Retrieve Simple Cycles List containing the provided edge
get
/topology/v2/edge/cycles/{name}/filter/{filtername}
Retrieve simple cycles based on the edge eid
Request
Path Parameters
There's no request body for this operation.
Back to Top
Response
Supported Media Types
200 Response
Cycles retrieved successfully
Body ()
Root Schema : Vertex
Type: object
Show Source
Nested Schema : bridgeEdges
Type: array
Unique Items Required: true
Show Source
Nested Schema : pathIds
Type: array
Show Source
Nested Schema : properties
Type: object
Additional Properties Allowed
Show Source
Nested Schema : relationships
Type: object
Show Source
Nested Schema : BridgeEdge
Type: object
Show Source
Examples
400 Response
The request isn't valid
Body ()
Root Schema : ErrorType
Type: object
Show Source
Nested Schema : message
Type: array
Show Source
401 Response
The request is unauthorized
Body ()
Type: object
Show Source
Type: array
Show Source
403 Response
The request is forbidden
Body ()
Type: object
Show Source
Type: array
Show Source
404 Response
The requested resource not found
Body ()
Type: object
Show Source
Type: array
Show Source
500 Response
An Internal Server Error has occurred
Body ()
Type: object
Show Source
Type: array
Show Source
Back to Top
