Edge REST Endpoints
Active Topology Automation/Edge
REST APIs for Active Topology Automation, Edge.
Create a new Edge
Method: post
Path: /topology/v2/edge
Delete an existing edge based on the entityId
Method: delete
Path: /topology/v2/edge/eid/{eid}
Delete an existing edge based on the fromNode and the toNode
Method: delete
Path: /topology/v2/edge/fromnode/{fromnode}/tonode/{tonode}
Delete an existing edge based on typeId and referenceId
Method: delete
Path: /topology/v2/edge/typeid/{typeid}/referenceid/{referenceid}
Retrieve a list of communication edges
Method: get
Path: /topology/v2/edge/communication
Retrieve a list of communication edges in a network
Method: get
Path: /topology/v2/edge/communication/network/{network}
Retrieve a list of communication edges terminated on a location
Method: get
Path: /topology/v2/edge/communication/location/eid/{loceid}
Retrieve a list of communication edges terminated on a network entity code
Method: get
Path: /topology/v2/edge/communication/nec/eid/{neceid}
Retrieve a list of communication edges within a specific distance of a device
Method: get
Path: /topology/v2/edge/communication/center-vertex/eid/{eid}
Retrieve a list of communication edges, nodes and alarms in a network
Method: get
Path: /topology/v2/edge/network/{network}
Retrieve a list of containment edges
Method: get
Path: /topology/v2/edge/containment
Retrieve a list of edges
Method: get
Retrieve a list of Edges
Method: post
Path: /topology/v2/edge/edges
Retrieve a list of edges using a list of entity ids
Method: post
Path: /topology/v2/edge/eids
Retrieve an existing Edge based on enityId
Method: get
Retrieve an existing Edge based on typeId and referenceId
Method: get
Retrieve an related device edges based on the device enityId and edge label
Method: get
Path: /topology/v2/edge/device/eid/{eid}
Retrieve Simple Cycles List containing the provided edge
Method: get
Path: /topology/v2/edge/cycles/{name}/filter/{filtername}
Retrieve Simple Cycles Lists for a list of connectivity names
Method: post
Path: /topology/v2/edge/cycles/filter/{filtername}
Retrieve the location hierarchy down
Method: get
Path: /topology/v2/edge/vertex/eid/{eid}/hierarchy
Update an existing Edge
Method: put
Update cost of existing edge
Method: patch
Method: patch
Update edge active event severity by alarm type
Method: put
Path: /topology/v2/edge/activeEvent/eid/{eid}/severity/{severity}
