page in the Search Results page. You can define multiple conditions for a resource, but each condition must have unique reasons and start dates.
To add a condition from a resource Search Results section:
In the navigation section, click the entity for which you want to create a condition.
The entity Search page appears, displaying search criteria for the selected entity.
Search for or create an entity of the selected type.
In the Search Results section, select one or more entity rows.
From the Actions menu, select Add New Condition.
The Condition Type column in the Search Results section is updated to reflect the new condition defined for the resource.
Deleting Conditions
To delete a condition:
In the Summary page of a resource entity, select Conditions from the Related Pages menu.
Select the condition you want to delete and click Delete.
The condition is deleted from the list.
Modifying Conditions
You can modify the type, description, and end date of a condition.
To modify a condition:
Click the link for the condition you want to modify.
Modify the type, description, or end date.
See "Condition - New Page" for more information about the fields in this page.
The Conditions page displays updated information for the condition you changed.
You use the Condition - New page to define new conditions for resources.
Condition Type |
Select one of the following:
Description |
Enter a description of the condition. |
Reason |
Enter the reason for the condition. All reasons must be unique. |
Start Date |
Enter the first date on which the condition applies. The current day appears by default. When multiple conditions are defined for a single resource, start dates for the condition must be unique. |
End Date |
Enter the last date on which the condition will apply. |
Working with Custom Involvements
UIM enables you to define custom involvements between entities that are not otherwise associated. Involvements can optionally be based on specifications that you use to define the different kinds of associations in your inventory. For example, you can create specifications that define involvements between physical connectors and the ports they support.
UIM provides a default specification for a special kind of custom involvement called a preconfiguration. A preconfiguration enables you to set up an association among entities that makes later operations more efficient. For example, you can create a preconfiguration involvement that associates a cell phone handset to a telephone number, which is in turn associated with a SIM card. This arrangement is not yet a service, but the use of involvements makes it possible to set up the service quickly when a subscriber purchases the phone.
The following kinds of entities can have custom involvements:
Connectivity
Custom network address
Custom object
Device interface
Equipment
Equipment holder
IPv4 address
IPv4 subnet
IPv6 address
IPv6 subnet
Logical device
Network Address Domain
Physical connector
Physical device
Physical port
Pipe
Place
Property location
Telephone number
You create involvements between entities from the Involvement section of a Summary page. When you create the involvement, you specify which Involvement specification (if any) to use. You can also define which role of each entity is relevant to the involvement.
See the following topics for more information about working with custom involvements:
Associating Entities by Using Involvements
You can use involvements to associate entities with existing entities or to new entities you create during the association process.
To associate an entity to another entity:
Open the Summary page of an entity you want to involve with another.
In the Involvements section, click Involve.
A list of entities appears.
Select the type of entity you want to involve.
The entity Search page appears, displaying search criteria for the selected entity type.
Enter search criteria in the Search section and click Search to add an existing entity. See "Searching for Entities" for more information.
Click Create in the Search Results section to create and add a new entity. See "Creating Entities" for more information.
In the Search Results section, select the entity to add.
Click OK.
The Items section is updated with the entity you added.
(Optional) In the Involvement Specifications list, select a specification that defines the involvement.
Click Involve.
The Involvement dialog box appears. If you selected an Involvement specification, the dialog box may include fields for its characteristics.
In the From Role Entity list, select the role of the entity from which you are creating the involvement.
If the involvement is relevant to all of the entity's roles, do not make a selection. If the entity has no defined roles, the list is empty.
In the To Role Entity list, select the role of the other entity that is relevant to the involvement.
Enter information for all required fields, and optionally enter information for optional fields.
The Involvements section includes the entity that you selected.
Deleting Involvements
To delete an involvement:
Open the Summary page of the entity from which you want to delete an involvement.
In the Involvements section, select the involvement that you want to delete.
Click Delete.
The Involvements page refreshes and the list reflects the deletion of the involvement.
Editing Involvements
You can edit the involvement information that you specified when you associated an entity with other entities, including the roles that pertain to the involvement. You can also edit any characteristics defined by the Involvement specification.
To edit an involvement:
Open the Summary page of the entity whose involvement you want to edit.
In the Involvements section, select the involvement that you want to edit.
Click Update.
The Involvements page displays the Involvement Information section.
Edit the involvement information and click Save and Close.
The Involvements page refreshes.
