Update cost of existing edge
patch
/topology/v2/edge/typeid/{typeid}/referenceid/{referenceid}
Request
Path Parameters
referenceid(required): string
The reference id of edge
typeid(required): string
The type id of edge
Supported Media Types
- application/json
Root Schema : schema
Type:
Show Source
object-
autoSuggestName: string
availableCapacity: boolean
businessObjectClass: string
capacities: array
capacities
channels: array
channels
costValue1: number
(double)
costValue2: number
(double)
costValue3: number
(double)
createdDate: string
(date)
Example:
2022-03-10 -
createdUser: string
edgeType: string
entityId: integer
(int64)
entityVersion: integer
(int32)
fromNode: integer
(int64)
fromNodeBusinessObjectClass: string
fromNodeCapacityConsumed: number
(float)
fromNodeData: string
fromNodeId: string
fromNodeReferenceId: string
inventoryStatus: string
isChannelized: boolean
isPipeInterfaceTerminated: boolean
lastModifiedDate: string
(date)
Example:
2022-03-10 -
lastModifiedUser: string
maxBandwidth: number
maxContiguousChannels: integer
(int32)
nativeEMSName: string
pathIds: array
pathIds
Unique Items Required:
true -
plannedActiveEvent: integer
(int64)
properties: object
properties
Additional Properties Allowed: additionalProperties
protectedEdge: boolean
ratecode: string
referenceId: integer
(int64)
ringName: string
specName: string
technology: string
toNode: integer
(int64)
toNodeBusinessObjectClass: string
toNodeCapacityConsumed: number
(float)
toNodeData: string
toNodeId: string
toNodeReferenceId: string
totalCapacity: number
trailPaths: integer
(int32)
unitBitRate: number
unplannedActiveEvent: integer
(int64)
Examples
Back to Top
Response
- application/json
200 Response
Cost of edge is updated sucessfully
Type:
Show Source
object-
capacities: array
capacities
channels: array
channels
costValue1: number
(double)
costValue2: number
(double)
costValue3: number
(double)
createdDate: string
(date)
Example:
2022-03-10 -
createdUser: string
edgeType: string
entityId: integer
(int64)
(int32)
fromNode: integer
(int64)
(float)
fromNodeId: string
(date)
Example:
2022-03-10 -
(int32)
pathIds: array
pathIds
true -
(int64)
properties: object
properties
ratecode: string
(int64)
ringName: string
specName: string
technology: string
toNode: integer
(int64)
(float)
toNodeData: string
toNodeId: string
trailPaths: integer
(int32)
unitBitRate: number
(int64)
Examples
400 Response
The request isn't valid
401 Response
The request is unauthorized
403 Response
The request is forbidden
404 Response
The requested resource not found
500 Response
An Internal Server Error has occurred
