Retrieve a list of edges
get
/topology/v2/edge
Retrieve a list of existing edges
Request
Query Parameters
boc: string
The Edge boc to be searched
fromnode: string
The fromnode entityid for the edges
fromnodeLabel: string
The fromnode label for the edges
The id of the edges
label: array[string]
The label for the edges
limit: integer(int32)
The limit for pagination
The name of the edges
offset: integer(int32)
The offset for pagination
property: array[string]
The properties of an edges
tonode: string
The tonode entityid for the edges
tonodeLabel: string
The tonode label for the edges
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
Edge retrieved successfully
Root Schema : schema
Type:
Show Source
object-
autoSuggestName: string
availableCapacity: boolean
businessObjectClass: string
capacities: array
capacities
channels: array
channels
costValue1: number
(double)
costValue2: number
(double)
costValue3: number
(double)
createdDate: string
(date)
Example:
2022-03-10 -
createdUser: string
edgeType: string
entityId: integer
(int64)
entityVersion: integer
(int32)
fromNode: integer
(int64)
fromNodeBusinessObjectClass: string
fromNodeCapacityConsumed: number
(float)
fromNodeData: string
fromNodeId: string
fromNodeReferenceId: string
inventoryStatus: string
isChannelized: boolean
isPipeInterfaceTerminated: boolean
lastModifiedDate: string
(date)
Example:
2022-03-10 -
lastModifiedUser: string
maxBandwidth: number
maxContiguousChannels: integer
(int32)
nativeEMSName: string
pathIds: array
pathIds
Unique Items Required:
true -
plannedActiveEvent: integer
(int64)
properties: object
properties
Additional Properties Allowed: additionalProperties
protectedEdge: boolean
ratecode: string
referenceId: integer
(int64)
ringName: string
specName: string
technology: string
toNode: integer
(int64)
toNodeBusinessObjectClass: string
toNodeCapacityConsumed: number
(float)
toNodeData: string
toNodeId: string
toNodeReferenceId: string
totalCapacity: number
trailPaths: integer
(int32)
unitBitRate: number
unplannedActiveEvent: integer
(int64)
Examples
400 Response
The request isn't valid
401 Response
The request is unauthorized
403 Response
The request is forbidden
404 Response
The requested resource not found
500 Response
An Internal Server Error has occurred
